Question about Kitchen Ranges
Circuit diagram for 082438200 Stoves PCB Stoves gas oven 700GR
I managed to short this out and fry one of the components. IC8 to be precise. I may have done more damage, but if I can replace IC8 I will soon know. This is the board http://www.apart4u.co.uk/parts/082438200/stoves-cooker-pcb-printed-control-board-control-unit.html Any help appreciated, or a replacement board.
  • 131 Answers
SOURCE: Replace RSD30 oven control
This is one of the hardest stoves to get into. Turn off the breaker.
Pull off the burner knobs. This should reveal four large plastic nuts holding the console in place. You can turn them gently with channel locks straight on - not from the side. After you've got the console loose, everything else is downhill. There's lots of screws behind console, and across the bottom of the console (just above the door.) Remove just the ones you need, or face the wrath of Dacor!
Be careful about the rubber strip across the top of the console. It often stretches during a repair. You might have to cut off 1/4 to 1/2 in to get it to fit again.
The large plastic nuts are very east to get cross threaded when replacing them. I recommend turning them counterclockwise until you can feel the threads line up.
Posted on Mar 11, 2008
SOURCE: Remote code required for UK Bush tv model WS6680SIL/C7
Found the correct code for my TV & Sky remote... I searched a fair bit more on google for... "WS6680SIL/C7 code" and found... http://www.sjstv.co.uk/skycodelistNEW.html which the correct code for my Bush TV - 0742. Others you may want to try are Bush 0157 246, 263, 377, 037, 064, 065, 310,300,383, 399, 391, 402, 339. or Beko 0125 514, 398. Further, Alba Group are the firm whom own Bush brand amongst others. Google Alba Group to get their site and links to Bush sites.
Posted on May 20, 2008
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven ignition: gas goes out as soon as control knob is released
Replace the oven thermocouple.
Posted on Mar 15, 2009
  • 7 Answers
SOURCE: i have no instructions for my stoves envoy cooker,
You can ring stoves on 08712222502 they will usually email over a manual for free you just need your model and serial number of your oven.
This can be found usually just behind the door to the grill.
hope this helps :)
Posted on Jun 01, 2009
Can you e mail me the manual for Stoves precision 1100 cooker
no
go google and type in--- user manual for stoves precision 1100 cooker --- and download the pdf version your self
Sep 26, 2016 | Stoves Ovens
Hi I have recently moved house, and have inherited a Stoves 720EF double oven. The dials on the fascia, do they have a backlight, as the only way we can see the dials is shining a torch on the fascia! I...
I have just checked my 720 and when you turn any of the dials on a neon lights up near the dial to illuminate that particular dial. Now as far as I can see the diagrams in the handbook do not show the neons as such. However, they do show a 'neon printed circuit board' that has connections to all the switches. So if all the three neons fail to come on, it would suggest that the neon P.C.B. and/or its associated wiring has failed. I'm afraid you will need an electrician to sort it to conform what has failed. Espares may be able to obtain the part for you. If you need a copy of the handbook, (with diagrams) supply an email address and I will send you a pdf copy.
Jun 10, 2011 | Stoves 720EF Electric Double Oven
I have a Stoves 905MF double electric oven. Tonight all the displays are active with all 8's showing in the temperature and time digital displays and multiple icons showing in the two oven displays. It is...
Re: Stoves 905Mf , I have exactly the same problem, Stoves told me niether power pcb or control pcb available as unit is obsolete.
This oven was made in 2006, what rubbish service !
Sep 28, 2010 | Stoves Kitchen Ranges
How to set oven programs
Hey, I've searching for a replacement manual for my Stoves Precision too... Found it here:
http://www.espares.co.uk/part/cookers-and-hobs/stoves/p/1092/630/0/0/917524/handbook-precision-1100df.html
If you buy it please use this code:
39WMTIXO
Cheers,
Apr 02, 2010 | Stoves 1100DFSID Kitchen Range
No Grill operation for stoves 720ef
Supply an email address for you and I will grant you access to my BT Digital Vault where a copy of the complete handbook is lodged. It includes circuit diagrams.
With your fault, can you here the switch operating, if not it just may be stuck?
Dec 12, 2009 | Stoves 720EF Electric Double Oven
How do i set the clock on a stoves 700gr mk2 double gas cooker
my stoves 700gr has stoped workin can you pls help
Dec 12, 2009 | Stoves Ovens
Stoves 720EMa - need wiring diagram
I will give you access to the handbook shortly.
Sep 27, 2009 | Stoves 720EF Electric Double Oven
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Kitchen Ranges Logo
70 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
