Question about Samsung CLX-3160 All-In-One Laser Printer
Clx3160 cutting off top of page
Every page I print is cut off at the top on my Samsung CLX-3160fn
  • 1003 Answers
SOURCE: Black lines across page
are black lines appearing on paper after printing from computer or when a fax is sent or recieved or both?
Posted on Jan 15, 2008
SOURCE: Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Posted on Feb 07, 2008
  • 670 Answers
SOURCE: My Samsung CLX-3160FN prints with
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then they also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade. Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Posted on Feb 27, 2009
  • 406 Answers
SOURCE: Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
Posted on May 10, 2009
  • 670 Answers
SOURCE: Samsung CLX-3160FN Vertical lines when printing black
This is a very common problem with Samsung CLX-3160 and CLP-300 printers. The real problem is that the developer blades get dirty with the toner. Buying a new imaging unit will only fix the problem for a short period of time then it starts to get buildup on the developer blades.
You need to clean the developer blades. If there are streaking on any color, then also needs to be cleaned.
Posted on Dec 24, 2009
My samsung clx 3160fn prints with a faded streak in the center of the paper
There is some-thing that is dirty that is making contact with the paper.
My guess is a roller or a little metal guide wheel or the like.
Clean it with tissue paper.
Use the already printed page to line up to see where about the source of the line is comming from.
Till next time!
damnor01
Apr 14, 2011 | Samsung CLX 3160fn All-In-One Printer
It cuts the image in halfWhere can I find the online manual
The direct link to download the manuals for this printer is http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=CLX3160FN&searchInputBox=CLX-3160FN&find_button=See+all+results
The graphics image is probably larger than the memory in the printer can handle in which case you'll need to reduce the resolution (or print quality) when you try to print it.
Jan 27, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Need to set up scanner on clx3160. Samsung have
need to go into user mode.press menu button scroll to fax setting,enter country,phone# and company name or just surname etc.
Jul 03, 2009 | Samsung CLX 3160fn All-In-One Printer
Transfer belt nees replaced
find samsung dealer,not hard to replace.
Jun 03, 2009 | Samsung CLX 3160fn All-In-One Printer
Vertical line on page when scanning/faxing
Clean the scanner glass. You probably have some dirt or whiteout on it. Open up the top feeder and look at the narrow glass and you'll probably find it.
Mar 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN won't print from my HP Pavilion Media Center M7467C
I have a brand new HP pavilion, but it wont print from my HP deskjet. If i am lucky i get the first p[age and a couple of lines on page 2. My new laptop (ACER) is quite happy to print using the same cable. printer etc. Conclusion...HP pav is defective. Am I wrong?
May 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Jan 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN "scanner locked"
Every Samsung multifunctional device has a scanner lock underneath the glass. This is to prevent scanner damage during shipment. Th user's manual in the CD and the unpacking sheet clearly illustrate where this lock is. If you open the top lid and look to the lower left corner of the glass, you will see a small lock-open/lock-closed symbol. Underneath that symbol you will find the lock. I'm including a small visual reference of a similar model. Just remember to turn off and on the unit after the lock is removed.
Sep 28, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
