Question about Compaq Presario C762NR Notebook
Computer problem with red screen - Compaq Presario C762NR Notebook
  • 52 more comments
  • max carson
    max carson Oct 31, 2012
    need more info
  • Treadstone Oct 31, 2012
    Sorry max - new to his site and didn't realize I was posting a question. So the problem remains that my computer is slow. One guy suggested I download Advanced Systems Care and C Cleaner - I did that. It seemed to help, but then it started to slow down again. There are long pauses before it loads a page or it will freeze for about 30 seconds before moving on. So i downloaded Smart Defrag and it seems to help in that when i go to a webpage, while it takes about 10 or so seconds to get there, it will actually pop up the site's page rather quickly - so in that sense, its changed. The other problem I have is this red screen. If I hibernate my computer or log off and then log on later, my screen goes red and shows the word COMPAQ and then on next 'page' it'll say "windows resuming" with a black hole in the middle of the red screen. But the black hole is marbled with red lines. So i'm at a loss ...can you help?
    Oh and i tired the F10 BIOS for hard drive scan and it turned my computer off because it got too hot. So it never finished the scan..
  • joecoolvette
    joecoolvette Oct 31, 2012
    http://h10025.www1.hp.com/ewfrf/wc/produ... 1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the Left side of the laptop.http://en.wikipedia.org/wiki/VGA_connect... You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable. 2) Turn the monitor on. If a CRT type allow it to warm up. Turn the laptop on. By factory default the display should show on the external VGA monitor. IF not; there are at least 3 display options available; A) Internal monitor of laptop ONLY. B) Internal monitor of laptop AND external VGA monitor. C) External VGA monitor ONLY. Hold the Fn key down, and at the same time tap Once on the F4 key. (The F4 key is the Display Toggle-Over key) No display on external VGA monitor? Hold the Fn key down again, and tap once more on the F4 key. Post back in a Comment as to what you see. Plus, is it a Compaq Presario C762NR Notebook PC you are referring to?
    yes correct model you are referring to. I will have to review what you said here - I was confused at VGA monitor. Ah, you even provided the wikipedia link. I'll let you know ...
    OK, I thought i had an extra LCD monitor - I don't. Any other way I can do this?
    I logged off and rebooted- no red screen this time. Still need assistance on speeding this up. Please and thank you.
  • max carson
    Shut down your computer, unplug from AC outlet, remove battery, replace battery, plug into AC outlet, re-start. It sounds like when you leave your computer on for a period of time it goes into Hibernation hence the Compaq screen upon waking. I never leave my laptops on when not in use I always shut down, I remove the batteries if I am going to be working at home with a AC outlet.As to the slugish behavior my advice would be run Malwarebytes Anti-Malware http://www.filehippo.com/download_malwar... it's free, do you have a good Anti Virus? If you do run a complete scan, if not try Avast! Free Antivirus http://www.filehippo.com/download_avast_... free. There are many things that make a computer slow, How many Start-UP programs are running, look in Task Manager, to see what is using all your resourses. Your laptop has decent specs it shouldn't be "bogging down". In CCLEANER there is a section, look on the left for "TOOLS" and click on it look for the section "STARTUP, What is starting up that you do not need? If you need assistance let me know I'll be happy to assist. By the way I never use Hibernation.
    OK thanks Max. I will do all you've said here. I downloaded AVAST but will run it through the antimalware. I will no longer leave it on hibernation ...and will get back to you on this...
    Max - a few things: I think I"m going crazy! 1. If i have AVAST, do i still need Windows Security Essentials? 2. Is there a way to deactivate a program that is running without having to uninstall? 3. I have one program that keeps showing an error every time i boot up - its the program called the Norton Internet Security. It says that there is an error because its missing a file - well I want to get rid of the entire thing completely but when I go into programs/features to uninstall, it searches through the files as if its going to install - I can't get rid of it. 4. I've unplugged, done the scan with malware, have the AVAST. I'm still working on uninstalling some things but not sure if it should be uninstalled - any pointers?
