Question about LG WM-2277HW Front Load Washer
I have a LG front load washer, and a shoe lace got stuck in the little holes on the back. The end of the shoe lace is made of some hard materials and it gets bend, so got stuck in the little hole. I have no idea how I could get it out and it keeps on making noises. I would appreciate if you could let me know how I could get it out. Thanks!
  • 1,543 Answers
Ouch! I'm guessing that the shoe lace wrapped around the shaft from the inner tub and cannot be pulled back into the wash tub. That sucks, because the only way to get at it then would be to remove the motor rotor, sepperate the two halves of the outer tub, allowing the inner tub to be removed to access the offending shoe lace. If you know what you're doing, it's about a two hour job. My advice: Just live with the noise. Please don't bother rating this, as anything but a Fix-Ya drops my score.
Posted on Jan 03, 2009
My WM1832CW front load machine consistently gives me the UE error code during the spin cycle regardless of the contents or size of the load. Its a direct drive system - so what could be the problem?
bad imbalance sensor. silly little contraption that sticks off the back of the drum. It is a plastic lever with a light sensor attached to the end. there is a hole and a bb that sits in the hole. when the load gets imbalanced, the bb gets knocked out of the hole and the light shines through the hole. the light sensor relays the error to the computer and it displays UE. I took the sensor apart, and put a piece of tape over the hole so the light cant shine through anymore. No more UE code. LG parts are very hard to find. I dont mess with them, but it was my neighbors machine. This will get them by until they can buy a new washer. good luck.
Jul 20, 2011 | LG WM-1832C Front Load Washer
How to remove inside door panel
It's usually the window winder that presents the problem . Remove all visable retaining screws ie; Grab handle , Internal door opening lever , Button on top of panel (if applicable ) etc . The majority panel are a pop snap on type . Remove the winder lever withthe aid of a shoe lace or thin piece of cloth material, The winder is retained by a horse-shoe shaped spring clip. .... Pull the shoe-lace/ material in the opposite direction of the winder retainer clip and it will easily come off, but it is a spring clip and may fly off so be careful. Good luck
Apr 10, 2010 | 2004 Mitsubishi Endeavor
How do you remove a back door panel on 03 expedition
Mar 26, 2010 | 2003 Ford Expedition
Take off front door panel
Mar 22, 2010 | 2004 Ford E150
How to get remove the rear door panel
Mar 06, 2010 | 2005 Ford Expedition
How to remove back inside door panel
Jan 25, 2010 | 1995 Ford Explorer
How do remove a ford focus 2005 door panel
Dec 31, 2009 | 2005 Ford Focus
Remove and replace door panels
Oct 15, 2009 | 1991 Ford LTD Crown Victoria
How to stack instructions
I just bought one of these, and the install is pretty simple.
you have 3 pieces, 2 of them go on the sides, 1 goes across the front.
you lay the side pieces on top of the washer so that the little tabe are sticking up,  the end that has 2 tabs and a hole for the screw goes at the back.  once they are laid in place, you put 1 screwn in each piece on the back of the washer (there are holes in the washer for this already) then you put the dryer on to so that the little tabs that stick up kind of hold the feet.
you put the front bar on last so that it's tabs hold onto the front feet, then you screw both ends of the front bar into the side bars.
Mar 18, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Kenmore elite he (5t)
You can wash Shoes in it... But the manufacturer does not recomened it.. I would suggest that you remove the laces and you should be just fine
good luck
May 27, 2008 | Kenmore Elite 45986 Front Load Washer
LG WM-2277HW Front Load Washer Logo
215 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
