Question about Water Heaters
HOW TO CHAGE THE TEMPATRTTING ON HOTPOINTELECTRI HEATR
SET WATER TEMPATURE
  • Water Heaters Master
  • 5,245 Answers
Copy following link for changing temperature on gas-and-electric water heaters:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
Posted on Oct 31, 2012
It says if my ECO has tripped the water tempature has exceeded 200F. What would cause the tempature to reach 200F
Question posted under Rheem tank-type gas water heater.
Model number and gas valve are unknown.
Open following link to see typical ECOs:
http://waterheatertimer.org/images/Intellivent-ECO-900.jpg
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
The ECO will trip at 180-200 degrees F.
This happens when the thermostat fails, then the burner stays on, and the water will continue heating.
With most water heaters, the ECO is one-time use device and the gas control valve is replaced.
Some water heaters have resettable ECO, but the overheating problem has to be solved.
Each water heater is different.
Contact Rheem or read manual for correct procedure.
If you have intellivent gas control valve, open following links for typical service manual:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
More resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater does not seem to be cycling right continues to light then go off and light and go off
might have to change regulator..where control is if water htr lights heats water n then goes off..that the problem should check wtr heatr front for 800 number to see if warranty is still good..because it is expensive to buy
Nov 22, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
How do i adjust the water tempature from the hot taps ?
you don't adjust hot water temp from the taps...
you can only adjust from the water heater.
what water heater do you have?
Aug 14, 2010 | Water Heaters
We can not locate the switch for the hot water heatr in our 2009 Fleetwood Terra LX Morothome, can we get a manual for this unit?
Wall by kitchen counter, or end of kitchen counter, near cabinet or counter on same side of motorhome as water heater, as well as a switch on the monitor panel itself. Some hide them on underside of kitchen cabinets as well.
Jul 12, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Install trim and adjust the thermostat on a Grohe shower faucet
Before you install the temperature control knob, adjust the valve body (47111) with a wrench to set the temperature to "100 degree or close to it". Now, place the limit ring to tdc (top dead center) and control knob with the red 100-degree align to it. Your problem may have been the valve's temperature setting is out range when you installing the temperature control knob.
Jun 28, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
The Thermostat does not reset!!!
Hi jamaica,the reset pops on tank/water tempature. The unit is overheating or the reset/saftey has become defective.Recommend replace thermo.
Mar 31, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I had our 1600ng Bosch water heater installed a month ago during warmer weather. It is not providing very hot showers. I use all hot no cold. how can io get more heat
on the front of the water heater down at the bottom there is a thermostat (usualy a blue knob) turning it clockwise will increase the tempature of your water
(good Luck)
Oct 12, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Crystals Forming On Gas Hot Water Heater
You need a new anode rod in the water heatr. You will probably be looking at a new heater soon.
Feb 15, 2009 | Whirlpool Water Heaters
I have two hot water tanks in an 11 unit building One side of the building has water coming out of the hot water spigots and the other side of the building has no water coming out of the hot spigots. There...
Duissamble the faucet after turning off the shutoff vavev and look for an obstruction. The only shutoff if the tempature gets too high is the pressure/tempature pop off valve which would redrirect the discharge down another path. Go to the waterheater and see if it is coming out from another open pipe from the heater.
Jan 17, 2009 | Water Heaters
Water Heaters Logo
23 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
