Question about Onkyo Audio Players & Recorders
Receiver desplay on my onkyo tx-sr 876 receiver keeps flashing and goes of arter it has been on for a while
    Master:
  • 444 Answers
Internal problem with amp, Might have been damaged buy a power (Surge)
Posted on Nov 03, 2012
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
  • 16 Answers
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
  • 24 Answers
SOURCE: bose 901 iwht tx-sr 706
You will need to connect the speakers to the front channels as you would with any normal set(Speaker + to amp +, speaker - to amp -, etc) then you connect the special Bose equalizer through a tape monitor loop and always have the monitor loop engaged.
Posted on Dec 29, 2008
SOURCE: Onkyo AV Receiver TX-SR 805 no display on the receiver
Finally one of us found the solution - thanks to cambrian
Please follow the link
http://www.avsforum.com/avs-vb/showthread.php?t=857502&page=579
BTW: My knowledge of electronics is very limited, but nevertheless I could fix the problem. I hope you can do it too.
Posted on Mar 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: can I connect bose 901
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on most (all?) AV receivers it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Posted on Nov 30, 2009
Onkyo TX-SR 805 flashes message "Test - < - 42" when switched on at power button.
Hello, you seem to be in technician test mode. Unplug the receiver for an hour, turn on and perform a reset by holding vcr/dvr and then on/standby. This should resolve your issue. Thank you, Onkyo USA
Mar 01, 2017 | Onkyo Televison & Video
Onkio receiver TX-SR 505 DISPLAY tube has 3.8 acv ,is off
Your Onkyo has the 3.8 VAC which normaly is correct for normal operation of the display. Make sure you have a SM to help you troubleshoot the problem.
Jan 10, 2015 | Onkyo Tx-Sr505S 7.1 Channel Home Theater...
My Onkyo TX-SR 876 turns right back off within 10 seconds of turning it on. I can see the display panel for about 3-4 seconds then it goes off and the red standby light goes into a blinking mode. Any...
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 27, 2011 | Onkyo TX-SR875 Receiver
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 23, 2010 | Onkyo TX-SR605 Receiver
Onkyo 876 with hdmi from blu-ray sound is fantastic video poor
Get a THX video set up disk (some movies have them on) and read the Onkyo manual for video setup between source and target. I have the BD35 Blu ray and a Panasonc 37" plasma, the pic via the amp was a bit off before the 4 hours of tweaking but now looks fab, after the process tweaks the sound sync needed a bit of work to get it all synched up but it is really worth the effort.
May 19, 2009 | Onkyo TX-SR875 Receiver
Onkyo tx-sr500; power goes out; standby light blinks
Remove all Wires form speakers
Power on
Push Video1 + StandBy /On
appears Clear on display
Dec 22, 2008 | Onkyo TX-SR501 Receiver
Nov 09, 2008 | Onkyo TX-SR605 Receiver
No video through HDMI section of Onkyo TX SR-805 receiver
My has problems with losing video on HDMI, component, or svideo, this is a piece of you know what!
Jul 03, 2008 | Televison & Video
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
52 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
