Question about Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor
Monitor (Dell 1701FP) flickers, flashes and goes black
My Dell 1701FP monitor is acting very weird. After using the monitor for a long time (months) without having any problem occur this suddenly happens: the screen starts to flash and flicker and after doing so for a little while it goes black. If i leave it off for a moment and then restart it it'll do the same thing after a short time and again go black. The strangest thing is that if I leave it and don't use it for a long time, and then later plug it in again, it'll work like a charm again (for, as it seems, a limited period of time). Anyone knows why?
    Problem Solver:
  • 19 Answers
Hello, My name is Richard; I am part of Dells Online Community Outreach group. Solution 1 is good as the inverter may be going out. The inverter lights up the screen for the picture to be displayed, other wise you would only be able to see very dark shadows. In the end it would be a good idea to call our technical support at 1-800-822-8965 and find out if the monitor is still under warrantee. Or you can email me at customer_advocate@dell.com, place attention Richard in the subject line. We can assist you in determining what the issue is and help apply a solution. Regards, Richard
Posted on May 30, 2007
    Genius:
  • 2,985 Answers
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
Posted on May 17, 2007
SOURCE:
How do i test power on a dell flatscreen 1701fp. I have tested the power adapter and it is working and outputting the correct voltage. The monitor itself will not power on, I have disassembled and looked...
Since you cannot power on the monitor with the power switch on the monitor, then it can be the power supply or the logic board, or the inverter has shorted circuits so it makes the power supply go into shutdown mode.
This monitor uses 14vdc 3A power supply, so what you can do is to verify that you do have 14vdc at the DC input jack with monitor in the OFF mode, then try turn on the monitor to see if the 14vdc drops down to lower than 12vdc or so.
The inverter board has fuse also.
I do not have the pictures of the board for this monitor, but if you can post the pictures, then it will help a lot.
Does the inverter board look like this? http://www.badcaps.net/forum/attachment.php?attachmentid=12595&d=1259317517
At this point I will concentrate why the monitor will not turn on first, you can disconnect the ribbon cables attached to the inverter board and see if the monitor will power up.
http://s807.photobucket.com/albums/yy352/budm/DELL/
Aug 10, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
1701FP display problem
Try to do the factory reset. It is on the pop up main menu on the screen by pressing the screen button.
Thank you,
Jan 12, 2008 | Dell UltraSharp 1701FP 17" LCD Monitor
Dell LCD monitor flashes white every second, and then goes black
buy a new one PLEASE, HD monitor works best but the least expensive ones are smaller
Mar 25, 2007 | Dell E173FP 17" LCD Monitor
Power on issue
I had the same thing happen recently.
I wish it was better news but It's a Capacitor that's burning out.
For myself, I just grabbed another monitor from my garage but I did look up the problem first and found video's on how to fix the problem.
It requires some soldering and a little talent along those lines.
I have no doubt I could do it, I just didn't feel like doing it then.
At the bottom of this post is one link to a DIY Fix it vid.
Another option is to find a used monitor.
Of course there are sites like E-Bay or Craig's that you could try but there is a recycle site that people give things away and take things on, called (freecycle).
This is a great site, I've used it in both directions many times with no problems.
NOTE: Use common sense.
I recommend that anytime your going to meet someone from the web you don't know that you take someone with you or at the very least tell someone exactly where you going and any other pertinent info.
Here are the 2 links I mentioned
https://www.freecycle.org/
https://www.youtube.com/watch?v=f3Nr7wAT84I
Dec 03, 2017 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Dell UltraSharp 1701FP 17" Flat Panel LCD Monitor Logo
334 people viewed this question
Clive
Clive
Alun Cox
