How to clean amish heaters
Need to clean the lint and dust from the back of heater and also the high button does not work
I was told my Amish heater only needed taken apart and cleaned to make it work nicely again, So is there any instructions that I can look at while I do this so that I don't mess anything up inside the unit ?
Posted on Dec 30, 2012
The heater works and the flames are fine but it is getting louder all the time and sounds like rocks in a rock tumbler. How do I fix it?
Posted on Dec 17, 2013
  • 4736 Answers
SOURCE: How do you change a light in an Amish surge
To do it correctly you'll need to see a drawing or picture. It's not difficult and the bulb may only be loose. They do that sometimes from vibration.
For more information and a downloadable manual do to:
http://www.heatsurge.com/help/troubleshooting.cfm#poor-light
If the link doesn't work when you click on it, simply copy and paste it into your web browser.
Posted on Jan 28, 2011
  • 4736 Answers
SOURCE: how to change bulb in amish heat surge heater
It's not difficult to change the bulb. But lengthy to explain. If you no longer have your Owners Manual go the link below and click on "Flame does not illuminate properly" More than likely though, the bulb(s) have just come loose.
Posted on Jan 21, 2011
SOURCE: Reddy Heater will not stay lit
Thermocouple it going bad had same problem, you Should replace it.
Posted on Jan 03, 2010
reddyanantha
  • 205 Answers
SOURCE: dimplex storage heaters dead
sir please check the heater connection inside.then check if there are any damages in the control cables.
Posted on Aug 06, 2009
  • 4736 Answers
SOURCE: my amish heat surge heater
Sadly, the only thing that is Amish on your heater is the cabinet mantle. The electric fireplace is made in China. Never-the-less, from what you describe, it appears that the heater coil is not receiving power or it has burned out. If it's not receiving power, one of the resistors that controls the power to heater has gone bad (probably melted). The bulbs being burned out does not affect the heater. You must have had this unit for sometime for the bulbs to burn out. Normally these are LED Bulbs that have a tremendously long life. It may be that the bulbs have vibrated loose and need to be re-tighten.
If I recall correctly, these units were sold with a one year warranty and may have had an option of an extended warranty. If yours is still under that one year warranty, you're in business. If you purchased the extended warranty, that's even better.
In any event, contact their customer service dept @ 1-800-924-7964, as they may able to help you even more.
Posted on Jan 20, 2011
Why does the high limit switch keep tripping
You don't have specifics on the Dryer model. High limit is likely for a temperature being too high, which can lead to damage to the dryer or your clothes, or even to fire.
First and foremost, do NOT work on anything outside of the control panel or drum interior without unplugging the dryer. It almost certainly has a high current, 3-phase power inlet, and you can kill yourself coming into contact with the live power for it. Don't do that!
Most straightforward - look at the vent line. If it's clogged with lint, clean it out, both at the dryer end, and, if possible, for the rest of the line. You'll likely need a flat blade screwdriver to disconnect the vent hose on both the dryer and wall side. Take the vent line outside stretch it out, bang or hand-remove any lint sticking to it. (Stretching will help a lot in getting lint out of squeeze spots in the line.) Wear a dust mask to save yourself a lot of coughing when cleaning stuff.
if the vent is run under your house, go to the outside vent outlet and make sure it's not blocked or clogged.
Complementary to the vent line, clean out any tangible lint in the outlet hole area in the back of the dryer.
Past that point, my experience on the overheat goes a couple of places, all of which involve opening up the back. I'd suggest finding a DIY for your model to cut down on searching for screws. You'll likely have a bunch of 1/4" hex-head screws, which fortunately are the size of just about every hex-bit screwdriver set ever made - just put the hex end of the screwdriver on the head and it'll likely fit.
Inside, you'll open up the top of the blower unit. You will likely find it's clogged with lint, making the air pull anemic. Clean all the lint out of here. There are temperature sensors / cutouts. You'll need a DIY to locate which is which, and likely a voltmeter to test them. Last up-top possibility. Look inside the heater unit. It'll likely be a flat sheet-metal assembly on the right. If it's a gas unit, I'm out of my experience. If it's an electric unit, the heater coils are inside. They are likely covered in lint and laundry room dust. Use a long bottle brush to brush them off, or blow them off with compressed air. (Dust maskt!) A vacuum cleaner crevice tool can be useful. If they're covered in dust, they don't transfer heat to the air well, and can just overheat when the passing air doesn't carry the heat away.
Hope this helps! Good luck!