  • max carson
    1) we need to remove all anti virus! I think this is what is "bogging you system down" your machine has 3 anti virus on it now.. 1 remove Windows Security Essentials in control panel,( I don't know what OS you are using so I can't tell you what to look for in control panel), 2) remove Norton using a Norton Removal Tool found at:https://www-secure.symantec.com/norton-s... Run and follow instructions, 3) remove AVAST with Avast removal tool foundhttp://www.avast.com/uninstall-utility, run and follow instructions, 4) Did Malwarebytes find anything? let me know one way or the other. 5) Did CCleaner find any junk when you ran the cleaner? if so delete it. 6) did CCleaner find any Registry errors when you ran it? if so delete them. Important: after completeing these steps RE-BOOT TO RE-SET THE COMPUTER REGISTRY. NOW- WE ARE START OVER AND INSTALLING A FRESH COPY OF ANTI VIRUS 1) GO TO :http://www.filehippo.com/download_avast_... DOWNLOAD AND INSTALL AVAST RUN A SCAN. Get back to me when you have completed these steps or have an issue and need assistance.
  • max carson
    You asked," Is there a way to deactivate a program that is running without having to uninstall? YES I WILL SHOW YOU HOW, NEXT. GIVE ME INFO ON RESULTS OF STEPS: MALWAREBYTES SCAN? VIRUS SCAN? CCLEANER SCAN CLEANER? REGISTRY SCAN? NEED INFO TO MY INFORMED SUGGESTIONS.
  • max carson
    If you like I could try to repair you machine using a VPN. If so let me know. It a program I use with all my clients,(i do computer maintenance), you ca find the program at http://www.teamviewer.com/en/download/wi... look for the windows icon and click.Run and install if you wish. let me know.
  • max carson
    Quick question, are your windows and HP/Compaq Updates current? let me know.
    yeah they are current as far as i know..it updates all the time. I had a friend tell me that it could be the problem with my fan? my fan doesn't seem to be working and therefore the overheating and hot hot air?
    will look into this VPN program
  • max carson
    FAN? Do you use your laptop on a table, desk? where? it should not overheat, there will be hot air comming out that's the fan working, blowing over the hot components. NEVER BLOCK THE AIR FLOW BY USING ON A SOFT AREA, LAP, BED etc. HAVE YOU REMOVED ALL THE VIRUS PROGRAMS AS A EARLER DISCRIBED?
  • max carson
    OK - i will follow your instructions Max. My laptop sits on my desk or on this tray with a built in fan. Yes hot air is coming out - i guess it is the fan? I'll remove security essentials and OS? by that do you mean Windows Vista? Because that's what I'm using.
  • max carson
    max carson Nov 01, 2012
    ONLY THE ANTI VIRUS, 1) REMOVE WINDOWS SECURITY ESSENTIALS,2) REMOVE AVAST USING AVAST REMOVAL TOOL,remove AVAST with Avast removal tool foundhttp://www.avast.com/uninstall-utility, run and follow instructions 3) REMOVE NORTON USING NORTON REMOVAL TOOL FOUND HERE:remove Norton using a Norton Removal Tool found at:https://www-secure.symantec.com/norton-s... Run and follow instructions, FINALLY :RE-BOOT TO RE-SET THE COMPUTER REGISTRY. NOW- WE ARE START OVER AND INSTALLING A FRESH COPY OF ANTI VIRUS 1) GO TO :http://www.filehippo.com/download_avast_... DOWNLOAD AND INSTALL AVAST RUN A SCAN. Get back to me when you have completed these steps or have an issue and need assistance.
  • Treadstone Nov 01, 2012
    Max - all three virus products deleted and about to install AVAST...so far so good, do i need to get rid of Windows Defender as well?
  • max carson
    No let windows defender in, your getting there. Once avast is installed,( MAKE SURE TO UNCHECK ANY TOOLBARS IN TEXT) WHEN DOWNLOADING AVAST, WE DO NOT WANT ANY TOOLBARS , that slows your browser down. Also DOWNLOAD MALWAREBYTES AThttp://www.filehippo.com/download_malwar... RUN BOTH, FULL SCAN, IT WILL TAKE SOME TIME , MAYBE HOURS, Depends on the size of your HDD your specs say 160GB . I will monitor this site , you most likely will find errors in both. delete all errors. Then we will add some clean-up programs. to geyou system in "fighting shape " and light on it's feet!
