Question about Garden
My mower won't rev and is missing
  • 1 more comment
  • john Oct 30, 2012
    hi paul its a champion with a tecumseh engine hope this helps.
  • john Oct 30, 2012
  • paul marshall Oct 31, 2012
    Most common-; Old ,bad gas; contaminated fuel, water; dirt or corrosion internally. If ethanol/methanol infused fuel it can if potent enough eat/etch carburator. Try spraying in a little starting fluid. If it revs up and runs much better than remove carb and clean/rebuild. It may take a few times to get it clean or the piece of whatever cleared out.Try different carb if available. Most carbs cost as much as a replacement economical mower. Know your limit and move on.
    Problem Solver:
  • 11 Answers
What brand etc. do you have? lots of ideas. anywhere from igniter, coil, wires, to air leak, fuel, carb., valve, rings etc......
Posted on Oct 30, 2012
  • john Nov 01, 2012
    hi paul i cleaned the carb out 2 times and its running like new, many thanks for your help.
2 Suggested Answers
  • 6468 Answers
SOURCE: I have a poulan 42'' cut riding mower that revs up good but as soon as i put the blades down to cut the engine almost drops to an idle & the mower will barely move. Lift up the blade engin
try fresh gas if the gas is fresh clean the carb
Posted on May 03, 2012
Throttle won't go over 3000 rpm and when it gets to 3000 rpm it misses
If it is a lincoln or one of several other vehicles,
it has a rev limiter when in park or neutral
You have no vehicle,engine,year & can't help without
more driveability info & what has been done so far to correct
Do you even work on your own cars
Mar 06, 2013 | Lincoln Town Car Cars & Trucks
96 Taurus. Won't rev over 4000 revs even in park or neutral
That is the rev limiter kicking in at idle.
Oct 02, 2012 | 1996 Ford Taurus
Lawn mower missing with new plug and 10% ethanol gasoline
small engines are not keen on ethanol. Some won't do E85 either.
Try to find straight gas. see if that helps. if your mower is older you may have to set the magneto gap. put a business card between magnet(on flywheel) and the "E" coil. Loosen screws the magnet will pull the coil against the flywheel. Tighten those screws and that's it.
Please get back if problems persist. we want to help.
Aug 31, 2012 | Garden
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
Toro Model 20041 sputters and stalls out; If I cover the primer bulb the engine will rev up and run. Also the mower won't start unless I clean the spark plug. What do I need to do?
Most likely you'll have to remove the bowl nut, under the carb's bowl. You'll most likely find varnish in the jet, or maybe water. These are some typical jets, Tecumseh. Briggs, similar (baymee Lehigh Valley PA, 2009).
Jun 08, 2011 | Toro Personal Pace CARB Walk Power Mower
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
May 18, 2011 | 2005 Kymco Venox 250
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
