Question about Toshiba Computers & Internet
My laptop says no bootable device insert disk what is wrong?
  • Toshiba Master
  • 32,281 Answers
NO BOOTABLE DEVICE When the PC cannot see a boot file/disk on either the hard disk or floppy drive it gives an error message "No bootable device. Insert boot disk and press any key" First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Posted on Oct 31, 2012
Testimonial: "i replace the harddrive and it work just fine"
Godshifter
  • 13 Answers
SOURCE: Media test failure, No bootable device, insert boot disk.
That happened to me when I tried to upgrade. If you don't have an external DVD drive, you have to copy the restore disk to a flash drive, put it in the USB drive, power up, hit F12 at the first screen, move the highlight to the USB and boot from it.  Oh, and it has to be at least    1 GIG, the USB Flash drive does, or it won't fit.
Posted on May 18, 2009
freetek
  • 5568 Answers
SOURCE: Aspire 5315, no bootable device, PXE-E61 media test failure,
With any standard laptop (your Aspire included) the default boot disk should be set to drive C:
If the system is not finding drive C:, the boot sector may be damage or the drive may have failed completely.
Depending on your operating system (probably Win XP for this one) you can make a boot disk on a friend's optical drive and change the boot sequence in the BIOS setup to your optical drive. Just make sure the disk you've made is compatible with the drive in your Aspire; such as CD - DVD+-, etc.
Once you can get some kind of prompt, either from a basic Desktop or just E:\ from your boot CD, try typing in "C:" (without the quotes) to see if it is accessible. If not, the drive may be bad.
If the drive is still readable, you have more work to do to restore the damaged boot sector.
Posted on Mar 21, 2009
SOURCE: Acer Aspire One Insert boot disk
well u really cant put in a disc, you said you have the aspire one that means it doesn,t have a disc drive . Thats the way it was made
Posted on Jul 10, 2009
endisforever
  • 36 Answers
SOURCE: MY SYSTEM SAYS NO BOOTABLE DEVICE--INSERT BOOT
Okay, first things first. Unplug everything except for the power cord. Make sure the floppy drive (if you have one) and CD-ROM drive are empty. Go into your computer BIOS settings and make sure that the computer is set to boot from your hard drive first. (Depending on the computer, usually holding down F2, F4, F6, F8, or even other function buttons will allow you to do this. Not all of the buttons at once, but just hold each one down when you start the computer until the BIOS comes up). If this doesn't work, your Hard Drive is either corrupted, all information has been deleted, or simply came loose over time. You may be able to fix this yourself. The easiest solution is to reformat your computer using the original disks your computer came with. You can also use a licensed copy of Windows disk.
If you have information to recover, I would look into Bart's PE Builder (google it), although that requires another computer. If you have access to another computer there are many boot disks that you can download or buy.
If none of these work, try getting your computer into DOS mode. It's much harder with XP and Vista, but Windows ME and earlier it should be an option. simply type C:\ at the prompt, cd windows, dir/w. This will tell you if windows is still there. At least then you'll know your options. If windows is gone, the only way to get it back is to reinstall it. I hope something in here helps someone.
Posted on Jul 14, 2009
parrotheadpc
  • 2600 Answers
SOURCE: no bootable device message, says insert boot disk what is that
Usually this is idicative of a hard drive failure, try to boot with the windows cd and see if it will boot up. Try this below......
Windows Start-up Errors
First, The basics. You will need a Windows CD. If you only have a recovery disk set like the ones from a HP or Compaq, they will not do what you want. You can normally use a Dell disk, also retail box disks (Windows Purchased from the store), or some OEM versions of Windows will work (most of these will have the Microsoft hologram on them).
When you get the system started and it finds your startup disk you will see a screen that says Press any Key to boot from CD. I normally use the space bar as my any key and then you should see a blue screen that says Windows setup in the left hand corner. Wait until you see the welcome to setup screen and then click the "R" key to get to the Recovery Console How long it takes to get to each of these depends on the speed of your system, but I will tell you that it will take a few minutes to finally get to the Console.
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the enter key.
This will bring you to a prompt that says:
C:\WINDOWS>
Type: cd \ and then click enter
( Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work. If you find that a command hasn't worked make sure you typed it correctly. These are similar to old DOS commands where spaces had to go between each command so DOS knew where one command stopped and another started.)
You are now at the ROOT of the drive where it all begins. The Prompt should now say C:\>
Now type: CHKDSK /R and click enter.
The chkdsk / r command also includes the P command and will also look for lost recoverable information in bad sectors.
Now after the chkdsk has run type: FIXBOOT then click enter.
It may prompt you with a warning but continue through it and once fixboot has finished type: EXIT and click enter.
Your system should reboot and when it does click the F8 button to get a windows start menu. Use the up or down arrow to highlight the LAST KNOWN GOOD CONFIGURATION and click enter. If it was a simple drive error this should have fixed it.
Posted on Nov 21, 2009
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
Aspire one keep saying no bootable device insert boot disk and press any key and I don't have a disk slot
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 19, 2012 | Computers & Internet
It keeps tellin me no bootable device-- insert boot disk and press any key... i also dont have a disk drive all i have is a ubs flash drive spot
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Oct 17, 2012 | Acer Aspire One D257 Netbook
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
HP Pavilion dv4-1548dx no bootable device-- insert boot disk and press any key help no disk
en mi laptop hp pavili
como hago si mi laptop hp paviliondv4 sale no bootable divice -- insert boot disk and press any key
Apr 23, 2012 | Computers & Internet
Ace r5315 No bootable device insert disk and press any key
Open the hard drive bay and ensure it is plugged in correctly. If that isn't the problem, try testing the hard drive. If it's ok, then the motherboard is gone.
Dec 19, 2011 | Acer Aspire 5315 Notebook
No bootable device insert boot disk
1.Please insert bootable disk( Like Windows XP/7 or Vista) into the cd-rom
2.then restarting your pc
3.press booting from cd-rom
It will work
thanks and Regards
Trinoj
Aug 04, 2011 | Acer Computers & Internet
It says "no bootable device
bring it on a computer service center...your laptop need to be reformat and install w/ OS, windows7 or vista, its your choice but surelyyou gonna spend big bucks for it....hve a nice day
Feb 12, 2011 | Computers & Internet
I have a emachine notebook when turning it on this is what comes up on the screen: check cable connection! pxe-mof: exiting intel pxe rom. no bootable device - - insert boot disk and press any key. What...
The motherboard no longer detects a hard disk present - it has died. Replace it and reinstall Windows using the recovery cd that came with the laptop.
Feb 09, 2011 | eMachines eMD620-5133 Notebook
Hi, I cannot boot my acer aspire 5315 laptop, No boot filename received. PXE-M)F: Eciting broadcom PXE Romm. No bootable device. Insert boot disk and Press any key. Please can you help. Mant thanks
It looks like your hard disk went invisible, and BIOS is trying all alternative boot options before it says that there's no boot device available.
I'm afraid that the most probable diagnosis is that the hard disk is broken; anyway you'll need hands-on service to establish what's wrong and what can be done.
Oct 18, 2010 | Acer Aspire 5315 Notebook
Computers & Internet Logo
317 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
