Question about Frigidaire Refrigerators
Frigidaire refrigerator temperature problem
Temperature control is very high. when you change it it won't stay.
  • Official Brand Answer
  • 4,342 Answers
Hello - From what you have describes it sounds like the damper door might be open causing the temperature to be too cold. Use a mirror to look at damper door at the rear of compartment and use a hair dryer on damper door to deice for 5 to 10 minutes. Allow 24 hours and if the temperature is still too cold, then I would have a professional look at the damper door or thermostat control for replacement depending on the diagnostic.
Posted on Nov 02, 2012
ngfam1
  • 639 Answers
SOURCE: frigidaire refrigerator
Friend,
ngfam1 At your service!
Sounds like your thermostat is malfunctioning.
Do not let it keep going like this without service or it will burn out the compressor soon by running non stop.
How old is the fridge????
now that's expensive and not worth investing in if the fridge is 10 years old or more the new refrigerates use much less power and can change your electric bill for the better !
Below I referred you to a great service nation wide!
Here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
SOURCE: Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Posted on Oct 30, 2008
Maytag317
  • 1136 Answers
SOURCE: THERMOSTAT
Hi, Here is the Part # 5304421256.
This is a common issue with this model. Just remove the 4 screws holding the control panel up and you will be able to see the thermostat/cold control
I hope this helps you.
Please let me know if I can assist you further.
Vicl
Posted on Jul 05, 2009
Eeeh, this will prevent you to spend more than you have. Carefully unplug your fridge, remove it from the wall for about 1 foot wait 15 mins and plug back and let it stay there for ever.
Posted on Sep 16, 2009
heatman101
  • 43501 Answers
SOURCE: Frigidaire Gallery Model FRS26ZSHB3 The
There are two things that could be happning....
1. The control is bad and when you manually turn it it will close and start the unit, but it will not close after it opens to stop the unit on it's own....
In other words... you touching it and moving it will get it to work, but it will not turn the unit on if there is no outside influence on it....
The possibility is that the compressor will not restart when warm...but once it cools down it will restart....
I don't think this is what is happening though... my bet is with the thermostat/control...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 12, 2011
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Feb 14, 2017 | Samsung Refrigerators
Chimes constantly. How do you turn them off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung RF263AEBP Refrigeration :...
I have a frigidaire side by side model GLHS37EHSB7 refrigerator makes a continuing beeping sound what could be wrong?
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
May 11, 2015 | Frigidaire Refrigerators
Smeg refrigirator keeps beeping without stop
Mar 09, 2015 | Smeg Refrigerators
The freezer temperature will not stay programed, keeps fluctuating
Hello Charlotte Goodman, thank you for your post!
From my understanding your Frigidaire refrigerator, FPHB2899LF8, will not stay programmed. It sounds like a possible problem with your control panel. I would recommend performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience an issue with your temperatures I would suggest consulting with a professional technician for proper replacement of the control panel. I hope this is helpful. -Matt
Nov 30, 2014 | Frigidaire Refrigerators
Flap won't stop humming buzzing
Oct 07, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
Jul 07, 2014 | Frigidaire Refrigerators
Why is my Fridgidare side-by-side freezer working but my refrigerator side not cooling?
Hi Friend, this is Z. Thank you for your question!
If the temperature in the freezer compartment of your Frigidaire refrigerator is cooling but the refrigerator side is not, it may possibly be because the temperature control is set too cold/high in the freezer section or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the temperature does not stabilize within 24 hours, then more than likely the control is not telling the damper when to close and/or your refrigerator might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts.
May 21, 2014 | Frigidaire Refrigerators
215846602 215267800
Hello Jennifer - Often when the temperature is too cold, it is because the temperature control is set too cold/high or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the unit stabilized within 24 hours and the issue persists, then more than likely the control is not telling the damper when to close and/or the unit might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Jul 02, 2013 | Frigidaire FRS23W3A Side by Side...
Refrigerators Logo
148 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
