Question about Whirlpool Dryers
Whirlpool LER46343Q0 Makes noise like train chugging when revolving
I bought it used serial number MR2934294. Was told it is five years old. If it is older I don't want to rpair it. Buy new one.
  • Whirlpool Master
  • 7,482 Answers
Hi 4luvofdicken
Your problem is the drum rollers are in need of replacement.
It is a fairly simple job and reasonably cheap to repair.
A few hints below.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Bud
Posted on Oct 31, 2012
Testimonial: "Expert advice and clear directions for determining where my problem lies! Rate him EXCELLENT"
  • Suzie Nov 01, 2012
    Thank you so much Bud for your quick response. I only bought this last weekend.... I will follow your instructions and check things out before I get the man who sold it to me over here. I paid almost $200 for an 8 year old dryer. (Originally told it was 5-6 ys old... looked it up model and S/N. It had been painted. Now I even wonder if it was water damaged from Hurricane Irene as he claims he has "suppliers.." LOL all over. I am afraid I was "taken". Had debris and sand in it also. I will do as you said and make him come out here to check it out. He gave a 90 day warranty and if I know what is wrong when he comes I can tell him I checked it out myself. If the rollers are bad he will hear about it.
garing
  • 998 Answers
SOURCE: whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Posted on Aug 27, 2009
JOE LLAMA
  • 26 Answers
SOURCE: LG ELECTRIC DRYER
Henry, its going to be 1 of 2 things. Check inside your drum, see if the vent in the rear has burning or discoloration around it. If it does, it sounds as if your vent is restricted causing the unit to overheat, so clean/fix/replace the venting and your support pulleys will need to be repalce ie flat spots from overheat. If there is no scoarching marks and you know its not the vent or heat issue, the drum seam may have parted causing the thump as every revolution is made.
Posted on Apr 04, 2008
jdhnmi
  • 143 Answers
SOURCE: drum is loose front to back
there is a thimble on the back of the dryer it acts as the bearing it is made out of some kind of fire retardant material see if it is bad .my dryer hit the front face of the dryer and the guide has worn forward there is also a felt pad around half of the bottom on the front of the drum it is pretty tricky to get apart but you can replace every part on the front just way out the cost
Posted on Jan 27, 2010
  • 59 Answers
SOURCE: Have a five year old Amana Gas Dryer Model Number
could be a loose or weak solenoid on the gas valve
Posted on Mar 08, 2011
jdhnmi
  • 143 Answers
SOURCE: My Whirlpool Cabrio just started making a clicking
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Posted on Jun 27, 2011
My new whirlpool fridge..Top freezer..Makes a loud pop/cracking noise. Does not seem to coordinate with when the fridge is done recycling. What can I steer a repairman to look for? Thank you.
Hi Nole, if you are having any concerns with your Refrigerator we would advise you to have an authorized servicer out to view it. Authorized servicers are trained to work on our products and will know what to look for. If you would like to schedule service please email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and model/serial number.
Apr 11, 2017 | Whirlpool Refrigerators
I have a smith & wesson 38 cal. Serial number V10082. Can you give me age and information on this gun.
Have a read of these links
How to Identify/Date a S&W - Northeastshooters.com
www.northeastshooters.com > Forum > Hardware > Firearms
  1. Cached
  2. Similar
Jun 5, 2009 - 10 posts - ‎8 authors Many people have questions about how to identify a S&W revolver and when was it made. ... Sometimes the serial number is here, especially in later models. ... 37 1952 JA 38 Spl 38 Chief Special Airweight .... There is some dispute regarding the dates on some serial numbers and your gun may actually be ...
[PDF]Serialization - NRA National Firearms Museum
www.nramuseum.com/media/940941/serialization-date%20of%20manufacture.pdf
  1. Cached
  2. Similar
serial numbers assigned in chronological order. For. 1927-1944 ...... .38 S&W. 9. 39. 10. 5 .38 Colt. Special. 82. 7. 0. 0 .38 S&W. Special. 25. 0. 2. 0 .38-44. 2. 11.
To IDENTIFY your Gun - Smith & Wesson Forum
smith-wessonforum.com > ... > S&W Revolvers: 1961 to 1980
  1. Cached
  2. Similar
Aug 25, 2013 - ALL Hand Ejectors without Model Numbers should be posted here: S&W ... GIVE us the caliber, but 44 Special or 38 S&W or 38 Special or whatever it is will ... Locate model number S&W 38 Special 13 posts 17 Feb 2012 For new members looking for date of manufacture info ... 50 posts 22 Dec 2011 S&W 38 Special CTG 17 posts 2 Jan 2011 Dating a 5 digit serial number 38 S&W Special CTG? 27 posts 10 Aug 2010 More results from smith-wessonforum.com
Need help with Smith and Wesson Serial number - National Gun Forum
www.nationalgunforum.com > General Discussions > Collectors Corner
  1. Cached
  2. Similar
Apr 26, 2012 - 10 posts - ‎3 authors I have received an old Smith and Wesson 38 special pistal which was passed to ... The serial number is a five digit number on the bottom of the gun ... barrel, if there is a set of numbers there they would be the model, like 10-6 ...
