Question about Banks 2001 Chevy Silverado - Crew cab, long bed, 6.6L Duramax - Big Hoss Bundle
How to change crankshaft sensor on 2001 6.0 chevy
    Problem Solver:
  • 5 Answers
Just mark it the exact way it is pointing make sure you turn the crank so one of the slots are exactly dead centr of the magnetic crank center then take off the sensor and put it back in the same exact location pointing in the **** you lined up with the old one its simple the pain in the **** is the cramped space and small tools you will need thats it you might have to heat and bend or modify one of your tools to get to the tight spot thats all remember dont get confused the circular round plate the sensor points toward has one addition slot more then the # of cylyders you have one is to just to get it to activate it dont worry about that just do as I stated above
Posted on Oct 30, 2012
What is the cam & crank sensor resistance on 2001 chevy metro?
CHECK CONNECTION,CRANKSHAFT SENSOR UNDER CRANKSHAFT PULLEY.DO YOU ANY PROBLEM WITH ENGINE?
Jan 20, 2015 | Cars & Trucks
Location of a crankshaft sensor for a 2001 chev malibu
http://www.chevymalibuforum.com/forums/showthread.php?t=11860
Oct 04, 2014 | 2001 Chevrolet Malibu
How do you replace crankshaft sensors on a 2000 chevy venture
Why would you change a crank sensor
It failed a test?
How was it tested?
No parts get changed just for something to do
Dec 22, 2012 | 2000 Chevrolet Venture
How do I time a 2001 Chevy Blazer ZR2 4.3L? Why is it throwing codes in my 01 Chevy Blazer ZR2 4.3L for crankshaft and camshaft sensors?
was the distributor move, sometimes the rotor in the distributor will move just a hair. turn the motor by hand to tdc and see where the rotor is pointing
Oct 29, 2012 | 2002 Chevrolet Blazer
Crankshaft position sensor location on 5.7 liter V-8 chevy engine
Crankshaft position sensor is in the front of the engine under the harmonic balancer on the right side.
Jul 15, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
Car is stalling
My 2001 chevy impala was stalling at the light or when I was just riding down the road on the highway it would all of a sudden just cut off. I had a mechanic change the crankshaft position sensor and the car have not stalled or shut off since. Hope this helps you and good luck.
S.H.
Florida
Dec 09, 2010 | 2001 Chevrolet Impala
Were is the crankshaft position sensor located on 2001 chevy mali
It mounts in the side of the block near the crankshaft,it fits in a hole,going into the engine block.,look on the inside of the engine compartment ,on the firewall side,left of the pulleys,down low.
Mar 22, 2010 | Chevrolet Malibu Cars & Trucks
Where is the crankshaft sensor located on a 2001 chevy blazer 4.3L v6. The check engine code was crankshaft sensor and cyl #2 misfire.
If you have a distrubutor it is located in the side.Books says you have to turn the crank with a breaker bar to align the slots.Well hope this helps,and good lock.
Mar 14, 2010 | 2000 Chevrolet Blazer
Where is the crank sensor located on a chevy malibu 2001
It should be down near the crankshaft pulley. Remove the the right front wheel and the splash shield, it should be there next to the pulley.
Dec 20, 2009 | 2001 Chevrolet Malibu
Need to change crankshaft position sensor for 2001 elantra
down by your crank shaft pulley you will find a sensor with 2 wires ruining into it and 1 bolt holding the sensor in remove the bolt and twist and pull on the sensor then slide the new sensor in then reinstall bolt and wire
Mar 08, 2009 | 2001 Hyundai Elantra
Banks 2001 Chevy Silverado - Crew cab, long bed, 6.6L Duramax - Big Hoss Bundle Logo
Top Banks Computers & Internet Experts
David Payne
David Payne
Are you a Banks Computer and Internet Expert? Answer questions, earn points and help others
