I want to stop radio transmission on bush radio
  • joecoolvette
    joecoolvette Oct 31, 2012
    Stop radio interference on a Walkie Talkie used in the bush? Otherwise I do not follow. In reality I am just curious.
  • Paul Austin Oct 31, 2012
    Have a look at spirit box on google that will give you and idea what it's used for
  • 3,799 Answers
Turn it to the "Off" position.
Posted on Nov 03, 2012
2006 buick rendezvous when turn on wipers they move very siow and stop half way up
Most likely the wiper transmission. It has plastic bushings that can deteriorate. Inspect the bushings and all are ok, suspect a bad or burnt motor at that position.
Mar 14, 2018 | Buick Cars & Trucks
Fixing linkage to transmission
If the transmission shifts and I mean NO problems .
You need to look at the allinment of the moving parts every thing has to fit correctly and line up move freely .
You may also have a problem ware some one replaced something like a lock nut or washer's that wore specific to the vehicle now the nut comes lose .Look at all the players bushings mounts angles make sure things are tight but above all look for somethimg that isn't wright that is ware the problem is .
Jul 16, 2016 | Jeep 2002 Liberty Limited Edition
How to put a manual transmission into gear without using the clutch or the trailer gear shifter
There is either a pilot bearing or a pilot bushing that supports the input shaft of the transmission. I don't know which, but if it is a bushing, it would make sense based on your description.
Maybe the clutch quite a bit and were in a position to use the clutch a lot, like in traffic or pulling a trailer, they could have overheated the clutch, which could have allowed the grease to melt and, left it a bit dry or cooked the grease enough to thicken it enough to cause the bushing to hold onto the input shaft, keeping it from stopping as quickly.
Apr 04, 2016 | Cars & Trucks
Need transmission bushing for 1983 Nissan pickup truck z24
Go to www . rockauto . com - Select Nissan - Pick Year 1983 - Pick Pickup - Choose Engine Size 2.0L L4, 2.2L L4, 2.2L L4 DIESEL 2.4L L4 or 2.5L L4 DIESEL. Then type in the part that you need "Transmission Bushing" You probably have a Standard Transmission and probably need a Clutch Pilot Bushing. The cost runs between $0.87 cents to as high as $1.42
Oct 08, 2014 | Cars & Trucks
How do I fix the wiper assembly on my 2008 Pontiac Grand Prix?
Should be able to just replace the bushing. Take it to a CARQUEST and have the guys look up the assembly. They will have a break down of what can be purchased as parts and not the whole thing.
Aug 04, 2014 | 2006-2008 Pontiac Grand Prix Windshield...
I have removed all of the screws from the valve body on my transmission and it will not drop down because off the electrical plug-in on the side of the trans. . What is stopping the valve body from coming...
The thirteen pin plug connector you mentioned is stopping you from removing the valve body.
First, locate and remove the heat shield protecting the wiring (transmission should be in the park position). The heat shield is held to the transmission with a bolt on one side and a screw on the other.
Second, disconnect the thirteen pin plug from the guide bushing.
Third, turn the bayonet locked guide bushing counter-clockwise. Loosen and remove guide bushing. The valve body should drop down at this point.
Hope this helps.
Oct 23, 2011 | 2004 Dodge Sprinter
How to install control arm bushing in a 1998 toyota camry
Many bushings all over in cars and all are pressed in. Which bushing are you referring to?
Jul 15, 2010 | 1998 Toyota Camry
How do you replace the transmission bushing on a
are you referring to the rear output bushing or the tourque converter bushing do you have a leak in between the motor and trans need more info please
Sep 13, 2009 | 1995 Chevrolet Caprice Classic
I'm replacing the tail shaft seal on transmission. I need to see how the seals are put in transmission
Drive it home with a ball peen hammer.Just a note here,behind every leaking seal is a worn out bushing,so don't be surprised if replacing the seal doesn't stop the leak.Inside the tailshaft housing is a bushing that engages the driveshaft yoke.It should be a fairly tight fit when the yoke is installed and the driveshaft is bolted up.Grasp the driveshaft and yoke and wiggle it up and down,should be just a couple thousandths play.If excessive play,it needs a new bushing which entales removing the extension housing,driving out old bushing,and driving in new bushing which requires bushing drivers.But the seal,you just drive it in with a hammer.It will want to walk the opposite direction,so you have to press it down with your other hand while hitting it with the hammer.Also make sure the seal has some lube on it where it contacts the yoke.A dry seal will rip and leak.
Jul 26, 2008 | Ford Ranger Cars & Trucks
Computers & Internet Logo
David Payne
David Payne
