Question about Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series
Lately after tank fills as the water is shutting off it makes a howling noise. It`s hard to explain what it sounds like. It flushes great. It`s about 2 yrs old. What you all think?
2 Suggested Answers
  • 22 Answers
SOURCE: the toilet will not flush,
Is it a new installation or was it working before and now there's a problem?
It could be rod-clearance, it could be your water pressure or an obstruction in the inlet-filter, or maybe a couple of other things. Different fixtures have different minimum pressure requirements. Some work at 25 PSI static pressure at the connection but others require a 35 PSI minimum. This should be specified in the OEM's manual that you should have received with the toilet.
Some very informative troubleshooting videos are available for viewing at http:howto.flushmate.com
Posted on Sep 15, 2010
Dodge dakota hard steer
Could be a restriction in the rack.
Jan 19, 2014 | Cars & Trucks
Toilet tank is not working properly
Valve needs to be replaced on inside of tank flush valve is going bad replace it the water you are hearing is water going into the fill tube going into bowl nothing is wrong with that its normal.
Jan 04, 2014 | Kohler Home
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
My toilet makes a high pitched whine after being flushed. Pressing down on the top of the tank mechanism makes it go away but the next time it flushes the whine returns.
I would suspect that the flush valve has a blokage in it that is causing a harmonic distortion to be transmitted thru your cold water piping.. One way you may be able to help this is to slow fill rate down on your flush valve. If your fush valve has a seperate float to shut off water supply to tank when it;s full there should be a adjustement screw onside of valve where float rod goes in. Adjust screw down to raise float and thus slow fill rate of tank, this should help with the noise. Ifyour toilet does not have adjustable float see if you have a valve on incoming water supply. If you do you can try slow down flow thru supply valve and see if that helps, Thanks
Nov 18, 2010 | Kohler K-11466-0 White Cimarron Comfort...
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
Noise of flush water
You have two issues inside of the toilet tank. The holding down the button is caused by your chain not being tight enough from the handle to the flapper. Take the slack out of that and replace the flapper. The second is that you need to replace the fill valve. This is what is making the noise when the tank is being refilled, and will have to be adjusted after it is installed.
Please remember to rate this.
Apr 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
When filling bathtub or running two showers, water heater howls
it could be the fact thath the water comming in is what the problem is,, on a well system the water is extra cold and the unit is working hard and with sand aso comming in it makes it harder to keep the temp up on the water,,, flush the tank, put hose on it and open the drin valve with a hose on it turn the cold water on and let it flow till the water comes out clear usually about 5 min,,, get all the sand out and other debris and try it
Apr 03, 2009 | Water Heaters
Howling or squealing noise when the machine is filling with water
there is a restriction in the valve assembly. it is servicable so remove it, open it up on both hot and cold and clean thoroughly. replace and test
Jul 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Sloan M-101526-F Flushmate?® Complete Replacement System for 501-B Series Logo
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
