Question about Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP
Power cable broken for sony xdr-s10hdip
Alternative power supply
The time does not automatically set on my sony alarm clock XDRC706DBP
Afraid I have the same problem and I have to manually set.
good luck !
Jul 07, 2014 | Sony Xdr-c706dbp Dab / Dab Digital Alarm...
My Sony radio XDR-S55DAB has completely stopped working. Initially all that showed on the display unit was the symbol for a dead battery but this also appeared when it was mains connected. I have pressed...
I have noticed exactly the same issue with my Sony XDR-S55DAB
Even if it has batteries installed but only working off mains electricity, after several months it will not start when the power button is pressed and I have to replace the batteries.
The radio will work again if you just replace the batteries with fresh ones
Try this next time the batteries go flat; disconnect the radio from the mains, replace the batteries with fresh ones, and leave for a couple of minutes (you do not have to switch on!).
You can remove the batteries if you like then reconnect the mains cable and press ON
If your radio behaves exactly the same as mine, it will spring into life so how come?
In the "olden days" ie pre-2000, small portable radios often had a physical switch which connected and disconnected the power supply be it battery or mains.
Nowadays, many radios don't have a "proper" switch, but a "function" button - press it on, and the radio operates, press it again and the radio stops - to enable this, a very small amount of charge is required to keep the central "brain" alive in order to notice this, and in the case of the Sony XDR-S55DAB, this only seems to be supplied by the battery, not the mains adapter.
My advice is simply keep a spare set of batteries handy and replace them whenever your radio wont turn on. Using the mains adapter allows the batteries to lastfar longer than using the batteries on their own.
It is completely counter-intuitive that a "battery/mains" radio needs batteries to work off the mains, but this is the only design fault can find in an otherwise excellent radio.
Aug 15, 2013 | Audio Players & Recorders
Hello. although my iphone is being detected, my radio (am/fm) does not work. i pressed the
I think the radio only works with the headphones on ..cause it plays the role of antenna ...try to see if it works with them ..and if it does this is the issue for not working ...The dock does not takes the antenna place and therefore it can not work proper..
It may be able to work if you use a cable to plug into it ..and take the signal to the amplifier via jack connection ..The cable might do the trick ..
Dec 08, 2011 | Sony HD Radio and Dock Docking Station,...
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
I need remote code for sony xdr-ds12ip i pod docking station
call sony and request or check amazon. usually you can download an app for your iphone for remotes or you can try a universal remote. program it to your dock radio station
May 06, 2011 | Sony HD Radio and Dock Docking Station,...
Sony mains DC lead for XDR-S7
ask in Local Electronics shop. Probably they have
Nov 29, 2009 | Electronics - Others
Need owners manual and remote
Hello, I think I can help you.
The owners manual is available from the sony site. Just click on the link below.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=XDRS10HDIP
Then click on operating instructions to download a PDF of the manual.
The remote is available from Sony at this link.
http://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to provide the best FixYa
May 04, 2009 | Audio Players & Recorders
SONY XDR-S55DAB Stack at display : DAB WAIT
Solution seems to be do not buy small Sony DABs, or any small ones. I have the XDR-S56DBP and have same problem. Was also cursed with 'no ensemble' error. Even worse than the Pure one I had before which lost all of the DAB facility and now only functions as an FM radio. I had a good medium sized Roberts one, but power cable split and I can't find a suitable replacement.
Apr 28, 2009 | Sony Audio Players & Recorders
Sony HD Radio and Dock Docking Station, Remote Control for iPod XDR-S10HDiP Logo
91 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
