Question about Emerson Microwave Ovens
Wear can I get a replacement plate
The plate that the food sits on while being warmed in the oven fell out and broke how can I get a replacement?
  • Emerson Master
  • 9,047 Answers
We need the full model number from the tag on the unit to be able to help you with specific DIY advice.
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Posted on Oct 31, 2012
3 Suggested Answers
SOURCE: Microwave oven coming on but not heating
I had the same problem with my Sharp OTR microwave/convection oven. I had 2 service reps out to look at it (Sears and Lowes) they both said it was the magnatron and would cost about $500.oo to repair it. I called Waverly's Appliance in Paris, TN and it turned out to be a diode. Total cost of repair was $35.00 including service call.
Posted on Jan 09, 2009
localwonder
  • 6784 Answers
SOURCE: My microwave oven is not heating the food
HI, you will need to replace the heating device. This device is called the Magnetron and, it will cost you about $133.00. This is a repairable issue but, you will need to call for service. I do not recommend installing this device if you are not familiar with handling this type of tech.
Posted on Jun 01, 2009
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
Sep 24, 2014 | Kenmore Microwave Ovens
Panasonic inverter microwave combi makes a clunking sound after a few seconds and the plate does not revolve properly, the supplier said it was burnt on food on the spindle but how could food get there, I...
Check the glass plate lines up with the 3 notches on the spindle, if it's not sitting correctly it will clunk, it's just a matter of getting the plate to sit right on the spindle, if still no joy check to see if the spindle is damage or the glass underneath.
Nov 23, 2013 | Microwave Ovens
Glass turntable broken
microwave should work with out the plate as the plate turning the food is for cooking evenly for warming porpuses there should be no problem
Oct 19, 2013 | Panasonic NN-T888S Convection/Microwave...
5 yr old microwave has worked perfectly - until now. Put small amount of food on a safe plate in for 45 seconds. Plate suddenly cracked, was extremely hot - and food wasn't even warmed.
The plate wasn't microwave safe or has a crack in it that had moisture in it to cause it to split.
A new pyrex type glass plate will get it going again.
Mar 08, 2011 | Microwave Ovens
Unit does not heat food. the light and rotating plate work but food is not heating.
It could be a faulty magnetron, which is responsible to warm up the food. If that is the case, then the cost price of that part is quite expensive and you are better off replacing the whole unit rather than spending money on buying the parts.Hope this helps.
Aug 14, 2010 | Samsung MT1066SS Convection/Microwave Oven
Kitchenaid Microwave plate broke (you know the glass one on the bottom of the microwave) can I still use it to cood my food?
yes you can if you have an old plate that will fit on the rollers use that,, the only reson the food go's round is so that it is evenly cooked and thats all, plus it looks flash?
Mar 09, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
MICROWAVE TURNTABLE DOES NOT ROTATE WHEN IT IS TSWITCHED ON.
Make sure your plate is accurately centered onto the brown circle with wheels. And make sure your brown circle has all of it's wheels, and make sure that's centered into the middle piece. If all else fails, it's likely the microwave belt that turns the table has broke off or fell off. You might wanna check the bottom of it, you'll need a screw driver for that.
Also note: Microwaves can still cook food even if the table does not turn, older microwaves didn't have this feature. Good luck and please rate my answer
Oct 12, 2009 | Microwave Ovens
May 30, 2009 | Frigidaire FMV157GM Microwave Oven
Kenmore 1200 watt sparking when warming empty plates
Unless specifically stated in the manual, you shouldn't use the microwave for warming plates. That is not it's intended use.
I suspect the microwave circuit has failed in some manner.
Reply the specific Sears model number (in the form xxx.yyyyyyyy), and I can help further.
Jan 23, 2009 | Kenmore 63252 Microwave Oven
Do not understand the use of the sensor
Dear ggold
I think you refer to the steam sensor. I,ll explain how it works with one of its uses. Say you want to reheat a plate of food. You can do this two ways. You can guess how much time it will take to warm the food, and maybe not heat it enough or overcook it which can ruin some foods. Or you can just press the "reheat" button. The oven will come on at full power and continue to operate until steam begins to rise from the plate. The oven then switches to a "countdown" mode until it determines the food is hot. Saves time and guesswork. Most modern ovens work like this. Since you dont give the make and model of your oven, this is the best I can do.
Ray...
Nov 23, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