  • max carson
    If you open CCleaner and open "TOOLS" click on "STARTUP" and copy the entire page and right click the blue highlighted area and "Save to text file...", Copy the text file and insert here. Like so: No HKLM:Run Adobe ARM Adobe Systems Incorporated "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
  • max carson
  • max carson
    sorry it will not copy and past all the info?
    OK, I forgot about the toolsl and copying the info to you
  • max carson
    max carson Nov 02, 2012
    I could not get the info from CCleaner, Tools to copy and paste all the info, so it may not work. How did the scan come out?
  • Treadstone Nov 02, 2012
    i just deleted c cleaner and advanced care and currently doing a chkdsk scan C: but when it gets to D: it stalls at 90%. Not sure why that's the case. I want to override it and then install the AVAST and then get back to you
    the malwarebytes showed that i had a virus i think - trojan something. I got it deleted and it should be out now
    oh and I uninstalled the AVG 2012 and it says that it was removed but that i can'not remove it from the programs/features??
    ok nevermind - the AVG is now gone. AVAST installation now
  • max carson
    So you had 4 anti virus, WOW, NO WONDER YOUR COMPUTER WOULD NOT RESPOND, HOW MANY MORE? You will need a AVG REMOVAL TOOL FOUND HERE:http://www.avg.com/us-en/utilities. i HAD AN IDEA YOU HAD VIRUSES AND MALWARE , I DON'T KNOW HOW IT WAS RUNNING AT ALL. NO WONDER IT WAS SO HOY THE CPU WAS RUNNING FULL TILT!
  • max carson
    ALL ANTI VIRUS HAS TO HAVE A REMOVAL TOOL SUPPLIED FROM THE COMPANY. USING THE WINDOWS UNINSTALLER DOES NOT REMOVE IT ALL, THEREFORE IT CONFLICT WITH ANY OTHER ANTI VIRUS ....ONLY ONE ANTI VIRUS TO ONE MACHINE, MALWARE PROGRAMS ARE DIFFERENT, MALWAREBYTES IS ONE OF THE BEST.
  • max carson
    AFTER A ANTI VIRUS OR MALWARE SCAN ARE COMPLETE ALWAYS RE-BOOT TO RE-SET AND CLEAR THE ERROR FROM THE REGISTRY.
  • max carson
    THIS WOULD BE EASER IY YOU E-MAILED ME WITH THE START-UP INFO FROM CCLEANER TO MY ADDRESS: desk.maxcarson@hotmail.com
    i already got a lecture from my friend about being a germaphobe but that it shouldn't carry over into the laptop! LOL . OK. Avast just finished installing. I removed the Norton with the uninstaller from the site you sent me. So all the virus programs i deleted from windows uninstaller is probably not fully removed then? What should i do? I know Norton was done properly through your link. I also uninstalled the AVAST properly. I uninstalled C Cleaner and Advanced Systems Care by Windows installer - should i go to the website for proper uninstall then?
    I'll reinstall C Cleaner - where do i get this start up info?
  • max carson
    have you read the messages i posted? Let me get things straight: 1) you have removed ALL ANTI-VIRUS, except AVAST, with THE REMOVAL TOOLS: NORTON WITH THE REMOVAL TOOL, AVG WITH THE REMOVAL TOOL , WINDOWS SECURITY ESSENTIALS WITH THE WINDOWS UNINSTALLER. IMPORTANT TO REMOVE ALL ANTI-VIRUS, EXCEPT AVAST, WITH THE REMOVAL TOOLS.I PROVIDED THE
  • max carson
    E-mail and attach a copy of start-up in CCLEANER> TOOLS>STARTUP, COPY AND PASTE A E-MAIL TO : desk.maxcarson@hotmail.com
  • max carson
    ii AM HAVING A HARD TIME TRYING TO SEND INFO THROUGH THIS SITE USE MY E-MAIL I DON'T THINK YOU ARE GETTING ALL THE INFO I AM SENDING
  • max carson
  • max carson
  • max carson
    AVG REMOVAL TOOL HERE:http://www.avg.com/us-en/utilities
  • max carson
    ARE YOU IN THE U.S? IF SO, WHAT STATE?
    canada
  • max carson
    IN THE IMMORTAL WORDS OF PINK FLOYD: "IS THERE ANYBODY OUT THERE"?
