Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Hose is clogged, can't remove hose.
My wife was vacuuming the needles from our Christmas tree and noticed that the cup was not filling up with anything. The hose immediately at the base of the vacuum is completely clogged with needles. Anyway, I can not for the life of me get this hose off to clear it of needles and I've lost my manual. Please, help.
Tanks,
Nate
  • cclovis Jan 12, 2009
    our hose is also clogged. vacuum impossible to take apart to get to clog.
Hello,i have a 2996AVS,i have worked on many vacuums like this,if you look down on the top cover where the wheel height knob is,on the far left & far right side's there is a chrome phillips head screw on each side,remove these two screws,the top cover will lift off,just pull up on the back part of the cover and it will lift off,then you can see where the hose attaches,there is a small slot where the hose clips in,use a small flat head screwdriver or pocket knife and insert it in the slot,there is a raised lip on the hose you can see, slide the driver in the slot right on top of this raised lip and slide the small screw driver in until it is under the slot,this will pry up the slot and you can pull out the hose from there,on the rear of vacuum there is a clear plastic attaching cup that locks the hose to the unit,just squeeze the two clips together and pull and this section will come off,then you can clean out end to end of hose,just line them up and push them back in when your done,then reinstall top cover and tighten screws,also check your belt why you have the cover off,it it ffeel's loose or hardened,or slick and shiny on inside of belt,this will cause thr roller brush to slow down or stop ,hope this helps you. r.man
Posted on Jan 29, 2009
Why won't it suck
Hey there! It's possible that you may still have a clog in your vacuum somewhere. The filters can also cause the vacuum to lose suction. Try these steps to restore suction to your cleaner.
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Rinse the filter under running water until it runs clear. Allow 24 hours to air dry outside of the vacuum.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brushroll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
Jun 20, 2014 | Hoover UH70120 WindTunnel TSeries Rewind...
Jusy shut off while using
Your sweeper may have overheated. I don't know what brand you have but I hope you weren't trying to vacuum pine needles from the Christmas tree. Pine needles are sticky and will clog up any vacuum sweeper. Check your sweeper to make sure the tubes (hose & pipes that carry dirt) are clean and clear. I used to service Oreck vacuum sweepers.
Dec 30, 2013 | Eureka AirSpeed Bagless Zuum
Neither the water or the formula is dispensing.
Either your screen in the bottom of the fill tank is clogged, or the jets that spray are clogged and need to be unscrewed and poke a needle or paperclip through them. If you want to check the hoses, only remove one at a time so they don't get mixed up and blow real hard through them.
Feb 07, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
Low Suction When Using the hoses on the Dyson Animal
there is a washable filter either on the side of the motor or in the dust cup clean it out using water make sure it is dry before reinstalling also check for clogs there are several pices that are removeable the peice under the hose and vent clip? on the side remove and check for clogs
May 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Capture Vacuum
Either the filters are clogged, the hose has a clog in it, or the dirt inlet down by the brush roll is clogged. Pull the hose off and see if you have suction at the end of the hose, that will tell you which way to look for a clog.
Feb 18, 2008 | Eureka Capture Upright Vacuum Vacuum
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction from hose
Take the bottom plate off, the inlet may be clogged. If not then drop something like a big marble down the hose to see if it goes all of the way thru.
Dec 12, 2007 | Dirt Devil M088905 Vision Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
133 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
