Question about Dryers
Hotpoint sensor dryer de luxe 9345 showing error code e2
Error code 2 is showing and there is an audible alarm. I've cleared the filter. I can't see a thermostat reset button so no idea what's wrong with it. Don't dare use it in case it's serious.
SOURCE: ctd80 hotpoint dryer error code f10
If you remove the back cover of the drier with the appliance un pluged, you will see the heater bracket.
un screw this from the back panel, and at the top you will see three thermostats. There is a brown one with a small hole in the middle, if you use a pin and press in, you should hear a click. This resets the thermostat and you should be able to use the drier again.
Apparently a common fault on these indicit based driers.
it worked on mine
Posted on Oct 28, 2007
SOURCE: MF8180C error code
DID SIMPLY REPLACING THE FUSER UNIT SOLVE THE PROBLEM?
Posted on Dec 27, 2007
tzweeb
  • 318 Answers
SOURCE: We have had our Whirlpool
the f22 code is a failed thermistor. you can try to change this yourself but if the unit is less then a year old then it will be covered by warranty.
the part is only about 30 bucks so if you can get one and find it behind the lint screen duct then you could change it and fix the problem.
Posted on Jan 06, 2009
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
Whirlpool GR396LXGQ oven comes on by itself & goes into clean cycle, code reads E2 -F3-
Whirlpool F3 faults relate to temperature problems in the oven. In the case of the error E2-F3, F3 is the general fault code and E2 is the specific error code. An E0-F3 error indicates that the oven's temperature sensor is open; E1-F3, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E3-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in the clean mode. Here is the probe to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 07, 2012 | Whirlpool Ovens
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
How to change the door switch
Hello.
Some Washer ranges are equipped with electronic displays that indicate the time of day and the oven's temperature when it's in use. The display also alerts users to error codes including PF, or power failure, and various letter and number combinations that correspond to issues ranging from electronic control malfunctions to problems with the oven door latch.
Related Searches:
F2 Faults
Washer F2 faults relate to temperature problems in the oven. In the case of the error E2-F3, F2 is the general fault code and E2 is the specific error code. An E0-F2 error indicates that the oven's temperature sensor is open; E1-F2, that the temperature sensor is shorted; E2-F3, that the oven temperature has exceeded the maximum rated 575 degrees Fahrenheit in "Cook" mode; and E2-F3, that the oven temperature has exceeded the maximum rated 950 degrees Fahrenheit in "Clean" mode.
Clear Error Code
If your oven display shows a letter/number combination, washer advises clearing the display. Press "UPPER OFF" or "LOWER OFF" on double oven models. On single oven models, press "OFF/CANCEL" to clear the display. If the code reappears, the manufacturer recommends contacting a professional service technician or contacting the Washer producer
Professional Service
The Tech Sheet included with Whirlpool ovens is meant for use by professional technicians servicing the unit. To address an E2 F3 error, a technician can check the oven's temperature sensor connection, measure the sensor's resistance and, if necessary, replace the sensor.
Thanks.
Dec 07, 2011 | Washing Machines
I have an Error 2 that happens when trying to scan a document. It makes a clunking noise. How do I fix this? Thanks in advance!
E2 error means is a paper jam.
Solution 1
Turn the printer off, then on again. Sometimes, when Pinter turned on, the position of the wheel is not correct, causing the error E2. By turning off the printer and then turn back, the position of the wheel will return to normal. This way I've ever done and it worked.
Solution 2
You turn the sensor vertically, as opposed to clockwise. By rotating the sensor vertically, roller wheel position to be shifted, so it will return to normal position. Rotate the sensor vertically, until you hear the sound (clak) of the wheel roller.
Nov 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
E2 Paper Jam code flashing .... but no paper jam!
There is a small sensor on the fuser that most likely has become disloged. It requires a lot of disassembly to get to.
But an E2 code is that sensor not being cleared off. It pops out of the frame sometimes during paper removal.
Apr 14, 2008 | Xerox WorkCentre XE80 Laser Printer
Dryers Logo
48 people viewed this question
Top Dryers Experts
