Ge top waher leaking on the bottom - Washing Machines
  • abeygold Nov 01, 2012
    i already replaced the center seal but still leaking on the floor from the nut that holds the flywheel .but can't pin point the leak
    its not the discharge hose .icould see dribble from the nut that holds the flywheel
Soundalike it can be the discharge hose. I just did mine. Usually from move n alot or. Vibrations Or it can be a hookup. If you are able turn you washer on make sure it's empty. As its filling. Lift up the front and tilt back. You're gonna b looking at the thick black hose that runs from you're pump all the way up the inside of your washer. Out the back.
Posted on Nov 01, 2012
3 Suggested Answers
  • 1028 Answers
SOURCE: waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Posted on Sep 11, 2008
hiltonjug
  • 612 Answers
SOURCE: GE washing machine leaks at bottom
If this machine has a place to put pour fabric softener in that's sits under the lid on the cabinet? If so, the hose that allows the softener drain into the tub is either leaking or is disconnected.
Please rate this solution if helpful
Posted on Aug 21, 2009
My ge waher wont spin or rinse model number wwre5240d1ww
Check the water valve screens in the water valve. Remove and clean
Jan 11, 2014 | GE WBSR3140DW Top Load Washer
Waher leaks water on floor
Where is it leaking from? Back or bottom. Hose might not be connected right on back if it's from the bottom, check hose that connects from bottom of basin to pump. May have come off and needs to be put back on and tightened back up.
Feb 22, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My waher is not draining, what will I do?
I found a shoestring in one of these:
Pretty easy to take apart and clean out.
Remove the front panel to get to it
I have a video and service manual HERE
Jan 31, 2011 | GE WBSR3140DW Top Load Washer
I have a GE Top Poad WasherWJRE5550H1WW that intermittantly leaks
There seems to be an overflow drain from the top of the tub to the bottom (inside the cabinet). I don't know why this was designed to dump water onto your floor.
May 13, 2010 | GE Washing Machines
Waher
quite possiblethat the tub itself is sitting to far foward, this machine fills from the back section above the tub, very possible as it fills its deflecting off the tub cover and unto the floor
Nov 26, 2008 | Washing Machines
Waher
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Leaking from the front
take a butter knife and release the two clips on the top of the front panel (look in the seem between the top and front panel and push the butter knife directly into the clips), this will release the front panel from the machine. then you can see where the water is coming from.
May 14, 2008 | GE WHRE5260E Top Load Washer
Amana model TAA500L1 washing machine repair
you have the seals out of the washer. with washing farm clothes and the sand and grit sitting on the bottom of the machine right on top of the seal and bearing they went bad. i suggest that you by a whirlpool washer there seals are up higher then any other machine. amana, maytag ge are not good for farm wahers sorry to inform you.
Feb 15, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
