Question about HP Office Equipment & Supplies
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
Hp officejet pro l7780 all in one printer, Did all the checking of paper in side nothing there, Cleaned all rollers, including the pick up roller, it is still not picking up paper, The pickup roller drops down and turns but does not pick up paper. It is making a slight grinding noise.
    Top Expert:
  • HP Master
  • 35,531 Answers
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Posted on Oct 31, 2012
3 Suggested Answers
  • 56 Answers
SOURCE: HP Laserjet 1320 Series Printer-Grinding Noise Won't Pickup Paper
take the roller out again but this time make sure the paper sensor is in the proper place. it does go scew when putting a new roller in. It happened to me last month.
you dont need to get another printer.
Posted on Oct 09, 2009
SOURCE: The auto-document feeder on our HP L7780 OfficeJet
I put an elastic band around the black roller as it doesnt seem big enough and it works nearly every time now. Have done this with another L7780 Pro as well which fixed it completely on that one.
Posted on Dec 22, 2009
Rollers not picking up the paper or picking too many pieces at once.
Pickup rollers can be easily replaced if you want to try that first. But the other noises could point to stripped gears or a different problem internally
Jan 08, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
My HP Officejet Pro L7780 faxes off & on. Motor is running w/in ADF, but the pick assembly does not grab paper
There should be a textured seperator pad, if that's worn out, replace it. Also check the ADF rollers should not be smooth. You may need to just replaced the ADF maintenance kit. It should include the roller assembly and seperator pad.
Jan 17, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
When making copies, auto document feeder picks up paper and rollers squeal but paper gets stuck on underside. If you lift the lid about an inch the paper will feed through. HP Model L7780
open the top cover, on the very left there is a part that can be removed (running front to back) I believe you will see a scrap of paper iunder there. remove the paper, replace the part and try again
Jan 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
The auto document feeder does not pick up the paper
The pickup roller is probably dirty. Take a clean sheet of paper and put a small amount of rubbing alcohol at the end. Take that same end and place it in the automatic feeder and attempt to feed through for a few times. This should clean the pickup roller and allow paper to be picked up. Wait a few minutes for the alcohol to dry and attemt to feed a clean sheet of paper. You might need to repeat the process a few times
The paper feeder won't feed the paper through when faxing and copying. The rollers just keeps spinning. Help!
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
The auto-document feeder on our HP L7780 OfficeJet Pro printer doesn't pick up the papers anymore. The 'gears' are spinning, but the papers aren't advancing. I've cleaned the rollers, but that still didn't...
Jun 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Tray 2 Printing
Couple of things for you to check out.
1. Is that you've enabled the second tray for the printer. This is normally automatic but to check go to:
START > Printers > L7780 > Properties
- Click the "Device Settings" tab
... then sort out the different setting so they are all correct such as paper size and of course "Tray 2: Installed"
2. The other more common issue is simply that the printer isn't sitting properly on top of Tray 2 and as a result it's not engaging the cog wheel properly to pick up paper.
This is one of those trial and error things where you pick up the printer and re-slot it down onto Tray 2 until it works properly.
Hope that helps...
May 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Feeder won't pull paper
the arm in the printer is a cog setting you may have inadvertently knocked it out of alignment, it has free movement on a pivot and spring but when the printer uses it, it pushes on the mechanism to grip the paper and the roller at the bottom freeds it though, sometimes using to thick paper can do the samething. you would need to open up the device and locate the mechanisms, and make sure there is noting in the way of the controller's, i've seen a tiny piece of silver rapper make the same problem.
Jul 02, 2017 | HP Officejet Pro L7780 All-In-One InkJet...
180 people viewed this question
Seeker5211
Seeker5211
