Question about JVC AM FM CD DET FACE CAR STEREO
Will not hold any memory when radio is turned off
I have a model kdg333 with a 12 cd changed in the boot when i turn the car ignition off and turn on almost straight away the memory is gone is this the head unit or the box thanks
  • playa04 Mar 26, 2009
    I am trying to install a pioneer head unit into my 91 EB Falcon everything is working just fine except the memory wont hold when car is turned off. i've tried earthing it and everything. the yellow wire which i'm sure is the one i need is not drawing any power at all can anyone tell me how to fix this problem?
    New Friend:
  • 57 Answers
There are two power wires for car radios mostly Red & Yellow check to make sure 1 wire is powered all the time in most cases its the yellow as well check the fuses from the radio on the red and yellow wire also make sure the red wire is only powered when ignition is on but it sounds like that wire is ok good luck....
Posted on Jan 10, 2009
How do I have to restart my eclipse avn52d car audio cd drive after I changed my car battery ?
You must be inside the Eclipse in order to unlock the radio's security system.
Insert the key in the ignition. Turn it clockwise one notch so some of the car's controls turn on, but not the ignition.
Press the radio's "On" and "Screen/Text" buttons at the same time and hold both down until "SEC" appears on the radio's screen. After two seconds, the screen will change to read "DISC."
Press the "Open" button on the front of the radio. The front panel should open it.
Insert the Key CD into the CD slot. The message "SEC" appears. You should have received this CD when purchasing the car. If you don't have this CD, contact your Eclipse retailer for an extra one.
Eject the Key CD by pressing the "Eject" button and close the front panel of the CD player.
Jan 27, 2018 | Eclipse Car Audio & Video
Power on, clock works, CD works, NO SOUND from the radio
Check the speaker wires maybe they have worked loose. And speakers themselves as they may blown. Do you have an amp if so check its fuse. Also check for inoperative interior lights, lighter, and horn. One of these circuits will power the radio's memory circuit. Some radio models will appear to work normally but have no sound if the memory fuse is blown. The clue is the clock will reset to 12:00 each time you turn on the ignition switch.
Feb 12, 2017 | Cars & Trucks
The radio buttons on 09 altima are not responding when u try to change to a new radio station and to cd or radio plus when u put the cd in u can't skip to the next song
First impression is you radio is toast. It maybe some component gone bad on a circuit panel inside the radio. Before you consign it to the deep try "rebooting" it. Most electronically controlled radios have some king of logic and memory boards in them ...so treat your radio like your computer when it starts misbehaving. To reboot the radio disconnect the battery (remove the black/negative lead first then the positive/red lead from the battery), put the key in the ignition and try to start the car (it won't of course but this is to discharge any holding capacitors) and turn on the radio ...again to discharge any holding capacitors. Turn everything off and let it sit overnight if you can. Reconnect the battery. The radio should have lost all saved information (time, stations, EQ settings etc) and may now be responsive to button inputs. If this doesn't work then I'd say the radio is a goner.
May 01, 2014 | Cars & Trucks
97 grand cherokee laredo wiring cd player install. can get power to it but have to have battery and ignition switch hooked together how to do it the other way? cause it erases my memory on the cd player...
Hi the ignition wire needs constant power thats how it saves your memory. You will need a test light to find the wire that is constant power. With the key off touch the light tester to the power wires from the radio harness the one that turns the light on with the key off is the ignition wire and is to be connected to the ignition wire from the radio.
Feb 05, 2010 | Cherokee (REF) AM/FM Stereo with CD Player...
I just put in a radio in my 88' truck and i have to reprogram my stations every time i start my truck,why is it not holding memory?
Your red memory wire is not hooked up or you switched the red and yellow ignition wire around and your radio stays powered up when you turn off the ignition.
Oct 17, 2009 | Dual XDMR-7700 CD Player
The memory does not work after the radio is turned off
When this happens it usually means that the ignition and battery wire are connected incorrectly. hope this helps...
Jan 03, 2009 | JVC AM FM CD DET FACE CAR STEREO
Radio Station Presets wont hold
hi girlygirl 1
the problem is your ignition and your permanant battery live wires are the wrong way round all you have to do is remove the stereo and you will usually see a red wire plug into another red wire and a yellow wire into another yellow wire all you have to do is change the red to the yellow and the yellow to the red and it will hold the memories fine hope that helps !
Nov 19, 2008 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Changed the radio in my car and the new radio wont hold its memory when the key is removed from ignition
Memory wire on new radio needs a live connection ie source that is live with ignition switched off.
Jul 20, 2008 | 1997 Audi A4
Sony car radio/CR/cassette doesn't hold pre recorded radio stations once ignition is turned off
run the yellow wire to the battery as its the memory wire and that will work if it is installed correctly and still does the same it can be the battery even if the battery still works.
May 25, 2008 | Car Audio & Video
Changing the clock
Try this, which works for most Pioneer car radios, they say.
Turn key to ignition on or accessories position, turn radio off. A time should be displayed, and maybe it is incorrect.
Press the Function key and hold it for 3 seconds and the hour will flash. Use either the up/down or the left/right button to change the time. When finished, I think you push the Function key again.
Nov 08, 2007 | Pioneer DEH-235 CD Changer
JVC AM FM CD DET FACE CAR STEREO Logo
738 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
