Question about Clarke Air Tools & Compressors
Confidence in the integrity of the air receiver.
BEN Broom and Wade air compressor and vertical receiver. I have looked at the general condition of the receiver and it is built to massive proportions. It must be 1/4" plate and is welded with no signs of corrosion or damage. I use it at a max pressure of 90 psi but it has no test certificate and to be honest I feel at least a little uneasy despite its overall condition. I KNOW the answer is to get it cert'd but it means dismantaling a large amount of kit. When I look at other receivers I can't belive this would present an explosion hazard. In your experience of BEN Broom and Wade receivers what do you think? It's probably a 1958! Thanks. K.
  • 70 Answers
The only way to trust this receiver is like you said have it certified these will rust at the welds inside which would be the weak spot. If it was always drained of water and had a filter on intake no telling how long it will last. I have not seen a compressor receiver break off I would expect a small leak first. Hope this helps
Posted on Jan 09, 2009
Where exactly is the switch for the air suspension compressor on a 2006 Buick Lucerne CXL?
The automatic level control (ALC) system maintains a desired rear suspension position under all types of towing, hauling, and loading conditions.
The system uses the electronic suspension control module (ESCM), ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, LR and RR suspension position sensors, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
What switch ? there are sensors at the wheels that control the system .
The system uses the automatic level control module (ALCM) with integral suspension position sensor, ALC relay, ALC compressor assembly, air dryer, air lines, LR and RR shock absorbers with integral air chambers, exhaust valve, driver information center (DIC), and the serial data circuit to perform the system functions.
The
Jul 10, 2016 | Buick Cars & Trucks
How to bypass air conditioning compressor on 2002 ford taurus?
You would need to replace the compressor with an A/C illiminator bracket/pulley, you cannot just put a shorter belt as it would still make contact with the a/c pulley, at least on a 3.0L OHV version.
May 27, 2014 | 2000 Ford Taurus
I have a broom and wade compressor and need head studs
Most NAPA central distribution stores have an extensive selection of bolts. Take one to make sure it's right. The thread per inch is also critical to know. Dorman products also. Fastenal now has many locations (have to buy a box), or Grainger Industrial Supply.
Oct 10, 2012 | Air Tools & Compressors
I have a nc 21814 broom and wade compressor and after information
head studs for my broom and wade i think there 1/2 inch w high tencol
Oct 08, 2012 | Cars & Trucks
Just hooked up a U.S. General vertical 3 1/2 hp compressor and when I turned it on started to pump up the receiver. Between 40 and 50 psi the plastic tubing between the discharge line and the unloader...
Is it failing at the copper/brass fitting going into the tank (the tank check valve)? That area can be 250 degrees F or more during operation. Plastic, in my opinion is not acceptable here. I'd recommend getting some 1/4" OD copper refrigeration tubing and the appropriate compression fittings, and replacing the line.
Mar 14, 2011 | Air Tools & Compressors
Type of oil
Air compressor pumps can use different grades of oil depending on weather conditions and usage, however do not use engine oil. Some Ingersol Rand pumps use a synthetic oil available through WWGrainger on the web. (generally not model specific) If this pump is lightly used you can use the less expensive compressor oil sold at Lowes lumber made by Campbel Hausfeld. It sells for less than $3.00 a bottle. Generally speaking, under normal weather conditions and light duty use, do not worry about the weight of the oil; just make sure that it stays clean and at the right level. If your compressor is running hot, it may be due to other problems like the check valve, head gaskets leaking between cylinders or chambers or high usage. If, however you just want the best oil for your compressor, use the synthetic. It is usually colored blue or green. This oil is special formulation to prevent breakdown in high heat and will not allow carbon for form on parts or inside of the hoses. enjoy
Oct 30, 2008 | Ingersoll Rand Type 30 Reciprocating Air...
Air condition problem
When you say "noisy", is it a metallic grinding noise? Or, did someone overcharge the system. If the compressor IS internally noisy, replacing it is only half of the job. Anytime that comperssors fail, metallic particles get in the system, from the grinding of the compressor vanes or bearings...and need to be removed. Most of the time, they are trapped in a device called the "receiver-dryer", located next to the condenser in the front of the car. So, replace the compressor, replace the receiver-dryer, and evacuate the system. Hold a vacuum for 30 minutes, and then recharge. Not replacing the receiver dryer will damage the new compressor.
Sep 09, 2008 | 1994 Toyota Camry
How do you fix a serpentine belt of air condtioning that is grinding even when air or defrost option is not on?
replace compressor ;remove refrigerant ;accessory belt ;electrical connectors ;suction /discharge refrigerant hose from back of compressor ;bolts from compressor and engine block ;leave bracket attached to compressor
Jun 06, 2008 | Oldsmobile Aurora Cars & Trucks
Air Tools & Compressors Logo
85 people viewed this question
Top Clarke Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Clarke Air Tool and Compressor Expert? Answer questions, earn points and help others