  • max carson
    CANADA, THE GREAT WHITE NORTH! I'M IN SOUTH FLORIDA.
  • max carson
    ANY UPDATE ON THE LAPTOP, WHAT'S GOING ON?
    Florida! I need to come for a visit one day! OK just finished doing full scan with AVAST...now going to do the malware site
    the AVG removal - i should go get the AVG removall even if i already uninstalled from control panel area? it will still work?
    ok, i'm going to email you now...while i wait for malware
  • max carson
    Yes, If you have not run the AVG removal tool all of the AVG has not been removed.
    how do i know which one to download for AVG remover...32 bit or 64? how do i find out?
    oh figured it out
  • Compaq Master
  • 7,627 Answers
Shut down your computer, unplug from AC outlet, remove battery, replace battery, plug into AC outlet, re-start. It sounds like when you leave your computer on for a period of time it goes into Hibernation hence the Compaq screen upon waking. I never leave my laptops on when not in use I always shut down, I remove the batteries if I am going to be working at home with a AC outlet.As to the slugish behavior my advice would be run Malwarebytes Anti-Malware (http://www.filehippo.com/download_malwarebytes_anti_malware/) it's free, do you have a good Anti Virus? If you do run a complete scan, if not try Avast! Free Antivirus (http://www.filehippo.com/download_avast_antivirus/) free. There are many things that make a computer slow, How many Start-UP programs are running, look in Task Manager, to see what is using all your resourses. Your laptop has decent specs it shouldn't be "bogging down". In CCLEANER there is a section, look on the left for "TOOLS" and click on it look for the section "STARTUP, What is starting up that you do not need? If you need assistance let me know I'll be happy to assist. By the way I never use Hibernation.
Posted on Oct 31, 2012
Testimonial: "Max is fantastic - goes out of his way to assist a person who's quite dumb in the area of computers - Max was not triggered by my stupidity! Ha! Great work and super nice guy too! :)"
Why is my screen red
You placed your problem with wrong category, I assumes. Is it a projection TV or a laptop? If it is a TV; check the site linked here for one color predominant screen faults. If it is a computer, re post your problem by computer category. http://electronicshelponline.blogspot.com/
Jul 04, 2014 | Computers & Internet
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
What is my computer browser and how do i close it.
Your computer browser is the program that you use to connect to the internet. Its called a browser because you use it to "browse" the internet.
Common browsers are programs like Internet Explorer (which is the blue "e" on your desktop) or Mozilla Firefox (which looks like a blue planet wrapped in red flames or wings).
You close a browser by clicking on the red "x" in the upper right hand corner of your screen. If you click on the "-" which is located to the left of the red "x" in the upper right hand corner of your screen while on the internet, this minimizes the browser and puts it on the bottom of your computer screen. You can see which windows are open by looking at the bottom of your computer screen. When windows are minimized, they look like squares and have the name of the page which is open on them displayed for easy reading. To close a browser that is minimized to the bottom of your pc screen, click on it with your mouse and then click on the red "x".
Jul 07, 2011 | Computers & Internet
I have a 24in wide lcd monitor for my computer and
mcdevito75 here, The red power light usually means the monitor is off, if when you press the red button it turns to green, or blue then the red power button means the monitor was off. Your monitor could be burned out.
Jul 16, 2010 | Computers & Internet
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
The screen is covered with red lines
Try logging into BIOS, and check if you still find the red lines, then it will be an issue with the hardware.
(NB to goto BIOS, shut down the computer, keep tapping F10, and then restart the system), that will log you into BIOS)
Dec 18, 2009 | HP Compaq nc8230 Notebook
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Red screen in mysims pc game
Try updating your Video Card Drivers, and restarting your computer.
If that doesn't work, try reinstalling Sims (1 or 2)
Dec 29, 2008 | Video Game Consoles & Games
Color change
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
Oct 13, 2008 | HP Pavilion M703c 17 in.CRT Conventional...
Permanent Red Line Down the left side of the screen
This can't be repaired, the LCD panel is a sealed unit. if you can't live with it then you need a new monitor
Feb 20, 2008 | HP Pavilion F1703 17" LCD Monitor
Compaq Presario C762NR Notebook Logo
140 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