Smith & Wesson .38 Special and .357 Mag Revolvers Guide
www.luckygunner.com/lounge/guide-sw-38-357-revolvers/
  1. Cached
  2. Similar
Mar 4, 2015 - A Guide to Smith & Wesson .38 Special & .357 Magnum Revolvers ... would have done except Smith & Wesson's revolver model numbers have ...
S&W .38 spl. Mod. 60 Serial number history - Smith And Wesson Forums
www.smithandwessonforums.com > ... > S&W Revolvers 1945 to Present
  1. Cached
  2. Similar
Dec 16, 2012 - 10 posts - ‎5 authors Trying to figure out how old my great uncles old .38 is, got it as a gift when ... 1965, the R serial number series for the model 60 started in 1969, and s/n R1152xx shipped in 1974-75. ... s/n series with the Chief Special until 1969, when the R s/n's started. .... smith and wesson model 60 serial number lookup. S&W 38 special snub want to know year or model 10 posts 9 Mar 2013 Help identifying .38 special ctg 8 posts 3 Mar 2013 S&W 38 CTG identification with pics 9 posts 16 Jun 2012 s&w 32-20 ctg serial number lookup. 9 posts 10 Mar 2012 More results from www.smithandwessonforums.com
Smith and Wesson serial number search - Page 6 - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=277680&page=6
  1. Cached
  2. Similar
May 8, 2008 - 25 posts - ‎13 authors Page 6- Smith and Wesson serial number search Handguns: The ... There have been questions brought up before about the accuracy of the J series serial numbers. Jim .... This smith & wesson revolver is a .38 special caliber
Gun Values Board - Re:Smith and Wesson 38 special ctg serial ...
www.gunvaluesboard.com/smith-and-wesson-38-special-ctg-serial-number-16089439...
  1. Cached
  2. Similar
Well, you have not given much information. But it looks like a serial number for a .38 Military & Police Model of 1905, 4th Engineering Change, made in the very ... smith wesson 38 cal Serial number Google Search
Nov 09, 2016 | Sport & Outdoor - Others
Whirlpool Washer WTW4850Q1 makes loud noise during agitation cycle?
http://www.repairclinic.com/Shop-For-Parts/a11b5-x777477343835307131/Wtw4850q1-Whirlpool-Washing-Machine-Parts >Click on repair help written in blue. Its free. Hope this helped.
Jan 05, 2015 | Whirlpool Washing Machines
ANTIQUE REVOLVER NEED ESTIMATED VALUE
Not having a serial number on it makes it worth more to a street gang than it does to a collector. I suggest selling it to any would be violent types for a great profit - and since there is no serial, it can't be traced back to you! (except for here, of course).
Why not just blow someone away yourself? If the company can't trace it, nobody else can either!!
Nov 19, 2013 | Colt Single Action Army Revolver P1658, 38...
Need location of serial number oniver johnson revolver
Hello! Many Iver Johnson and U.S. Revolver Co. revolvers have a visible serial number on the trigger guard, under top strap, or bottom of ****... However except for earliest guns, the real serial number is hidden on the grip strap under left grip panel with a letter prefix to identify the years made....Guru...saailer
Mar 10, 2012 | Boating
Bought second hand machine. works well,however makes noise from underside machine while in operation. and bangs signifigantly when it shuts down. It's a whirlpool unit. unsure of model number. about 3/4...
This sounds like the brake is engaging to stop it from spinning. You can find the model number under the lid at the rear of the lit on the maching. I am assuming this is a top load model.
Jan 04, 2010 | Whirlpool Washing Machines
I have a Whirlpool estate washer...it fills, agitates..but the spin cycle does not work. The timer has been sounding kind of odd the last couple of weeks. Could this be my problem?
i have the same problem with my whirlpool washer. It is five years old! I was told it was the basket drive and transmission that is going. It will cost $275 to fix. Paid $379 for it. What a piece of ****! Will never buy whirlpool again. It was my 1st one. I had always bought GE prior.
Jul 20, 2009 | Whirlpool Washing Machines
Refrigerator makes loud noise when motor is shutting down
Check for dirt, vacume throughly. Visually inspect fan blade, for anything not normal.
Mar 11, 2009 | Refrigerators
Dryers Logo
359 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
