Question about Frigidaire FGF378AC Gas Kitchen Range
Rebuilding old wolf stove
I would like to put in ignitors for the range top and oven
  • 93 Answers
It is possible but you have to know how, top burners will be easier to do then oven, for top burner you will needed push button switch, spark module and electrodes. I never done the oven but it is possible. Have fun.
Posted on Mar 02, 2010
Why is my Wolf oven apparently getting no power? Stove top lights but oven won't light and no power to panel.
Not sure about your make , but if 1 half of the unit works ( The top elements in your case) and the oven doesnt, I would suggest that there may be 2 fuses in your meter box ( If the oven is wired across 2 phases) or there may be 2 fuses in the back of the oven and the fuse that protects the oven has failed. If unsure, be safe and get an Electrician or a stove technician to sort it out for you.
Sep 28, 2015 | Wolf Range Kitchen Ranges
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Stove top and broiler work Oven won't heat
the way to check this is to first see if ignitor comes on or put an amp clamp meter on it. the ignitor needs to draw 2.8 amps or more to engage the gas valve. if it doesnt lite or draw any amps at all. check voltage to bake ignitor. it will be the ignitor most likely. but the gas valve or control could be bad.
Aug 04, 2010 | Amana AGR5835QD Gas Kitchen Range
Wolf 4 burner stove developed a non stop ignitor clicking
If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Non stop ignitor clicking
The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
233 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
