Question about Ionic Pro TURBO Air Purifier
Ionic Pro makes weird buzzing noise
I have cleaned my ionic pro multiple times. The "clean" light has never come on. Anywho, It keeps making this buzzing noise and it is really annoying and I want to know how to make it clean my air quietly... Any ideas?
  • 2 more comments
  • Processor Jan 10, 2009
    I have the same problem it makes a crackling hissing type noise will stop for awhile then do it again. Cleaning does not seem to help.
  • graveeja Jan 14, 2009
    Is it a buzzing sound or more like a screetch? I have one and have had it for a year and it does it on and off it makes a sound like the emergency broadcast system thing on TV like its faint but enough to hear and its annoying as heck. Ive cleaned the blades, the charging wire and the contacts at the bottom and still same issue. Ive called CS and they keep giving me the same BS that it needs to be cleaned weekly. Ok if thats the case explain how I can put it through a cleaning on Sunday night only to have this annoying sound return on a Tuesday night after minimal to no operaiton.. anyone else having the same issue?
  • khunnay_nat Jan 26, 2009
    I love the machine because it works very well to clean air. However, I have the same problem with the noise. I just bought this unit for a month now from Walmart. After cleaned it a few times because my husband is a smoker, it starts to making buzzing noise (static noise to me). I listened to it and it sounds like it was from the back of the machine. I cleaned everything (including the string in the back). The first day after I cleaned the string in the back, the buzzing noise had stopped for about 6-7 hours. Now, it comes back again, and it won't stop no matter what I do. I'm now taking it back to Walmart to get a new one. Hopefully the new unit won't give me the same problem again.
  • pelicani Jan 28, 2009
    usually, cleaning gets rid of the sound. But not this time. I'm planning to wait until this afternoon and test again. if it still crackles, I'll take it apart and vacuum out all the dust.
  • 3 Answers
I found that the buzzing can be removed by blowing out the unit, cleaning the blades and taking a long cotton swab and alcohol to thoroughly clean the corona wire - carefully - don't break it. The wire should be clean enough that the slider/wiper runs smoothly up and down the wire after cleaning. If it drags or is rough to slide, you will still have noise no matter how many times you clean the blades. The wire gets a "crust" on it.
Posted on Sep 16, 2009
On my ionic pro, there is a small tab on the right rear that you can pull up to clean the wires inside the tower. It seems like the blades must be inserted for you to pull on it. This solved the buzzing sound. Oh, and if you look closely at the wires in the dark when it is makng the noise, you can see the static charge.
Posted on Dec 04, 2009
  • Kimmy Vee
    Kimmy Vee May 14, 2015
    awesome! totally helped!
  • Jennifer Abbott
    Jennifer Abbott Dec 05, 2017
    Yes, worked immediatley. I ran it, the tab slider, up and down a few times and then replugging it in no more crackling!
I will tell you all what the problem is and how to fix it with 100% certainty. Take the air cleaner outside and lay it on its back. Attach a small cotton or microfiber towel about 5 to 8 inches square to a thin rod. Soak, and I mean SOAK the towel with rubbing alcohol. Then, with your thin rod, push the towel over the three thin wires. Be careful to very lightly drag the towel over the wires so as not to bend or break them. Let the unit dry completely (or help it with a hair dryer). The zapping, buzzing, crackling noise WILL BE GONE. I give you this at no charge, though I am willing to take donations as I am sure this will save many folks BUCCO BUCKS in restored air cleaners! Let me know if it works for you!
Posted on Feb 08, 2012
  • 1 more comment
  • martinmarty Jul 06, 2014
    When I saw "100% certainty" I thought, "Yeah, right..." I've been fighting this noise for years. I used to love the Ionic Breezes and after they were scarce, even on eBay, I got an Ionic Pro. I like them when they worked but eventually they all got to hissing so bad I couldn't stand to have them on, not to mention that they even *sound* unsafe when they're hissing. Your advice about alcohol cleaning the corona wires, plus another person's who said watch it in the dark to see where the arcing/hissing is coming from, enabled me to get my Ionic Pro going again PLUS an Ionic Breeze GP that I haven't used in years. I don't mind spending 1/2 hour cleaning them if they will actually behave for a while. GREAT ADVICE! THANKS!
