Question about LG Heating & Cooling
Error code c2
Unit is continusly flashing error code C2
Therinnaiguy
  • 1420 Answers
SOURCE: error code c2/c3 on carrier
Need a better model number to be able to help you out. Somethong like 40QK_ _ _
Posted on Jul 21, 2008
SOURCE: norcold fridge displaying error code
My refer was displaying error code C2...I troubleshot it and found that C2= "no 120 VAC" coming off the board for heaters. Heaters were good (checked out with Ohm meter) so it had to be on the board. Turned out to be easy...about only parts on the board that could cause this problem was a S.P.S.T. relay...purchased from Digi-key for $1.70...beats the price of a new board nearly $500. Been working fine now for about 2 weeks.
Posted on Oct 12, 2008
SOURCE: My Paloma tankless water heater flashes C2 11 error code
I just had the same problem and I fixed it in about an hour or 2. First shut off the gas,water and power(unplug it) Take off the cover There are about 20 screws above the electrical circuit board. You have to remove all of those screws to remove plate that is covering the burner assembly. The burner assembly has these 3 pins that look like number 7's these are covered with build up and gas can't flow right. That's why you get the c211 error not enough gas. Take a wire brush and gently remove any build up, I also cleaned the thermocoupler which is next to the burners. It looks like a metal pin with a couple of wires coming out of it this was also very dirty. I took a can of air and basically freshened it up It works perfect now. Email me with any Q's at Mario@myredr.com Good Luck All that you need is a long phillips screw drive and a drill because its about 25 screws
The burner assembly has 2 screws all the in back underneath the assembly once you remove those 2 the assembly comes out . You don't have to disconnect any wires.
Posted on Oct 29, 2009
  • 244 Answers
SOURCE: What is error code c2 76
Lost comm. between the remote and the burner control circuit board.
Posted on Nov 01, 2009
  • 269 Answers
SOURCE: i don't know the security code of nokia 5130-c2
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 1234 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Posted on May 20, 2010
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
How do i cancell all codes in nokia c2-00?
sir my nokia c2-00 security code error bata raha hai please help me
Sep 10, 2013 | Nokia mobile C2-00 Dual SIMbiosis
How to fix c2 error code on 5400
1) For Rheem tankless water heater, C2 11 is usually means bad circuit board.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) What is a 5400?
Is this a water heater?
What brand water heater. What type.
Is this gas or electric.
New installation, or older installation that started having problems.
Has required yearly maintenance been done?
Is the unit rated for correct altitude?
Has the water temperature been increased?
3) Add comment and include description of product, and best description of problem for possible assistance.
4) Call service technician.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 30, 2012 | Water Heaters
Nokia c2-02 probulam no sim working. Shows enter code undo
Hi, I think your mobile must be network restricted. You must unlock it. The safest and easiest way to unlock a Nokia C2-02 is to unlock using unlock code. You can get the unlock code for a Nokia C2-02 from www.prounlocking.com/nokia-c2-02/rs8wp9/ at affordable cost with easy unlocking instructions.
Here are the steps for unlocking a Nokia C2-02,
1 - Switch on your Nokia C2-02 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-02.
3 - Compose #pw+CODE+1#.
4 - The Nokia C2-02 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-02 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 27, 2012 | Cell Phones
I have a paloma PTG 74PVP-2, error codes C2 14 flashing?
Before calling service technician, or Rheem, copy following link for troubleshoot resources:
Error 14 is low manifold pressure, cracked heat exchanger, restricted air flow.
C2 can be dirty combustion parts, bad gas solenoid valve, bad circuit board.
Combination of these two error codes implies possible PC board failure, which is similar to failed motherboard on computer.
Suggest that service technician perform the required yearly maintenance to see it that fixes error code.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 25, 2012 | Rheem Water Heaters
I need restriction code for nokia c2 ? my ime=357418042456759
You can unlock a NOKIA C2 safer and easier using unlock code. You can get the unlock code for your NOKIA C2 either from your network provider or from any reliable online source. For example you can get the unlock code for a NOKIA C2 from www.prounlocking.com/nokia-c2-00/rs8wp9/ at low cost.
Here are the steps for unlocking a NOKIA C2,
1 - Switch on your Nokia C2-00 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-00.
4 - The Nokia C2-00 would then display the message "SIM Restriction Off" and will be unlocked!
Aug 10, 2012 | Cell Phones
I need restriction code for nokia c2 01
You can get the restriction code for your NOKIA C2-01 either from your network provider or from any reliable online source. For example you can get the unlock code for a NOKIA C2-01 from at low cost.
Here are the steps for unlocking a NOKIA C2-01,
1 - Switch on your Nokia C2-01 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-01.
4 - The Nokia C2-01 would then display the message "SIM Restriction Off" and will be unlocked!
Aug 03, 2012 | Nokia mobile C2-00 Dual SIMbiosis
I forgot my nokia c2-00 security code
sir my phone nokia c2-00 security code error bata raha hai please
Dec 21, 2011 | Nokia mobile C2-00 Dual SIMbiosis
Restriction code for nokia c201
I HAVE A NOKIA C2-01 MOBILE FROM ENGLAND WHEN I INSERTED SIM IT ASKED FOR THE RESTRICTION CODE .MY IMEI CODE IS 358607043358936.PLEASE HELP...
Sep 18, 2011 | Cell Phones
Heating & Cooling Logo
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
