Question about Heath Zenith Halogen Quartz Motion Sensor Light in White (SL5512WH)
How do I change a halogen bulb in a security outside light?
Have put in a replacement bulb but light still not working, It is the same type of bulb but it does not seem to be clicking into place.
2 Suggested Answers
fisherman816
  • 66 Answers
SOURCE: How do I replace the Halogen bulb on the Heath
Unscrew the bulbs counterclockwise with youre finger tips.
Posted on Nov 13, 2009
Replace a headlight bulb in my headlight
The car can have Bi-Xenons or halogens lamps, the bulb would be different. The user manual shows which bulb type to use.
Changing the halogen bulb would be quite easy. On the contrary changing Xenon HID's involves some knowhow and should be done by a dealer, they also need to be replaced in pairs.
25311943-cld1w30nam4pvdfzfn10ykwq-5-0.jpg 25311943-cld1w30nam4pvdfzfn10ykwq-5-2.jpg
Dec 07, 2014 | Mercedes-Benz E-Class Cars & Trucks
How to change headlight 2003the x type Jaguar
look inside owners manual in glove compartment look up bulb replacement in the back index it will show and tell you how to replace headlight bulbs. be sure to wear clean gloves, because headlight bulbs or halogen type bulbs, if oil from hands or skin touch the halogen bulb it will cause halogen light bulb overheat and blow out.you can go by auto parts store when you buy new headlight bulb the salesperson will go out to vechicle and replace headlight bulb for you wont charge you any thing.just charge you for the headlight bulb.
Feb 12, 2012 | 2003 Jaguar X-Type
I have a 2005 chev impala can i replace my high beams headlights with just low beam lights
NO YOU HAVE TO REPLACE HIGH BEAM LIGHT BULBS WITH HIGH BEAM LIGHT BULBS BECAUSE HIGH BEAM LIGHT BULBS AND LOW BEAM LIGHT BULBS TWO DIFFERENT TYPES OF BULBS.WEAR CLEAN LATEX GLOVES HANDLING THE HEADLIGHT BULBS WHICH IS HALOGEN LIGHT BULBS, OIL FROM FINGERS OR HAND WILL CAUSE HALOGEN BULBS TO OVER HEAT BLOW OUT.
Jul 05, 2011 | 2005 Chevrolet Impala
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How to put a head light in
Release the locking ring, then withdraw the halogen bulb from the headlamp assembly
Removal & Installation
This procedure only applies to replaceable halogen headlight bulbs (such as nos. 9004 and 9005); it does not pertain to sealed beam units.
  1. Open the vehicle hood and secure it in an upright position.
  2. Unfasten the locking ring which secures the bulb and socket assembly, then withdraw the assembly rearward.
  3. If necessary, gently pry the socket's retaining clip over the projection on the bulb (use care not to break the clip.) Separate the bulb from its socket.
To install:
  1. Before installing a light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion and dirt.
  2. Line up the replacement headlight bulb with the socket. Firmly push the bulb into the socket until the bulb is seated. If so equipped, make sure the spring clip latches over the bulb's projection.
WARNING Do not touch the glass bulb with your fingers. Oil from your fingers can severely shorten the life of the bulb. If necessary, wipe off any dirt or oil from the bulb with rubbing alcohol before completing installation.
  1. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. (If this is a combination low and high beam bulb, be sure to check both intensities.) If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct if necessary.
  2. Position the headlight bulb assembly and secure it with the locking ring.
  3. Close the vehicle hood.
Apr 23, 2010 | 1998 Ford Windstar
I'm trying to replace my headlights, and cannot figure out how.
If it is like my s60, you need to change the halogen bulb. The bulb assembly is accessible from under the hood. It is held securely in place by three spring clips. Once these clips are removed, you can pull out the assembly, plug in the new halogen bulb and replace the assembly. Be careful not to touch the halogen bulb with your fingers (oils shorten lifespan).
Dec 23, 2008 | Volvo S80 Cars & Trucks
Palm beach 48"
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
May 12, 2008 | Hampton Bay 48 In. Palm Beach in Textured...
Heath Zenith Halogen Quartz Motion Sensor Light in White (SL5512WH) Logo
51 people viewed this question
Top Heath Zenith Home Security Experts
Mike
brian soufane
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
