Question about Microwave Ovens
Microwave model# MH3185XPB-1 has a fuse iin it labeled T4H250 tell me the amps thank you
  • 4 Answers
It's 4A
Posted on May 18, 2014
2 Suggested Answers
  • 324 Answers
SOURCE: Cooks Microwave fuse 15 amp
www.digi-key.com or www.newark.com stocks those fuses.
Posted on Jun 10, 2011
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
Hi I have a daewoo microwave kor/6n9rr 800watt the upper fuse has blown ,enquired with spares suppliers ,only fuse showing on their parts was one with wire attached each end with terminals which I...
Hello Mary
You shouldn't be working on, or inside a microwave oven. They are not a consumer repair job due to the debilitating effects of microwave energy, the high voltages inside the capacitor, and the highly poisonous core to the magnetron.
Fuses blow for a reason, you have to find the reason before replacing the fuse. Unless you are an electrical engineer, take it to an authorised repair centre, or just buy a new one.
Apr 17, 2017 | Daewoo KOR6N9RR Microwave Oven
Where are the fuses located in a whirpool microwave mh3185xpb
The fuses are located on the inside for which the top cover must be removed. Check for short in the surge capacitor, protector if the fuse has blown.If there is power then make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Feb 11, 2013 | Microwave Ovens
The fan is part of the microwave and is functioning
all makes & models are fairly basic but some have 1 fuse inside the unit & some may have 2 or 3. mine had 2, one for the fan & one for the microwave functions control board. they are usually see through fuses so it's easy to tell if they're blown.you have to remove the microvave metal casing to get to them. hope this helps.
Nov 25, 2011 | GE Microwave Ovens
Where is the fuse located on the sharp r-1875 microwave
you have to take off the external housing and you will see a glass fuse near the power source.
Jul 19, 2011 | Sharp R-1874 Convection/Microwave Oven
MH7140XFQ Fuse Amp
you need to look at the ends on your fuse and this will tell you the amperage you need to get for your particular unit,get them from a hardware store
Sep 22, 2009 | Whirlpool MH7155XM Microwave Oven
Have a microwave model NNSA616W, sre 6C37231152 purchased in 2007. Am aware Panasonic has sent memo to distributors to install 20 amp fuse instead of the 18 amp that was in this model when it was...
PANASONIC BELIVES SERVICE IS THE INTEGRAL PART OF ANY BUSNESS. SO YOU CAN INFORM YOUR EXPERIENCE TO THE SERVICE DEPARTMENT OF PANASONIC IN YOUR COUNTRY.
Apr 07, 2008 | Microwave Ovens
Microwave Ovens Logo
60 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
