Question about HP Photosmart 635 Digital Camera
HP635 CAMERA, SCREEN SHOWES RED AND READS CARD LOCKED. CAMERA WON'T ERASE OR TAKE PHOTOS
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 27, 2010
How can I get my camera to delete photos see below? How can I get back to the main menu on it?
Have you tried replacing the card with a blank one, so there is space for the camera to move images to ?
Jun 04, 2016 | Olympus FE-180 Digital Camera
St76
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Dec 11, 2012 | Samsung St-76 16 Megapixel 16-mp Digital...
Memory card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Dec 11, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Cannon SD1100 IS Digital Camera The Camera reads " Card Locked". The Maual's solution is to slide the switch up on the memory card. Did that still won't work. When I go to the Menu, the...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Feb 25, 2011 | Canon PowerShot SD1100 IS Digital Camera
Both memory cards show "THIS
Are both cards 4GB or larger SDHC cards, and is your camera more than a few years old? There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Dec 29, 2010 | Cameras
I have a brand new PENTAX E70L camera, with SD memory card. i took a few photos on it and then turned it off. Now when i turn the camera on it reads -card requires formatting.I press continue , to format...
Make sure you don't have any pics on the internal memory. To be sure, with no card in the camera, go into the menu and find "format" and follow the on-screen instructions. Then, insert the card and go into the menu and do the format thing again to erase the card and optimize it. Use the menu and not the format option the camera has been giving you.
Sep 28, 2010 | Pentax Cameras
I had deleted the photos then charged the battery. when i turned on the camera to take photos it wouldn't let me shoot and the screen say's Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jul 30, 2010 | Canon PowerShot SD870 IS Digital Camera
When I turn the camera o a red stripe with white
Some cards have a lock tab on them. Make sure it is not in the lock position. If no go then take the card to a photo place and see if they can read it and download your photos. If that does not work then you can reformat the card (you will lose your photos). If you still are experiencing problems, try another card. If that does not work then it's off to the warranty repair or time to get a new camera. Repairs on these are only worth it if they are free or really cheap.
Jun 20, 2009 | Casio Exilim EXZ75 Digital Camera
Camera screen said SD card is locked when I installed an SD card
The SD card has a lever on the side of it. Move it to the other position.That is to prevent accidental erasing.
May 12, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Cannot clear compact flash card.
You say - The screen now reads "card not intialised" and I am unable to take any further photos or format the card. Help???? Which screen? If it is the computer screen- then open the card and delete the folder. If it is the Camera menu simply reformat Did you format in the Computer - you sholud not have doneso. Do a google for a utuluity that will - Unformat and try this- or try card in another camera Otherwise new card.
May 09, 2007 | Fuji FinePix S9500 Zoom Digital Camera
HP Photosmart 635 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
