Question about LG WM-1832C Front Load Washer
WM1832 CW washer with UE error
Hi Rich,
I followed your instruction and removed the front lid of my washer but I did not see any foam at all. Instead it is a circuit panel full of wires.
I also removed the bottom panel in the back of the washer where the drum is but there is no foam as you described.
Please advise.
Thank you.
    Genius:
  • 1,036 Answers
You should have access to the sides of the drum. Attatch foam to the either the drum or he outside casing.
The problem is caused by the drum moving too much (because of the defective dampers).
This is a cheaper fix than replacement dampers.
Posted on Jan 04, 2009
LG WM1832 CW how to force unlock the door
look to the bottom of the washer some may have a drain plug next to the filter placement as to the LG TROMM washers....do have a bucket ready as it will come all out at once if ya take the filter cap off
Oct 04, 2016 | LG Washing Machines
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
How do I rectify the UE code , I have finoished my wash but it is still showing up
Hi.
US means unbalanced error. Try balancing the unit as explained on the owners manual. Try redistributing the load. Check the floor. If that does not work try following the instructions in the diagrams for the specific code available on the LG support website. Here the link.
Regards.
Ginko
Sep 06, 2011 | LG WM-2077C Front Load Washer
Getting a UE code on LG front load washer
Hello there
The UE ERROR CODE
UE - Unbalance switch error Unbalanced load is sensed three times during a spin operation. Open lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board Normally this turns out to be the unbalance switch that has failed and needs to be replaced so i would have this checked first.
If you have a warranty on this machine still you should be able to use it ok?
Hope this is very helpful or you.
Best regards Mike
Sep 26, 2010 | Washing Machines
WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
May 16, 2010 | LG WM1814CW Front Load Washer
Ue error code on my LG WASHER
Hi there
hope this helps you .
· Check circuit board thank your for writing to fix ya.
Best regards Rich
Dec 08, 2009 | LG WD-16115FD Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
LG washer with UE error issue
This is fairly easy to do, although you need to find some suitable foam - two pieces about 8" square and probably 3" - 4" thick.
You will also need a suitable adhesive, which could be spray carpet adhesive, copydex, or silicone sealant.
Turn off and unplug the machine, "walking" it out slowly if it's under a counter. Do not strain the water hoses too much.
Undo the few screws along the top at the back that holds the lid on, then slide the lid back an inch and lift off.
There should be some foam buffers in there already - but may have fallen off. Retrieve them if they have, but fit your bigger ones instead to leave maybe a finger width gap each side of the drum.
Make sure any springs on the top you can see are ok while you're there.
Once fitted, refit the lid and screw back, then push back the machine from very low down - check hoses are not squashed, and the outlet hose is ok.
Turn on again.
Jan 02, 2009 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
139 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
