Question about Xerox 6505/DN - Workcentre 6505dn Color Laser Mfp,
Error code 093-950
Replacing ink cartridge with non-dell toner. getting "Y-CRUM error" "error 093-950.
4 Suggested Answers
  • 2072 Answers
SOURCE: Error states replace toner cartridge...
1. The toner is blocked or clumped in the dispense tubes. - Carefully remove the dispense tubes of the toner dispense system and check for a blockage in the dispense tubes. 2. The toner cartridge is not opening or augering correctly and the toner is not flowing into the dispense system. - First check the affected color(s) for toner availability, make sure that the dispense system is not being starved for toner due to a defective toner cartridge. Replace if found to be defective.
Posted on May 12, 2008
  • 18 Answers
SOURCE: After removing toner cartridges error display said replace various colour toners.
it is not according to your printer or your head of cartige is not clean or damage. try replace new one
Posted on Sep 11, 2009
  • 4 Answers
SOURCE: An unsupported black toner cartridge is installed
Some replacement cartridges require a new "chip" be installed to tell the printer that the cartridge is a match. I would check with New Egg and see if they forgot to send the chips, if required. I don't know of a manual bypass to the system.
Dave W.
Posted on Sep 14, 2012
Sharp AR-5127 error code F2-04
CRUM data read trouble
Replace the toner cartridge.
Replace MCU PWB.
Replace MCU PWB EEPROM
Check and fix connection between
CRUM (toner cartridge) and MCU
PWB.
May 18, 2014 | Sharp AR-5316 Advanced Digital Imager...
Error F2 on Sharp AR5516
Replace MCU PWB.
PWB.
May 09, 2014 | Sharp Office Equipment & Supplies
Solution for f2 error code
F2 - 04 : Improper cartridge (Destination error, life cycle error)
Detail : The destination of the machine differs from that of the CRUM.
The life cycle information is other than "Not used (FFh)."
Cause : CRUM chip defect - Improper developing unit
Check and remedy : Replace the CRUM chip - Replace the developing unit.
Identificat ion error : The trade mark code of the CRUM differs.
The company code of the CRUM differs.
Model error : The boot program model code does not coincide with the CRUM model code.
Type error : When the CRUM type is other than genuine/conversion/production rotation .
Destination error : The machine destination differs from the CRUM destination.
Data abnormality : When an error value is included in the initial
check information. When the max. toner supply time is 00.
When the print hard stop is 00.
Misc error : When the Misc information is other than "Not used (FFh)."
Oct 20, 2012 | Sharp AR-M160 Laser Printer
We have an error message CRUM 009-367 and we are unable to figure out what is wrong with it on our Dell 3110cn. Thanks
009-367:The Yellow (Y) Toner Cartridge CRUM Data error is detected.
  1. Cycle power on the Printer.
    1. Turn the printer off.
    2. Wait 10 seconds.
    3. Turn the printer on.
    4. Determine if the issue still occurs.
  2. Verify that the toner installed is Dell toner
  1. Cycle power on the printer again.
  2. If the error persists, replace the desired toner cartridge.
    • If the desired toner cartridge has already been replaced, replace the Toner Dispenser CRUM.
    • If the Toner Dispenser CRUM has already been replaced, replace the Printer.
Mar 07, 2011 | Dell 3110cn Laser Printer
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Error Code U2-40 on Sharp FO-DC550 fax machine.
That is a CRUM communication error. The CRUM is a chip that resides on the toner cartridge that keeps track of the toner usage and resets when a new toner is installed. If you replaced the toner recently it may be corrupt. If you got a refurbidhed toner they may have reprogrammed the CRUM incorrectly. Power supply problems often cause this error so check your outlet to make sure it is withinn the proper voltage range and also that it is not on the same circuit as other devices. Get a "real" surge protector designed for office equipment such as a smartpower. Try changing toners and using genuine supplies.
Jun 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Please help with diagnosis of following error for Dell 5110CN CRUM ID -093-693
crum has happened to me when using the wrong toner cart or using a non-Dell cart. If that is the case, replace the chip from the old Dell cart into the new non-Dell - easy to do by prying the small circular top off. You'll probably need to switch to non-Dell toner on the printer - go through menu to find it and your toner usage software will be disabled - that's life.
I also had this happen with real Dell toner cart and I did the same thing to rectify.
Mar 16, 2008 | Dell 5110cn Laser Printer
Xerox 6505/DN - Workcentre 6505dn Color Laser Mfp, Logo
1,277 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
