Question about Miele Dishwashers
Miele G 865 won't drain
2 Suggested Answers
  • 128 Answers
SOURCE: My Miele dishwasher has the red drain light on and
most common, debris stuck in the drain pump. remove the triple filter, remove the non return valve. clear the debris from the drain pump impeller. try to drain again. also make sure you dont have an obstruction in the drain line. if you replaced your garbage disposal recently, make sure they knocked out the drain plug when they connected the dishwasher. also make sure your dishwasher drain line connects directly to the disposal, and does not run to a air gap in your countertop. miele dishwashers will not function properly when connected to an air gap.
Posted on Jun 27, 2012
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
Feb 22, 2013 | Miele W1926A Front Load Washer
Miele 3204 won't spin or drain
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Your filter of the water inlet valve is accessible outside the machine; it is at the water entry point. Close your faucet & check this out; this gets clogged often.
Hope i am helpful...... Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve
Dec 02, 2012 | Miele Washing Machines
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Sep 28, 2012 | Dishwashers
My Miele dishwasher has water in the bottom of it and won't run
Check the impeller on the pump to make SURE it's turning freely. There could be a piece of debris wedged in there - like glass or a screw from a pot handle. If this is redundant, I apologize.
May 24, 2012 | Miele 24 in. Novotronic G851SC Plus...
Why is my Miele Novotronic w1512 saying Drain fault?
I have the same problem, i have cleaned the filter area and there was a plastic sweet wrapper in there also. However, I have put the machine back on an express cycle ans still have the error message coming up?? Drain Fault! I then tried to spin and the spin cycle wasn't working eithet. Whilst the machine was still on i patially undone the filter cap and removed a full tray of water, it then began to spin. What could yhe problem be?
May 21, 2012 | Miele Washing Machines
Won't drain all the water, the machine stops and the red light flashes
I have just had the same problem. Dishwasher on as normal, no water going in-EEEEk, did everything the manual said to clean drain pump and non return value, no change. Then I read answer above from wcredentino and low and behold, dishwasher immediately started and no call to service man tomorrow- yay, thanks 'wcredtino' However, for me, holding both buttons at once didn't work, reset occurred when I held the on/off switch down for 5 seconds- when I held it down with the start/stop button the problem persisted.
Thankyou!
May 13, 2012 | Miele Dishwashers
My Miele dishwasher has the red drain light on and won't drain
Mar 23, 2012 | Miele Dishwashers
Will not empty water
Hi.
If the machine does not drain you usually have drain blockage. Clean the drain well at the bottom of the tub. remove and clean filter and assembly parts. Make sure that the drain hose at the back of the dishwasher is not kinked.
Several Miele dishwasher uses a pressure switch to determine the water level. A defective pressure switch may prevent the machine from starting.
If this model uses a pressure switch, the switch will be located in the drain line. When a pressure switch is defective the machine should return an error code. Here a picture of the pressure switch:
If that does not fix the problem the pump located under the bottom panel must be tested.
Regards.
Ginko
Dec 15, 2011 | Miele 24 in. G2180Vi Built-in Dishwasher
Dishwashers Logo
19 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
