Question about Garden
I have a 5700 Homelite generator. Started it up and there is a gas leaking out of the air filter. Checked the fuel lines for cracks and they seem to be OK. What next?
  • 7,482 Answers
Hi
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line/s condition...after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Oct 31, 2012
  • jojoridervt
    jojoridervt Oct 31, 2012
    Bud- THANKS for the very detailed instructions and helpful hints (counting the # of turns to remove jet screws, marking opposing parts, etc) Everything that you mentioned makes sense and it will be interesting to see which of your suggestions makes the fix.
JOHN DEER LAWN TRACTOR 22 HP BRIGGS NO START DOESN'T SEEM TO BE GETTING ANY FUEL, HAS NEW PLUS AND NEW GAS FILTER. LOOKING FOR FURTHER ASSISTANCE.
The engine needs 3 things to run: Air, fuel, and a spark. The other things that can fail (and be easily identified or fixed) besides what you replaced are air filters, something in the electrical system (spark plug wire or other components in the electrical including any safety switches or loose wire connections), or cracked or loose fuel line. Easiest one is to check and clean or replace the air filter. For the fuel, check your fuel lines for cracks or leaks. Even a tiny crack in the fuel line may result in the engine pulling in air rather than fuel which definitely will make starting the engine difficult or impossible, For the electrical, other than checking for loose wires or adjusting any interlock safety switches, I would probably take it in for service. Other things that it could be would include a clogged muffler, a dirty or out of adjustment carburetor (I'd let the repair shop diagnose or repair these items), or very old fuel (IMHO, a low odds cause). Not sure it this helps but at one time or another, air filters, loose wires, sticking safety switch,and fuel lines were all problems I have experienced that I have easily checked and repaired. Good luck.
Sep 06, 2014 | John Deere Garden
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Primer does not work
Homelite Tune Up
Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
Bulb will not prime
Homelite Tune Up
Primer bulb wont prime
Most likely cause for this is fuel lines connected wrong or an air leak in one of them. Another scenario is the fuel line decayed inside the fuel tank (check it) and the filter fell off and now the line comes up out of the fuel on occasion. A clogged filter screen in the carburetor under the fuel pump cover causes this too. So...start at the fuel tank...check for cracks in the fuel lines (and in the PRIMER BULB) too, because air is unwanted in the system, but a little is always there.
Aug 11, 2011 | Homelite Mighty Lite Lawn Trimmer
Gas is leaking, I think its the little plastic gasline thats cracked thats attached to the the gas tank itself, if so, where can I find a new replacement gasline to repair it?
All small engine repair shops carry the lines you need and you may even be able to pick up a fuel line "kit" complete with fuel filter and fuel lines at your Home Depot. They carry many parts and accesories for Ryobi and Homelite trimmers.
May 15, 2011 | Homelite Garden
Primer bulb will not take in the fuel in it seems block
A fuel system inspection is needed here. You need to check the intank fuel filter,(make sure its not clogged) the condition of the fuel lines,(soft, not brittle with no tears or cracks) ,the ventin the gas cap,(little rubber tube must allow air in). Foremost, check the condition of the bulb itself:sets in (primer base assembly) that has very small check valves inside it controlling the inflow and outflow of fuel. There cannot be any air leaks as the bulb on the carb and one mounted remotely from the carb depend on a vacuum effect to operate correctly. So some disassembly and acute inspection will be required.
Nov 08, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite string trimmer - gas
put it in the trash and buy yourself a new one nto the same brand.
Aug 09, 2008 | Electrical Supplies
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