    Incidentally, on the Ionic Breeze GP, in addition to cleaning the corona wires, I had to clean one more place. There are two rubber coated bars that run vertically between the three plates of the collector. Near the bottom, I could see arcing between these plates and the collector plates. I used the alcohol and microfiber cloth again to thoroughly clean theses plates at the bottom. p.s. Remove the collector grid first, and also on this model there is a plastic shield between the UV bulb and corona wires. This shield is held in place by two small phillips screws. Removing these screws gives much easier access to the corona wires.
  • Linda Stone
    Linda Stone Aug 31, 2016
    THANK YOU!!! This thing has driven me crazy for a long time, I just finished and there is no noise :) :)
Yes after extensive cleaning i pulled the tab, about 30 times to clean it, and have stopped the buzzing...for now.
Posted on Dec 11, 2009
    New Friend:
No alcohol needed. I have two of the Ionic Pro Turbos. They have a push button that causes the metal blades to be exposed for removal and cleaning as the front swings open. They also have something in the back which you are to pull up and push back down to clean the wire if there is buzzing. NOPE! That doesn't work! But, thanks to having a small hand and a new, clean eyeglass cloth (which is lint free, small, light and smooth), I was able to adjust the open door (after removing the blades first) enough to reach in and simply pinch the cloth around the wire, then carefully run the cloth up and down the wire a couple times as the machine laid on top of my bed. (It may move around if you were to do this on a counter.) I could feel a tiny amount of residue on the wire, which came off on the cloth. A very small amount of gray dust came off, but that's all it needed - a small hand, clean eyeglass cloth (fabric, not paper) and carefully wiped. NO alcohol needed! You can plug in and operate the machine immediately.The silence is awesome when the wire is clean!
Posted on May 30, 2017
I can hear these annoying static noises through home theater with 3 12" woofers.... I mean this crackling sound cuts through the loud and keeps annoying. I think this is just the poor brand... I've heard there are some good brands that don't have these issues....
Oh btw... in conjunction with Areca Palm tree you get the purest air ever ^_^ like in forest =))) Areca Palm is a #1 indoor plant that converts Co2 into H2o while some good branded ionic purifier eliminates the pollution ^_^
Posted on Jan 30, 2012
My ionic pro ca500 has the blue light on but also is making a intermittent sizzling sound, I have wiped the blades, the clean light is not on.
What does the blue light mean? I had 4 Ionic breeze air cleaners, ionizer wires are broken. I was thinking about buying the Ionic Pro cleaners, but have no input about how well they work.
Dec 02, 2013 | Ionic Pro CA500 Air Purifier
No matter how much I clean the machine after it is turned on for 10 min or more it starts to buzz and make a static noise, any other suggestions?
The buzzing noise is not from dust in the air purifier, it's from the dust and pollutants in the air, it's now picking up. It should stop once the air is cleaned.
Apr 17, 2011 | Ionic Pro TURBO Air Purifier
My Ionic Pro keeps making a static-y noise when turned on. What is causing it and how can I fix it?
Hi jackieelling,
I work for the Ionic Pro company. Make sure you are also cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Feb 05, 2011 | Ionic Pro TURBO Air Purifier
Why is my machine buzzing even after i clean it
Hi iramsdail990,
I work for the Ionic Pro company. Please make sure you are cleaning the ionizing wire. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Jan 13, 2011 | Ionic Pro TURBO Air Purifier
My ionic pro turbo air purifier keeps buzzing even after I clean it
Hi lsalazar113
I work for the Ionic Pro company. Make sure you are cleaning the ionizing wire too. If that does not help, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 19, 2010 | Ionic Pro TURBO Air Purifier
It buzzes loudly every 2 seconds
Hi johanm65,
I work for the Ionic Pro company. Please make sure you are cleaning the ionizing wire too. If that doesn't work, please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 10, 2010 | Ionic Pro TURBO Air Purifier
Air purifier keeps making a noise even after we cleaned it several times and left it out to dry several hours.
Hi janandvince,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 08, 2010 | Ionic Pro TURBO Air Purifier
Red...cleaninh light..
ame problem. I returned it to the store and they gave me a new one. So Far so good. My little ionic pro now keeps shutting off by itself. Have no idea why.
Jun 07, 2008 | Ionic Pro CA500 Air Purifier
Excessive noise
Oct 26, 2007 | Ionic Pro TURBO Air Purifier
Ionic Pro TURBO Air Purifier Logo
13,251 people viewed this question
Top Ionic Pro Air Purifiers Experts
Paul Cox
Level 1 Expert
Thomas Perkins
Thomas Perkins
Are you an Ionic Pro Air Purifier Expert? Answer questions, earn points and help others
