Question about Samsung HCM4216W 42" Rear Projection Television
Relay keep flicking on and of on HCM4216W
I donrt know where to find the relay can you help me
    Problem Solver:
  • 11 Answers
Follow the AC cord into the board, then look for a black 1" to 1 1/2" black rectangular device wirh four metalic legs. It should be near that. But usually the reason it does this is to protect itself from a short somewhere. Do not bypass the relay are smoke could ensue.
Posted on Jan 04, 2009
Location of fuel pump relay
Search your make and model using google images.
Apr 10, 2016 | Cars & Trucks
I have a motorola droidmverison phone i did a factory hard reset. And no2 i cant log in cause i donrt. Have the old email info How do i by pass log in with nold user account
This is an activation lock through Google. Basically, the device was factory reset, and there was a PIN or SWIPE lock screen and a Google account on the device when it was factory reset.
As a layer of protection and to ensure the phone is not stolen, it is looking for you to enter the Google account that the device was ORIGINALLY set up with. If you know the Gmail login, but need to reset the password, you will not be able to login to the phone for 72 hours AFTER the password reset.
If you do not know the login, there is no way to bypass this screen. You would need to get the Gmail account information from the original owner.
If you have more questions concerning this, here is an in-depth explanation of the security lock. Guide What Is Android 5 1 Anti Theft Device Protection Feature And How Do...
Feb 24, 2016 | Motorola Cell Phones
Having trouble lining up timing marks. got camshafts lined up crankshaft will not come to 12oclock stuck at 11 oclock
the pistons are hitting the valves. your timing is not set correctly. the timing is too involved to tell here, but Subaru timing belts are not set up on TDC. I donrt know what engine you have?http://www.subaru.com/content/downloads/pdf/spt/STi_PERFORMANCE_TIMING_BELT.pdf
Sep 01, 2011 | 1997 Subaru Outback
A/c button flashes and does not cool
it sounds like the magnetic clutch relay is bad...this is a common problem on these models.......the clutch relay is located under the hood in the fuse block right behind the battery.......to check this you can swap the clutch relay out with the horn relay to see if this fixes your problem and 99% sure it will and the relays are right in the same fuse block to make it easy to check.....if this fixes your problem i would go to the dealer and get the new updated relay and put in there and reinstall your horn relay...i hope that this info will help you and if i can help in any other way let me know.....if you could let me and fixya know if i was able to help you and a comment would be appreciated....thanks and good luck and have a blessed day.....
Jul 31, 2011 | 2003 Lexus ES 300
I removed 3 relays from my ford ranger 2001 6 cilinders 3.ol and know idont know what is the fuel pump relay.can you help me how to know what is the fuel pump
they are listed in your owner manual. or go to motorcraft.com, procenter, tech info, owner manual.
fuel pump relay is 46A
4 relays in bottom left corner. it is lower right of the 4.
Dec 27, 2010 | 2001 Ford Ranger Regular Cab
Lights go on and off, my horn goes off, my wipers go on and off.. what can be my prolem?
Possibility: Relays located in the IPM located inside the engine compartment. Front Wiper On/Off Relay. Front Wiper Hi/Low Relay, Horn Relay, and/or Accessory Relay
These Relays may be bad. Switch similiar size and type and check functions.
Let me know if this helped or not or if you need additional help. Good Luck!
Nov 23, 2009 | 2001 Dodge Dakota
Wont take charge, difficult to start
so it doesn't want to come out of the closet and has been dropped ,suffering from depression of an electronic nature. Donrt open it send it for repair to TOMTOM one which will cost, or claim it on household insurance as a dropped item.
the charge circvuit possible has a damaged wire on m/board or a loose pin on board
Jun 20, 2009 | Tomtom ONE GPS Receiver
I need to know correct location for relays as they are mounted above fuses. 98 jetta gls
Hi - I don't know the answer off hand but there is just a chance you could do a Sherlock Holmes job yourself, because many of the relays have unique pin layouts and cannot fit into the wrong place. The numbers may be misleading - on my Sharan some of the relays have numbers which are sideways or upside down when correctly installed! If you find that one relay will go into more than one socket, or more than one relay will go into one socket then you will need further help, but if there is, say, a five pin relay and only one five pin socket, it's got to be right, hasn't it?
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jun 25, 2008 | 1999 Volkswagen Passat
Samsung HCM4216W 42" Rear Projection Television Logo
165 people viewed this question
Henry  Thomas
Henry Thomas
