Question about Tools & Hardware - Others
My hydraulic system on my 22 ton huskee log splitter stoped working
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check oil level first.
Posted on Nov 21, 2012
  • Ken Daly
    Ken Daly Dec 27, 2014
    Checked oil level, still won't work. Heard noise coming from below the motor, then it quit, fully extended.
2 Suggested Answers
  • 1015 Answers
SOURCE: i have a 4052 mcCulloch
Not having a mcCULLOCH manual I dont know what they reccomend,but on mine I just use HI grade industrial/commercial hydraulic fluid. I have been using this for 15 years and have had no trouble. I change oil and filter every year. Thank you.
Posted on Nov 06, 2010
Timber tuff 5 ton eletric log splitter will not move
check/replace the start/run capacitor/s
check that the hydraulic pump is not seized
Oct 26, 2015 | Timber Tuff 5-Ton Electric Log Splitter
My log splitter wont stay running, gas getting to carb and thats as far as it goes. It does start ann runs till primer is empty. The splitter is 2 yrs old. Can you help please?
I suspect that the main jet in the carby is blocked
It could be that the needle in the carby is stuck closed
There could be water in the carby
I would pull the carby and have it overhauled / cleaned out
Oct 03, 2015 | Tools & Hardware - Others
How do I change the seal in a 22 ton Huskee log splitter?
Picture of the cylinder my help, I have had different hydraulic cylinders apart. I don't know which one they put on a Huskee.
Feb 27, 2015 | Cars & Trucks
My 22 ton Huskee log splitter hydraulics quit working, I checked the fluid, that is fine, what next?
Its only a guess but see if its sheared the drive key between the motor and pump.
Dec 27, 2014 | Heavy Machinery
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
What type of oil filter for a Huskee 22 ton log splitter with a 190cc briggs & stratton engine?
Filter #s
Fram 1653A
Napa 1553
Cross 1A9023
Baldwin BT839
Wicks 51553
Kd460, here are some crossover part#s for a replacement filter for your Speeco splitter. To answer your other question, yes hydraulic fluid will pour out when you unscrew the filter. You can drain the entire tank first in to a clean container and then re-use the oil or you can put a container under the filter and then change the filter quickly. The fluid caught by the container can then be poured back in to the unit.
If you have any questions, you can call us here at Speeco@ 800-525-8322
Thanks
Kevin from SpeeCo.
Mar 31, 2013 | Garden
What type of motor oil do I use in my Huskee 22 ton log splitter?
If you are using it mainly at 30 degrees or above I would use straight 30 weight non-detergent oil.If you use it at lower temperatures then I would use 10w-30.That's what I run in mine and it's running great after 16 years. Thank you.
Jul 28, 2011 | Garden
I have a 4052 mcCulloch 4 ton log splitter. What kind of oil does it take for the hydraulics
Nov 06, 2010 | McCulloch 4 Ton Electric Log Splitter #...
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Tools & Hardware - Others Logo
461 people viewed this question
Top Tools & Hardware - Others Experts
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
