Question about Vacuums
Dyson DC 24 YDK motor is toast. What to do?
Do I need any other parts besides the YDK. How do I go about putting the new motor in?
  • Vacuums Master
  • 18,424 Answers
Click this link for full instruction how to replace the motor on DC24
http://dysonmedic.co.uk/how-to-replace-brush-bar-motor-dyson-dc24/
Posted on Oct 31, 2012
5 Suggested Answers
  • 389 Answers
SOURCE: Dyson DC 24 blockage between brush bar and
You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Posted on Jan 06, 2010
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
  • 9 Answers
SOURCE: Dyson DC 24 is clogged, not suctioning. How can I
I removed the flexible tube sections and blew compressed air in reverse flow path to remove the clog. however I have noticed my vacuum getting clogged more often and would like to know how to clean the insides of all the pipes to remove residue alloing buildup
Posted on Jul 08, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Posted on Nov 30, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: the brush dosent moving dyson
    You should be able to resolve this issue by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1502&product=DC24-ALLFLOORS
    However, if you're still having problems, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can go through a few checks over the phone.
    Kind regards,
    Jack
    Dyson Customer Service
    Posted on Jun 09, 2011
    Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
    Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
    Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
    How can i dismantle the dyson in order to inspect the motor
    You have to remove just about everything to access the motor. Instead of mew describing it, take a look on Youtube - there's plenty of information there.
    Take a look at: How to replace and fit Dyson motor DC14 DC07
    The motors do go wrong and non-genuine replacements are half the cost and work just as well. I got a motor and a set of filters for much less than a "genuine" YDK part.
    Jul 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
    I need a parts diagram of a dyson dc 18 that I can read. Please help.
    Sorry we do not have this diagram. Contact Dyson, whom I suspect is not going to be very helpful based on previous experiences
    Oct 11, 2012 | Dyson Dc-18 "slim" Upright Model...
    Dyson went very slow and black smoke came out and it started smelling and stopped worked.
    You need a new motor. It is a standard Dyson YDK motor fitted to your machine. In the UK, this will cost you about £65-£80 to have repaired.
    Jan 27, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    How do i fit new carbon brushers to dyson dc14
    It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
    Also, be sure you change the filters; one of which is washable.
    Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
    Oct 24, 2009 | Dyson DC14 All floors Bagless Upright...
    How do i fit new brushes in dyson dc 07 have the
    you have got to open the motor housing that isthe black casing that surounds the motor first then the motor comes out then you can see the brushes thay come out by lifting the copper strip up gently with a screwdriver then you pull it out then put in new ones
    Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    We have a dyson dc 07 animal the machine was working fine then switched off after returning to the machine minutes later it wouldnt switch on, i removed on off switch cover and used a short piece of wire...
    It could be the motor. I'm having to replace the brushes on my DC 05. It appears that you can only get brushes for the YDK motors in the DYSON, not the Panasonic motor. Which might be saying something about the YDK motors. What happens is that the carbon brushes wear down which is normal. However, the contact wire from the brush to its connector is set so that when the brush wears down, the wire is short enough to stop the spring etc from damaging the commutator. The end result is that you get an intermittent operation of the motor before it finally dies.
    I believe all the DYSONs come with the option of both motors and you cannot really tell which motor you have until you take the thing to bits. You also cannot change motors without changing various other parts on the hoover. On my DC 05 the writing on the YDK motor tells you which one it is.
    This website www. tasweb.org ,select the DC 05 option and scroll down tells you how to take the thing to bits. A search on google etc for your DC 07 may give similar results. Best of luck!
    Jun 20, 2009 | Dyson DC05 Cylinder Bagless Canister...
    Unable to find a panasonic replacement motor for dyson dc07 vac.
    You can convert it to the YDK one if you get the YDK motor housing as well.
    Mar 18, 2009 | Dyson DC07 All Floors Bagless Upright...
    Vacuums Logo
    123 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
