I need to remove a lock off my new Asus laptop it's on the hard drive I have been told that its hard to crack as when laptop is turned on it goes straight to password before anything
  • Computers & ... Master
  • 14,384 Answers
Go to control panel,find user accounts and you can make changes from there.
Posted on Oct 30, 2012
Let me know if it helped tou
ArmyMason
  • 121 Answers
SOURCE: remove hard drive in compaq presario laptop f572us
Please see link for Detailed instructions. Its simple as unscrewing a few screws and sliding out the hard drive.
Posted on Apr 01, 2009
  • 338 Answers
SOURCE: Master Password for 2.5'' Hitachi laptop HDD
if locked while booting up, before even windows is loading: you've got a master password in BIOS to worry about.No way but to ask the manufacturer to remove it.
if you cannot access windows anymore after booting up:
boot up from a win cd, go through setup,
install a new copy of windows and try to find your personal files on the disk, back them up and reboot from a win cd again, this time format the whole harddisk and set up a clean, new installlation of windows.(warning: all beforehand data will permanently lost then)
good luck
Posted on Aug 04, 2009
vpaaf
  • 115 Answers
SOURCE: i have a seagte momentus hard drive, need master password
you will haveto ask seagate forthat information
Posted on Oct 09, 2009
SOURCE: bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Posted on Aug 09, 2010
  • 14 Answers
SOURCE: forgot asus laptop password Windows vista
To reset your ASUS laptop Windows login password, I think you can try this password recovery software, fully compatible with Windows 7, Vista and XP etc operation system, supporting both 32-bit and 64-bit. You can do it on your own, no need to send it to a computer shop. Regards.
Posted on Nov 17, 2011
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
Hard disk locked
Remove the hard drive and test the laptop using other hard drive. If it is locked again, then your computer has a problem.
Mar 06, 2014 | ASUS Computers & Internet
Asus eee pc 900ha master password hard drive locked
an actual hard drive lock? Those are a bummer, a new harddrive is the only real way.. not even tech support can help with this, I've been down that road, It sucks. the only real way to fix an actual harddrive lock is to remove a chip from the harddrive and solder a new one one. that being said, i had to replace with a new one. with that sector of the HDD locked, not even booting into a bootable CD(like linux) will help, the harddrive will not be dectable.
Oct 29, 2013 | Computers & Internet
Asus laptop won't wake up
please provide what model this is, different series has different solutions.
Mar 26, 2013 | ASUS 15.6" Laptop - 4GB Memory - 500GB...
I have replaced the hard drive in an asus x5dij laptop and it still doesn't work
If this is a brand new hard drive then you need to install Windows on this hard disk with the ASUS drivers for your model laptop plus your programs to get a working laptop.
Jul 08, 2012 | Computers & Internet
Purchased on Ebay an Asus which has a locked HD. I have booted it to USB stick with Knoppix. It has a 160Gb locked Western Digital drive. Is this a bios problem? Is it a HD firm ware problem. I'm not...
You have to erase the motherboard memory. However this is extremely difficult. Even if you esase the cmos memory and put in a whole new hard drive, the lock may still be there. Your best bet is to contact the seller to see if they will give you the password. If they dont want to help you then you should leave a negative feedback on their account.
Mar 21, 2011 | Computers & Internet
How to install a new hard drive
Hi geaniel, to install the Hard drive, follow these steps:
Turn off the pc
remove the cables and battery
unscrew the screws located at the corners of your laptop
then remove the hard drive by pressing a latch on it.
Then insert the new hard drive and lock it by pressing the latch
lock the screws on the back part cover of your laptop
reinsert the battery and the cables on the pc
Turn on the pc... Hope this works...
May 20, 2010 | Acer Aspire 4720 Notebook
When I turned it on, it goes to the screen that has start windows
sounds like your boot record on hard drive is bad or hard drive turn on computer and hit like f10 or f12 it will tell you right after asus screen what key to hit for restore, if this doesn,t work hard drive is bad. hope this was helpful
Apr 15, 2010 | ASUS Eee PC 1000H Laptop
Asus dvd/cd player/burner packed up and needs replacing with new
have not fixed it but now trying locally to solve this problem
Oct 01, 2009 | ASUS Computers & Internet
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
