Question about Refrigerators
Maytag refrig.ice maker - Refrigerators
  • JIM Nov 01, 2012
    Original problem water wont shut off at drink dispenser,so I changed the supply valve water still wont shut off ,then I removed the water filter &blew air through the line,I still cant get the water shut off,same problem,please advise me Thank u!
  • JIM Nov 08, 2012
    I thought that my question had gone to the level 3 experts&I was wondering if theyve gotten a solution?thank u!
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
  • JIM Nov 09, 2012
    MAYTAG MZD2665HES THANK U !
  • Richard Roth
    Richard Roth Nov 09, 2012
    Sorry it took so long for someone to answer you. I just saw your post yesterday. If the water is running without you pressing the switch, then you will need to replace the solenoid on the freezer door. The solenoind is stuck in the open position. Here is the part to order.http://click.linksynergy.com/fs-bin/clic... The part comes with a 365 day, any part, any reason return policy. Keep me posted!
fridgetech
  • 473 Answers
SOURCE: Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Posted on Oct 18, 2007
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
philbran
  • 242 Answers
SOURCE: Water wont fill ice maker
the relay is the ice maker , buy the kit that contains the valve and it is a complete new ice maker system.
easy to find at sears parts.
Phil
Posted on Jun 11, 2009
Sea Breeze
  • 4655 Answers
SOURCE: We have a GE Profile refrig, circa 1995. The ice
If you are sure it is caused by the ice maker or if it is not it can be fixed. The only way an ice maker would leak like that is if ice is blocking the inlet tube and when the water comes on the water is spewed in a different direction than the ice maker. Most times this is caused by a slow leak in the water control valve for the ice maker side at the rear of the refrigerator. You can stop the problem by melting the ice in the fill tube with a hair dryer and keeping an eye on it until you see ice beginning to build up there again. That would indicate a slow leak in the water control valve that is not closing all the way when off. The other reason for large pools of ice in the freezer is a frozen over defrost condensate drain behind the cover in the rear of the freezer and would require you to unplug power and remove the rear panel. I will try to get some photos and a link shortly that covers that problem a lot more in just a few minutes. Sea Breeze
Posted on Aug 20, 2009
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
Ice maker doesn't work
Either the water line to the refrig is clogged or the solenoid that feeds water to the ice maker is not being activated. If latter is case could be that the cam that operates the various operations of icemaker is defective and not signaling the solenoid to let water into the tray.
Mar 11, 2015 | Maytag Refrigerators
No ice, water does not fill ice maker, but water flow is OK.
if Ice maker cycles and you get no water into it you have a clogged/frozen fill tube. If a broken line the water would go on your floor every 15 min. None of those indicates your refrig valve is bad. Dual solenoid water side works Ice doesn't.
Aug 13, 2011 | Maytag MSD2756GES Side by Side...
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice maker does not reject ice cubes. I can see ice cubes in the ic maker bur they do not rotate out to the tray.
The timer is either hung up, or bad. take the cover off the timer front and watch it cycle through. you can make it hurry up if you know where to put the jumper wire. You can probably get a new plug and play ice maker for around 60 bucks. My experience has been if it hung up once, it'll do it again.
Sep 23, 2010 | Maytag Refrigerators
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
My water works on my refrigerator but my ice maker doesn't work.
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , replace the water valve ( the piece the wall water line connects to on the refrig ) . If it freezes and does not dump , replace the ice maker . Also check the rake ( rotating arm ) , to see if a small piece of ice could be blocking it , keeping it from turning . If so , the small cube could be an indication of not enough water going into the ice maker ( replace the water valve ) .
Apr 18, 2010 | Maytag MZD2669KE Side by Side Refrigerator
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag refrig (french door) water and ice on door stopped working at the same time.
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag side by side Refrig. - Ice maker chute door
problem is in dispenser, check switches and or selenoid.
Jan 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
