Question about Janome Sewing Machines
How to change the needle? - Janome Sewing Machines
  • Janome Master
  • 7,365 Answers
I took my needles out to change them and can't get them back in!
Heather, switch off machine from electric supply.gently lay machine on its back, you will then be able to look at the needle holder .remember the needle has a flat side and this must corispond to the shape where the needle enters into the space for it . be sure you tighten needle into place with the tool provided for the job. Reston machine back onto it's base . Tread up machine and slowly turn by hand the side wheel to make sure the needle is in the right place. When this is working you can refit electric cable as continue sewing. P'S try sewing on a bit of spare fabric to make sure all is well..happy sewing , lois
Aug 20, 2016 | Sewing Machines
How do you change an embellisher needle
Unlike some other machines, you do not need to replace the entire needle shank when a needle breaks. The Embellisher comes with two alan key screwdrivers for changing needles. Insert the larger screwdriver at the red marking to loosen the entire needle shank. Remove the needle shank from the Embellisher and use the smaller screwdriver to loosen and remove the needle(s) you wish to change. Replace with new needle and tighten into position with small screwdriver. Then simply replace the needle shank with the red marking facing the front (towards you).
Dec 08, 2010 | Janome Sewing Machines
The thread on the bottom skips stiches and is coming thru to the top
Here are several solutions to try.
* Re-thread your needle It may be threaded incorrectly (backwards).
* Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly. Usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Change your needle it may be bent, or otherwise damaged. Make sure your needle is appropriate for the type of thread you’re using.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
* Adjust the pressure of your pressure foot as it may be too light for your fabric.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
* Adjust your thread tension as it may be too tight or too loose.
* Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Note: After changing your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps
Dec 29, 2009 | Singer 1725
Skipping stitches and knotting up underneath.
Here are a few things to try.
* Raise your feed dogs if your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot, it may be too light for your fabric.
* If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
Important Note: If you change your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
Hope this helps.
Sep 23, 2009 | Janome Sewing Machines
Whenever I zig zag my machine skips stitches.
Try these solutions.
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
It may be too light for your fabric.
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
stitches.
I hope this helps you.
Sep 15, 2009 | Bernina Activa 130
Sometimes my machine will skip a stitch
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
After changing your needle plate, check to make sure your needle aligns perfectly with this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope this helps.
Sep 12, 2009 | Singer Sewing Machines
QE 440 BSR sewing along fine then skips 2-3 stitches, bobbin seems to not catch the stitch.
* Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens or a universal needle for either. Make sure your needle is appropriate for the type of thread you’re using.
Important Note:
I hope this helps.
Sep 09, 2009 | Bernina Sewing Machines
Sewing Machines Logo
16 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
