Tub gets off balance and makes noise while washing.
I make sure that the load is balanced, the machine is level. When the wash starts going the barrel gets off set to the right (always) and it makes a grinding type of noise. When I open the lid and center the barrel it stops making the noise. It has to be re-centered after spin cycle. Any help would be greatly appriciated.
Grish
IT IS A MAYTAG TOP LOAD WASHER - HAVBB-1
  • kiddyaco Mar 19, 2009
    We tried putting more towels but they just roll up in a ball and the spin cycle turns on and off and will not work. We put a little load in and they still roll up in a ball and cycles on and off.We put in a real small load and it works some of the time. But our reason for getting the big Model WBVH5200J2WW washer was so we could wash big loads and this is not happening. We think that the washer should spin faster at the start of the spin cycle so that the load can't roll up in a ball like the washers at the laundry.
It probably does this because you have overloaded the machine with towels or bedding try putting less in...
Posted on Jan 03, 2009
Wirlpool wtw4800xq washer frequent out of balance
Check the spring rods on each corner make sure not broken or came off pull basket make sure nothing in between silly question is it level also check the balance ring to make sure it is not loose
Feb 17, 2015 | Whirlpool WTW4800XQ Top Load Washer...
Drum fallen to one side
I don't know which model you have, but there are plastic suspension pads that hold the tub level, if one of those wears out the tub will tilt. This can happen when you get a heavy load out of balance.
Jun 01, 2014 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washing machine makes a loud thumping noise when it goes on a high spin cycle, especially when the load is large. The problem started to become worse once I reconected a shock that was not connected...
The biggest problem with front loaders is leveling. Be sure it is sitting level. Use a lever and not your eye to level the machine. Be sure to use the lock nuts on the leveling legs. Also, these machines are very heavy and need to be on a really solid hard surface. Hope this does it for you.
Good Luck
Mar 12, 2011 | Kenmore Elite 45986 Front Load Washer
Everytime i put a load of clothes in its fine until it hits the 12 min mark and it starts to wabble everywhere and then the ul code comes on
Try making sure the machine is level front to back and side to side. It sounds like the barrel ( tub ) inside the machine is out of balance.
Hope this was helpful.
Good Luck
cookEmonster
Oct 13, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Washer spins than it gets off balance and shuts
Hi, Washing machines can become unbalanced when the wash load has too much weight in one area of the basket. A machine in good working order can handle most problems through its balancing mechanisms. However, when washing heavy single items such as comforters, the machine's tub can become so lopsided that it damages the washer.
Washing machines that get unbalanced can shake, make banging noises, and even more across the floor. When machines are secured in one place, they can vibrate and bang so much the entire house shakes and things fall off shelves. This is not good for the washer. Bolts can come loose, and parts can break.
When washing heavy items such as pillows or down coats, stay near the washer so you can correct any balance problems as they occur. Some washers have an automatic shut-off feature when they become too far off-balance. If yours does not, stop the spin cycle, open the lid, and redistribute the load. If this is a continuing problem, you may want to wash heavy items at a coin-operated laundry in a heavy-duty machine.
Take care
Jul 14, 2010 | Whirlpool Washing Machines
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
Washing Machines Logo
269 people viewed this question
Top Washing Machines Experts
