Hi can you please tell me where the lead with the yellow plug that is hanging from the top of the back panel where the switches are plugs in on the board.. There are 3 choices it ether goes into the r
  • yadayada
    yadayada Oct 30, 2012
    What is this?
    Problem Solver:
  • 19 Answers
It goes to the red.
Posted on Oct 31, 2012
2 Suggested Answers
  • 10 Answers
SOURCE: when i plug in the lead with 3 colours
S video is a 4 pin lead that supplies vision only. Because the cable is new doesn't mean it works. I would take the cable and camcorder back let the shop try to get it working or issue you a replacement especially if still covered by the guarantee.
To check the cable is a simple process involving the use of a multimeter. You are checking to make sure the leads have a resistance.
Posted on Mar 03, 2010
I just purchased this tv and would like to hook my roku to it but there is NO YELLOW COLORED PLUG IN on the back of the tv (all the other colors are there except yellow. Can I not use my roku now??
the yellow phono lead carries a composite video signal between devices, look to do the data transfer with a different interface such as scart HDMI, DVI etc'
Dec 29, 2015 | Televison & Video
AUDIO LEADS
There should be one audio cable, Green.
goes into one of the green plugs behind the computer.
Oct 31, 2008 | Medion MD 7317 17" Flat Panel LCD Monitor
Fiat punto 2005 spark plug change
Hi Gerard, on a 1.28v Punto the plugs are on the back of the cylinder head tucked between the 4 inlet manifolds. The plug closest to the timing belt end (just next to the oil dipstick) is easy to find, the others are a bit obscured by the plastic housing that sheaths the injector wiring. Be careful pulling off the suppressor caps, they hang on quite tight so best use long nose pliers and NOT pull on the HT lead. Hope that helps. Andy
Apr 15, 2014 | 2005 Fiat Punto 1.2
I have a Marshall channel/dfx footswitch. The jack plug has been chopped off leaving me with a red, blue and yellow wire. Can you tell me where each one is soldered to on a replacement stereo jack plug?...
NEVER trust colors... with an ohmmeter you can tell which is the common lead by testing... find the lead that has continuity to EITHER switch independently... It is PROBABLY the blue one... this will be the "sleeve" of the plug. The schematic documentation is so bad the jack wiring cannot be decipered as to which contact is the tip and the ring. HOWEVER once you find the common of the switches and connect it to the sleeve you have only two choices for the other wires so just try them.
You can also take the back off the pedal to find which color goes to BOTH the switches... connect that one to the sleeve. Try the other two wires for proper operation before final soldering.
Apr 11, 2011 | Marshall Amplification Marshall Footswitch...
Okay, so i plugged my xbox in and then i plug it into the tv, but no picture pops up at all, it says check cable signal, but i don't know what cable, and i tried hooking it up in the 1 component(under the...
what colour are the plugs on the lead you are using, if you have a component lead it will have a green a red and a blue plug if its composite you will have a red white and yellow plug
Mar 12, 2011 | Televison & Video
My xbox 360 has 4 flashing red rings
hi, 4 flashing red lights is telling you their is a problem with the video lead, try switching the xbox off and unplug all the leads from back of xbox and also back of telly, then plug them back into the xbox making sure you push them in far enough, doing this removes static and should solve the problem, then plug it into the tv and give it a try.
if after doing the above it still dont work then the next thing to do would be to try a neighbours or a friends video lead just to make sure the problem is with the lead and not the hana chip inside the xbox,
you should find another lead will solve your problem if unplugging them doesnt fix it in the first place.
let me know how you get on or if you need further assistance ok
please rate this solution and leave a testimonial please as most users dont leave a rating or response, thanks
Dec 12, 2010 | Video Game Consoles & Games
Won't agitate on any cycle
under the top cover but mounted to top cover find your two leads and trace back to control panel and jumper the leads to bypass switch and this will tell you either switch is good or bad!
Sep 13, 2009 | Kenmore 24032\24036 Top Load Washer
On/off switch
Usually the power on button only has two wires. Then you have HDD led leads, reset leads, power led leads etc. These are all separate wires that fit onto separate pins in the Jpanel1 (front panel header).
Could be that the really old emachines grouped all these wires and made them into a plug to fit their own style motherboards.
If this is the case then that connector would not be on your newer motherboard, and it would have that Jpanel1 instead.
Hope this helps as I'm not very familiar with the old emachines.
Hank
Jul 08, 2009 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
