Question about General Electric Hardware & Accessories
Cant get the timer to switch on or off
Since the clocks have changed cant get the timer to come on at 8am in the morning and to go off at 6 in the evening.Can u remind me what to do as ive missplaced the instructions
  • General Elec... Master
  • 5,245 Answers
10-31-12
Not sure which timer.
Probably in-wall hardwire or plug-in type timer.
Probably digital.
Copy following links to help identify timer and download manual
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Posted on Oct 31, 2012
2 Suggested Answers
  • 396 Answers
SOURCE: Setting the timer
Click on the link below to download your manual if you see your model listed.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
You can install a photocell for six to ten dollars which you can wire in series with your timer output. The photocell that will bypass the daylight time cycle from 8am-12pm.
Posted on Jul 27, 2010
I dont no how to set the timer to 24 hr clock
change to 12 clock
however a 24 hour clock has the same times up to midday -- midnight to midday --- the hours are 1 to 12 oclock after midday you take 2 off the reading and it is the same time as a 12 hour clock
so 1300 is 1 o'clock, 1400 is 2 oclock ,1500 is 3 o'clock
1800 is 6 o'clock 2400 is midnight
the minutes are the same regardless so 1.30 is 1.30 after midnight or 1330 after midday or 1.30 after midday now for example --if you want the timer to start at 6am you set the timer to start at 6 am to switch off at 8 am set switch of at 8 am
it you want the timer to start at 6 pm set it at 1800 and switch off at 10pm set it at 2200 hrs
Jan 22, 2017 | Hardware & Accessories
I have a hager eh 110 time switch on my pool and I cant set it. Any clues?
Hagar EH 10 is 230V analog time switch.
EH010 is 1" wide.
1) See large image of EH010
http://www.bewdirect.co.uk/home/m/Shop/id/3985/page/1/
2) See large image that explains how to set EH-010
http://waterheatertimer.org/images/EH-010-image-1000.jpg
3) With analog timers, there is a movable dial that rotates with fingers.
Pins or segments are located around edge of dial.
Segments are moved one direction or the other to set on-off times.
After segments are set, the dial is rotated to match current time.
The dial rotates as time passes, and segments move a switch that opens and closes electric circuit.
4) EH-010 is different.
Usually analog dial is located on face of timer like a clock face.
However EH-010 is only 1" wide, so dial is perpendicular to front of timer and is rotated with thumb.
5) I suggest setting a few segments one direction or the other and then manually rotate dial full circle to watch when pool equipment turns on-off.
This will tell you if segments should be set right or left.
I have not seen this particular timer, but it appears as if times on printed on edge of timer dial.
6) Timer has 240V clock motor.
So Hot line wires from circuit breaker connect to terminals 1 and 2.
This powers clock motor so dial rotates as time passes.
240V Line and 240V Load wires are connected as shown in image below:
Feb 10, 2011 | Electrical Supplies
My t1004r timer does not run any more. The manual switch still works. The problem may be due to rain getting inside. Does the whole unit needs to be changed out?
If manual override works, then timer is basically sound.
1) If dial does not rotate, then replace clock motor: T104 timer uses 240Volt clock motor. T101 and T103 use 125Volt clock motor
2) If dial rotates, but trippers are missing or trippers are worn down and no longer click on-off lever, then buy new trippers.
T100 series trippers and clocks are shown following link:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
3) If you have different timer than T101-103-104, then add a comment.
4) Clock motors are located on back of mechanism.
Mechanism snaps out with thumb spring located top inside box.
Clocks have identifying numbers: google search for that clock number if different that shown above.
5) If you buy new timer, then specify T104R.
R suffix is for raintight box.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
6) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 13, 2011 | Intermatic T104 24h 208-277v Mechanical...
Have model T103 Intermatic Timer that have been turning on the store lights for the past 20 years. Recently the timer does not turn the lights on in the morning and I have to manually flip the switch to...
Sounds like you need new ON pin
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
The ON-OFF pins rotate around until they come in contact with a lever. The clock motor pushes the pin forward until it clicks the on-off lever. The pins are softer metal than the lever, so the pins wear out.
If you need a new T-103 timer some day > the new timer mechanism can snap right into the old box without changing boxes.
If the dial is not rotating, then you can replace the T100 series 125 Volt clock motor (the T103 clock motor is 125V)
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=Wh40&op=search&Ntt=Wh40&N=0&sst=subset
Oct 12, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have a rangemaster leisure 110 my timer was flashing but was able to reset it, now the clock is on auto showing 0.00 and using the two buttons for 6 seconds then pressing plus or minus nothing happens
how can I get to the clock, I want to disable the auto timer, I cannot seem to find how to get to the wires, the hot plate (warmer) needs to come out first I think but cant see how to get it out ..URGENT
Many Thanks
Oct 01, 2010 | Rangemaster 110 (Gas) Kitchen Range
Setting the timer
Jul 27, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Timed pic taking
Press left on the multiselector (marked with a one-handed clock). Once the self-timer has been selected, you start it by pressing the shutter release button.
Jun 03, 2009 | Nikon Coolpix L11 Digital Camera
We have an aeg competence oven and we cant get it on cos the digital screen is flashing P00;00 and we cant get it of to set the time so the oven will work can you help
the problem may be with the clock chip, and not having a functioning clock means that the relay which connects mains power to the lower oven is not tripped. the clock unit costs $200 here in Yurp. since I don't use all the timers and delays that's a lot of money for a clock. so a friend and I took the clock unit out and shorted the relay so that mains power is always provided to the lower oven, and ginger bread is being baked as I type. and just to make it a traditional repair I put a piece of duck tape over the flashing P0.00, that was a bit irritating.
Jan 22, 2009 | Ovens
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Hardware & Accessories Logo
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
