Question about Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl
My garbage disposal will not start from a dead stop.
I can "kick start" it with a broom handle, and it will run fine. If I turn it off and let it come to a complete stop, it will not start back up again, only hum. The flywheel turns fine and seems free of any obstructions when it is off.
  • 5,089 Answers
The motor start winding has gone bad, or capacitor burned out.
Generally disposals are replaced when motor goes bad.
Mostly because the disposal is sealed unit and cannot be easily disassembled.
If you have local motor-repair guy, who has disposal bearing parts, and can get the disposal apart, then repair might be possible... but the bearing seal would be hard to replace.
Copy following link for replacing garbage disposal with tips from when I did apartment maintenance.
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html
Posted on Oct 31, 2012
SOURCE: Clogged Sink, Disposal On Takes Water Down, Off, Spurts Back Up
I have had a similar problem with a clogged sink and a functioning garbage disposal. I tried the liquid drain cleaner and had no success. Instead, my father-in-law used a plunger on the sink side. He had the clog undone in about 1 minute. Sink has worked fine ever since.
Posted on Jan 03, 2010
tbirdfan1
  • 3051 Answers
SOURCE: stopped up garbage disposal
Hello there:
you will need to make sure that all of the hoses from the unit are free of debris first ok
than if you need to remove the blade assembly and clean out the area around the unit and than reassemble the blades and see what happnes ok if not you will need to remove the entire unit and see what is making the unit malfunction. ok
best regards michael
Posted on Aug 27, 2009
KMusselmann
  • 247 Answers
SOURCE: Garbage disposal doesn't empty
To me it sounds like the waste pipe is clogged
Try a plunger
Kurt
Posted on Mar 19, 2009
freetek
  • 5568 Answers
SOURCE: Garbage disposal needs to be cleared manually?
In most units, there is a 'splash shield' that is held in place by friction only that can be easily removed. This creates the extra space (for my hand at least) to reach down into the unit to clear any hard objects. If you have pebbles in the basket of the unit, you should be able to remove them by hand without further disassembly. If you find nothing to remove, then the noise comes from elsewhere (bearing, blades) since anything that has managed to get out of the basket, won't make noise any more.
Posted on Feb 17, 2010
  • 12 Answers
SOURCE: sink garbage disposal not working! when I switch
Do you hear a humming sound when you turn it on? If so, you have a clogged disposal. Check on the bottom for the allen wrench location recessed in the middle of the disposal. Insert the proper size allen wrench and you'll be able to rotate the motor back and forth (sometimes difficult at first) and eventually loosen the clog and free up the motor. If you're able to move the shaft/motor easily in the beginning and it still doesn't work you may have a defective disposal. If you want to check more thoroughly you'll need to check to see if you have power at the disposal when you turn on the switch. Use a electrical tester that you can buy at any home improvement store to see if you have power at the disposal. If so, and the motor turns easily when you use your allen wrench, you have a defective disposal and it needs replacement.
Posted on Oct 04, 2010
Garbage Disposal STOPPED WORKING
there is a tiny reset button on the very bottom of the disposal. get a flashlight and a pencil or something. look under cabinet on the very bottom of the unit will be a small reset button. push to reset. if it keeps tripping the button and shutting off. use a broom handle. not your hand, to stick down the disposal drain and jar the blades loose. after that. run full blast with water. turn on disposal. while its running, flush ice, or orange peels down the disposal to clean... the ice will scrub it all and orange peels will clean and deodorize.
Mar 18, 2012 | Plumbing
How to reset ace garbage disposal
it has a reset button on the side of disposal. if it is kicking the line off then use a wooden broom handle put it in the disposal and turn to unjam the unit
Nov 06, 2011 | Ace Hardware Plumbing
Garbage disposer model GFC520F silently hums but not spinning
Hi! It sounds like one of your blades is jammed on something. Easy to fix! Make sure the garbage disposer is switched off (not necessary to unplug). Any large wooden handle tool (not a wooden spoon or plastic broom-they snap..1 to 1 1/2 inch diameter) axe handle, wooden broom ect., put the handle into the bottom garbage disposer on an angle. get nthe handle against the bottom and side where they come together. With gentle pressure, rotate the wooden handle until you feel it stop. This will be a blade..there are usually 2 at opposite sides inside there. Push against it till you feel it break loose in a clockwise direction. Once forced loose it should run again. Whatever jammed it will still be in there so you can to grind it up but it's advised to look with a flashlight and locate and remove the object. FYI...if your disposer is ever non-responsive, there is a red button either on the bottom or back of the disposer. This is a re-set button. Good to know. Let me know if you still have problems. Hope this fixes it for you!
Sep 05, 2011 | Vacuums
Disposal made loud grinding sound, immediately turned off. Could not find anything jammed in disposal. But now it just makes a humming sound
There is something binding up the garbage disposal. Make sure the power switch is off and trip the breaker for that circuit too! Use a broom handle, plunger handle or something similar and use it to try and turn the inside of the disposal. By prying between the sink opening and any raised surface on the bottom of the inside of the disposal with the broom handle you may be able to break it free. This sometimes takes considerable force so be careful not to smack yourself if the broom handle slips. It may take several attempts. Once you can get the disposal to turn, check inside for any debris that may have been forced back into the disposal and remove it before restoring power and testing the disposal is functioning properly. Repeat the process if it begins working normally and suddenly binds up again. There may be additonal debris in the unit.
Aug 20, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My bager 5 seems locked up when you hit the switch it hums how do I get it unlocked.
One day years ago, our new garbage disposal got stuck, and started humming instead of grinding. My mom turned off the switch, then she grabbed a wood-handled broom and stuck it down in the disposal. I was wondering, what's that lady doing.
She took the wood handled broom and placed it on the disposal cutter wheel that was stuck. Then she wedged the broom against the sink opening, She pushed the cutter wheel forward until it was free. Then she showed me that the cutter wheel is supposed to spin freely even when the switch is off.
That's how I learned to un-stick a garbage disposal.
Oct 24, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The reset button seems to be stuck on my badger 5 disposal. how do I fix it
Does your garbage disposal cutter wheel rotate freely
Get a wood stick or broom handle and put it inside garbage disposal
Use broom handle to rotate cutter wheel
If wheel is stuck, wedge broom handle against side of sink opening and use it to push the wheel free
Once wheel is free, try reset again
If wheel rotates freely, try resetting with power off
Turn off circuit breaker to make sure power is really off and switch isn't bad
Try reset again.
If reset will not click in with power off, then there is a short inside disposal, and disposal is bad
One last thing ... the reset may be bad.
You might open wiring cover and see if reset wires are visible and see if you can by-pass reset wires .... but if there is a short, then bypassing reset could be a serious fire or electrocution hazard.
Replacing unit
Insinkerator-brand disposals used to snap into the same sink strainer so all you had to do was disconnect old one and reconnect new one without removing sink strainer. Then buy a can of 'rectoseal' from the plumbing department. Clean off tubular drain pipes and washers. Re-assemble tubular pipe joints and brush gooey rectoseal on the washers when re-assembling so there is no leak.
The badger might have same easy replacement
Oct 17, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposal(1/3 h.p. Badger)not working
sound like the brushes. its cheaper to replace the unit
Jan 16, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
389 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
handygirl911
handygirl911
Are you a Buck Home Expert? Answer questions, earn points and help others
