I turn it on and in just about a couple second it just quit and has no power
SOURCE: My kenmore microwave automatically starts and can not be stopped
If and when an oven
is coming on or doing anything by itself, this is very dangerous and
can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open.
Is it possible that some spray cleaner got into the controls?
I always recommend that users instead spray cleaner on a soft cloth then wipe the control panel.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
If and when an oven
open.
On some models, the membrane keypad is not available as a separate part,
so you would have to order the control panel frame assembly which comes
with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock:
You can find handy exploded views and get part numbers by entering your full model number at the Sears Parts Site.
A full
Sears/Kenmore model number has 3 digits, a dot, then 8 more digits,
such as ###.########
Once you have the Sears part number, you can usually get parts cheaper here.
If you might be interested in having us so the work for you, we charge $39.95.
Feel free to contact me directly.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: My Kenmore Microwave, only a
read the info on the below link, it was posted by me;
http://www.fixya.com/support/r7088553-microwave_oven_not_heat_hear_loud
Good luck.
SOURCE: my kenmore ellite microwave 80803
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
We need the full model number from the tag on the unit to be able to help you with specific advice.Also, did it fail when you hit the "start" pad to begin cooking?Is the display lit? Does the inside light come on when you open the door? Is there any beep when you press a pad on the keypad?
My kenmore microwave just stopped working the model number is 72189655
