Question about Watches
Bought the watch last November. Battery died 9 months ago and had to come back to the original watch shop to get it changed. All it's doing now after the brand new battery is blinking Hset and Sub. Al
The watch needs servicing
Posted on Oct 30, 2012
  • 14 Answers
SOURCE: new fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Posted on Dec 05, 2007
  • 203 Answers
SOURCE: How to Change battery Diesel DZ7040
dont do it yourself it will invalidate the warranty bring it back to the shop the should replace the battery free of charge. it might be more than the battery. if this helps please rate. joe
Posted on Nov 22, 2008
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
SOURCE: I just bought my wife a michele csx-36 watch. Its brand
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Posted on Feb 28, 2010
Prc 200 needing battery replaced every week!!! i
Your watch is draining the charge on the battery. It is possible that you have a bad coil or circuit block that is causing the battery to die. An acceptable battery should last you at least 9 months to a year. You need to send your watch in to the manufacturer to have them fix the motor.
Oct 05, 2013 | Tissot Watches
I OWN A FOSSIL WATCH MODEL #ME1044. IT SIMPLY STOPPED WORKING. I BOUGHT IT 8 MONTHS AGO AT ROSS. THE HANDS DO NOT MOVE AND THE WATCH DOESN'T SEEM TO BE STORING ENERGY FROM PHYSICAL MOVEMENT. WHAT DO I...
replace the battery? otherwise send it to fossil. regardless of where you bought it it should have a limited 11-year warranty as as i can tell.
http://www.fossil.com/en_US/shop/customer_care/static/fossil-warrantyRepairs.html
Feb 05, 2011 | Audemars Piguet Watch
I'm from India and I have an Relic (Bought from US) the same model but in silver color. Its been almost two years and it is stopped. Whether battery needs to be changed or anyother problem? If I want to...
Most probably its battery problem. You can go to any reputed (Titan, Timex) watch showroom and get its battery replaced. They will change the battery immediately.
Don't get the battery replaced from the small watch repair shops. They don't have original batteries, so your battery will not last long.
Hope it helps. Don't forget to rate me. Thanks for using FixYa.
Jan 14, 2011 | Relic Goldtone Large Link Goldtone Watch...
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Beep and chime will not work
May 31, 2009 | Timex Watches
Replacement watch batteries
When you buy your watch the manufacture puts in a battery that is made to last 5 years so that the watch can sit on the shelf and not need the battery changed before you have even bought it. Batteries you buy from a store or a watchrepair usually last about 1.5 years. Sometimes you can find a watchmaker who carries the five year batteries, but most people don't want to pay the $25-$30 to have it installed so most places won't carry them for rear they will never sell.I would also tell you NOT to buy your batteries from a grocery store or a Wallgreens type place because those batteries could have been sitting there for months, or even over a year. If you go to a watch repair they go through so many batteries that almost evey time you are getting a fresh battery.
Oct 21, 2008 | Watches
Oct 04, 2008 | Diesel Audio Diesel Watch
Watches Logo
842 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
