Question about Comfort-Aire Dehumidifiers
Bucket full light wont shut off fdd2551 - Comfort-Aire Dehumidifiers
heatman101
  • 43501 Answers
SOURCE: LG dehumidifier
Here is a tip that I wrote to help people with just that dehumidifier problem..
Dehumidifier Problem It shows Bucket Full
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
heatman101
Posted on May 08, 2010
  • 420 Answers
SOURCE: 'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Posted on Jun 04, 2010
heatman101
  • 43501 Answers
SOURCE: bucket is empty but it wont run, bucket is full
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
heatman101
Posted on Mar 30, 2011
  • 4736 Answers
SOURCE: the bucket full light won't go out and the
Try resetting the bucket, making sure that it is set properly and triggers the safety lever/switch. If that doesn't solve the problem. Turn the Master ON/OFF Switch to OFF, unplug the unit from the wall outlet and wait 12-15 minutes. Plug the unit back in and turn the Master ON/OFF Switch to ON. If the bucket is installed properly, the unit should revert back to the original factory settings.
Hope this helps solve the problem.
Posted on May 29, 2011
dunnbiker
  • 8546 Answers
SOURCE: Full Bucket light stays on so dehumidifier will
If you don't have the manual it's here for free...
http://www.retrevo.com/support/LG-LHD45EL-manual/id/17335ci969/t/2/
Look at the picture in the upper right corner of page 12. The RED button is located in the upper left rear of the bucket cavity.
It may be jammed. Tap on it to make sure it moves freely. It must be pressed IN to indicate NOT FULL and allow operation. You should hear a click when it changes state and the light should go on and off. The weight of the float in the bucket presses it in until the water level rises.
Posted on Jul 14, 2011
When full bucket light comes on water is emptied and bucket put back in position. Fan will start and then the full bucket light comes back on beeps and shuts off.
You have to be sure bucket is replaced exactly where it should go or the bucket will hold the switch in, thinking it is full. If you have a floor drain close by,remove the bucket and set the dehumidifier over or next to drain so water will go down it,then you don't worry about bucket getting full.If it doesn't run with bucket off, maybe defective switch. unhook wires to the bucket switch and hook or tape together,if dehumidifier runs then switch is bad. UNPLUG FROM OUTLET BEFORE DOING THIS. IF YOU DON'T UNDERSTAND ELECTRICITY GET QUALIFIED HELP!!
Sep 17, 2014 | Dehumidifiers
The full bucket light stays on yet no water is collected
if water full light stays on the compressor wont start and remove water from air , investigate why light stays on ? is bucket really full? is sensor knocked out of its fragile holder ? is bucket all the way inside machine so that sensor is connected ?
Jul 04, 2014 | Kenmore 54501 Dehumidifier
Fedders a7dh45b2a*a-r dehumidifier shuts off before the bucket fills
Actually, it's probably doing what it should. Let me explain: Dehumidifiers run until they have lowered the humidity/moisture level to where you have the humidity extraction level set. At that point, the unit shuts OFF, until senses the humidity level has risen above where you set the level and it turns ON again. That doesn't mean the bucket will always be full when it shuts OFF. It may turn ON & OFF many times before the bucket is full. Watch for the Bucket Full Light to illuminate. That's when the bucket is FULL and needs to be emptied.
Hope this helped you understand how the unit works.
Jun 29, 2011 | Fedders A7DH45B2A Dehumidifier
Bucket is empty but it wont run, bucket is full light just flashes.
heatman101
Mar 01, 2011 | LG LHD45EL Dehumidifier
Jun 04, 2010 | Dehumidifiers
LCD READS CH 1 SHUTS DOWN BUCKET FULL LIGHT COMES ON
lcd reads ch 1 shuts down bucket full light blinks red
Aug 04, 2009 | LG Goldstar LD65EL Dehumidifier
Dehumidifiers Logo
14 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