Nov 07, 2015 | Dryers
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
How do i clean the inside of an amish fireplace
I was told to tip the amish fireplace and hold it about 6 inches away from the floor for about 20 seconds then set it back up you can here it reset inside and I was also told they are self cleaning hmmmm I also had mine for more than the warranty and they sent me a new insert at no charge. Cannot beat that I have to call them again casue it runs for a bit then shuts down again all in all they have been great to me and it heats great too
Mar 29, 2012 | Napoleon Heating & Cooling
How do you clean this thing. I love the safety of it but can not figure out the best way to clean it since the cage doesn't come off.
Use a can of compressed air with a straw nozzle (like you clean your computer with) to blow the dust and lint off. be sure to do it outside, though. You don't want the dust settling back inside the house.
Mar 29, 2011 | Presto HeatDish Compact Heater
The flame is orange and I noticed it was running high and when we leave it on one burner it wants to shut off. I have dusted and cleaned it and it didn't improve it. Now when we go to light it usually...
Sounds like thermocouple is part of the problem as it relates to lighting the heater. Overtime, they do become pitted or corroded and should be replaced. As far as the orange flame when running on high is concerned, it sounds like the air intake valve on the burner is partially clogged with dust or lint. I realize you said, "I have dusted and cleaned it and it didn't improve it" But, if you didn't take the front of the heater cabinet off and cleaned all if the interior (including the burners, the plaques, the pilot and the interior walls of the cabinet), your cleaning wasn't sufficient. A Shop Vac with a hose, brush attachment and crevice tool works real well to help you accomplish this. Also, a can of compressed air with a straw nozzle (like you clean your computer with) will aid you in cleaning the pilot orifice and the Oxygen Depletion Sensor (ODS). To further assist you, I have included a link to your Owners Manual (in case you have misplaced yours) that you can download and print for future reference.Be sure the heater is cool and the gas has been turned off to the heater, before attempting to clean the heater.
http://www.desatech.com/manuals/Vent-Free%20Heaters/107885-01.pdf
Hope this helps you to solve the problem.
Mar 19, 2011 | Desa International GWRN18 Infra-Red Wall...
Grandson put something in front of cadet heater. Now it's not working. Is there a reset button?
Yes there is a reset. Take of the front grille and you'll see the button on the front marked "HEATER RESET - PUSH". Make sure your unit is clean and free from lint and dust, which will accumulate over time and use. Inspect the unit for any signs of scorching or damage from whatever was put in front of the heater.
Dec 08, 2010 | Cadet Manufacturing C152 Com-Pak Plus...
Lasko heater shut down
The 5840 has a problem with dust getting on the heater element and turning itself off after 2 minutes running. HERE IS THE FIX. Unplug the unit from the AC outlet, Then using a can of dusting air ( the kind you use to clean a computer key board) aim the compressed air INTO the middle louver of the upper adjustable heater vent and blow out the dust that has gotten on the heater element. ( You are actually blowing into the unit, clearing off the lint/dust that has gotten on the backside of the heater element that you can not see without openning the entire case).You can see the front of the heater element inside the louvers, It's the shinny metal part that looks like a small radiator.It sits behind the middle louver. After blowing out the dust, shake the entire unit to allow the dust to settle to the bottom of the case. Using a vacum cleaner try to vacum out any dust from the LOWER FRONT intake. Once the dust has been blown OFF the heater element, the unit will work just as new and not shut itself down!
Feb 15, 2009 | Lasko Ceramic Heater
Lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Dec 09, 2008 | Lasko Ceramic Heater
Heater wont work on high setting
Clean the burner with a wire brush and vacuum the ceramic. Blow out the heater, remove dust, cobwebs, and lint from it.
Oct 19, 2008 | Desa International GWP20T GLOWARM Wall...
Pilot light won't stay lit
Look for dust and lint. Look for them in places where gas should be freely flowing. I had a similar problem with an Empire Corcho wall-mounted propane ceramic catalyst heater. First it was the pilot light, then the #2 ceramic mantle. After horsing around with the gas lines and pressure regulators and trying to re-aim the pilot, it all turned out to be dust and lint in the gas passages. A little dust bunny in the brass pilot tube gave me a pilot light the shape and color of a banana. One puff of compressed air, and I got back my razor-sharp pilot. And some dust in the chimney of the #2 burner kept it burning blue/yellow and blistering paint off the upper surfaces of the heater. A bit of cleaning with a shop-vac put that right. "Passive" heaters are very much prone to this sort of problem because they rely on convection currents (i.e. LOW velocity) to get the job done. Convection currents are notorious dust collectors, as in COBWEB CITY.
Aug 23, 2008 | Heating & Cooling
Heating & Cooling Logo
697 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
