Question about GE Profile Energy Star PSC25MGS Side by Side Refrigerator
Drips at water dispenser GE PSC23MGSA BB
Is there a self-service fix for a small but steady drip from doorfront water dispenser? Modal GE PSC23MGSA BB Thanks!
  • pb0324 Feb 26, 2009
    how do i replace the water valve?
  • 54 Answers
If it's a constant drip then you need a new water valve.
Posted on Jan 04, 2009
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    GE modle GSS22JET BB\ice maker water supply continues to drip
    You will need to turn the water supply off to refrigerator and pull away from wall and then take the paper cover off cover the compreesor area. Take the old and defectice water control valve off and Click Here=> WR57X10050 There are two sides, one for ice maker and the other for the water dispenser. Wiring will only go on correct connection. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
    Thanks, Sea Breeze
    Mar 18, 2010 | GE Refrigerators
    Water dispenser in door front is leaking.
    The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
    Nov 04, 2009 | Kenmore Refrigerators
    Ice maker dripping water even in stop position (bar up) and keeps supplying water to device. water dripping from the bottom of the housing unit at a steady rate.
    unplug ice maker if you still have water coming in fill valve is stuck on back on the bottom if not more than likly icemaker bad
    Jun 26, 2009 | GE Profile 20.7 cu. ft. CustomStyle...
    Water drip at doorfront water dispenser
    Hi!!! Yes you can fix it by installing an antisyphon device on your water line leading to the water dispenser..remember i've done this for many years repairing frigs and they all do this they all leak water out alittle bit..Good luck..
    Jan 03, 2009 | Refrigerators
    Ice/water dispenser drips after using
    afraid that sounds exactly like the problem.brand new fridge call who you bought it from they should fix it for free good luck hope this solves your problem
    Aug 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
    Water leaking at filter
    If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
    Feb 26, 2008 | Refrigerators
    Water dispenser dripping
    Your house valve may not be totally closed (bad seal or something) letting a small bit of water through. Disconnect the line to the fridge completely (in the back) to be sure. That way even if the fridge solenoid valve is bad AND the house valve is bad you won't get dripping. If you know the valve is good, there are times when the water filter will have air trapped in it letting the water in the line drip out slowly until it's finally empty. Pull any filters you have also.
    Feb 16, 2007 | Kenmore 53582 / 53584 Side by Side...
    GE Profile Energy Star PSC25MGS Side by Side Refrigerator Logo
    432 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
