Question about Norcent Technologies Televison & Video
I have a 4233 norcent 42
The power will not come on to the tv for about two or three weeks! once back the tv works fine until the next time .....had three different instances in the last 4 months i have to leave it unplugged for that time and then it suddenly gets power back ........does this tv have an internal battery???
  • hudgin4
    hudgin4 Oct 30, 2012
    oh the power going off has been three different power outages i forgot to mention that
    Sergeant:
  • 214 Answers
I would check to see if any capacitors are bulged or failing and replace them.
Posted on Nov 02, 2012
  • 275 Answers
SOURCE: Sony 36" tube TV
It definitely does not seem to be a problem with the Picture Tube. More like a cold solder. It is definitley not a job for a layman. Also, get a good technician to have a look, as locating cold solders is a labourous and time consuming process. It could also be possible that the main DC filter capacitor is getting dry, and may require replacement.
Posted on Aug 15, 2006
Soulvisitor
  • 1113 Answers
SOURCE: Sony Trinitron Wega kv-36fs120 wont turn on, standby/timer LED flashes 9 times.
I have your service manual but I can't find any reference to 9 flashes, are you sure it is 9 with out a pause?
see below from manual.....
Posted on Jan 31, 2008
  • 135 Answers
SOURCE: TV turns on & off
Hi there!
Exterior equipment attached to a standard tv cannot cause the set to switch on/off by itself.
I think you may have a power supply fault or else loose solder connections on the board, hence the "warming up" intro before the fault shows itself.
My suggestion would be a service technician if you are not familiar with electronics or TV's. Regards, JUS004
Posted on Mar 24, 2008
  • 3 Answers
SOURCE: NORCENT PT -4233
Norcent PT4233 no picture, black screen, but has sound. How to repair
The display (PDP - Plasma Display Panel) at the heart of this unit is a LG 42V7 model. There is a known bad solder "defect" on the YSUS board that causes this board to fall unexpectedly.
The bad news is that you have to replace all the primary boards on the display - ZSUS, YSUS and CTRL boards, as the failure can/often takes them all out.
The good news is that LG makes a repair kit for this panel. Its part number is 687VSNB03E and it contains the three boards LG6871QYH036D (Y SUSTAIN), LG6871QZH041B (Z SUSTAIN) and LG6871QCH053G (CTRL).
Hope this helps
Posted on Feb 07, 2009
jojack2k5
  • 34 Answers
SOURCE: Toshiba TV Remote Control not working
REPLACE IR SENSOR INSIDE THE SET COMMON PROBLEM
Posted on Apr 12, 2009
Have no power on my norcent LT-4247 lcd tv?? Cord is fine
Verify the outlet, check out the main fuse in the power supply, check for bad caps, cold solder joints, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 24, 2010 | Norcent Technologies LT4247 42 in. LCD TV
CANNOT PROGRAM REMOTE TO NORCENT TV
hi are you use universal remote if yes let me think that u use RCA UNIVERSAL REMOTE do this press and hold on remote the TV button at same time press and hold power button on remote solid light until come up then press N HOLD play for five sec until your TV sleep then press and hold REVERSE EVERY 2 SEC until your tv comes up then press stop, do all that when you are point to your TV . good luck.
Apr 28, 2010 | Norcent Technologies LT4247 42 in. LCD TV
Sylvania 6842THG won't turn on. the tv red light displays when you push the power button you hear a click and then 5 - 10 seconds it goes back off
I have been having the same issue. I unplug the TV for 10 minutes and it usually works fine. I moves all of my A/V plugs to a single power strip and that helped a lot. Since then, the TV went into protection mode only once in 2 weeks. Next, I will use a power strip that includes the cable protection.
Dec 12, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
No display/picture. Sound and power work perfectly.
Based on your problem listing I believe you have an LCD tv.
You can check your tv by turning it on to a station that normally
shows a good picture. Shine a bright flashlight and place it against the screen. Look around the edge of the flashlight for an image moving around. If you see it, your problem is with the inverter/CCFL..
Feb 06, 2009 | Norcent Technologies LT-2722 27 in. LCD...
NORCENT PT -4233
Hope this helps
Sep 04, 2008 | Norcent Technologies2703 27" TV
LCD TV Remote quit working
First thing, turn off the TV and unplug it for about 2-3 minutes. Remove also the batteries on your remote. Re-install the batteries on the remote and plug in your TV. Power on your TV using the remote. No luck?
Norcent may not be supported by a universal remote. If you just bought your unit new (maybe Best Buy who carries this brand) you are still covered by its warranty. Below are ways you can reach Norcent.
http://www.norcent.net/main/contact.asp
909) 305-2121
support@norcent.net
Mar 24, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Fujitsu 42" Plasma Display shuts off after 20 minutes
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
Oct 21, 2007 | Fujitsu Plasmavision PDS-4233 42 in....
Televison & Video Logo
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
