The clunking noise you can hear is also happening in my bathroom as a result of the washing machine clunking. The bathroom is upstairs and at the other end of house. An engineer came out today because
  • 14,417 Answers
Sounds like the bearing in the drum is bad,may have to replace whole drum,bearing in it may not be replaceable,to find out,call appliance company and have them look your model number and see if drum is a whole unit or bearing can be replaced.
Posted on Oct 30, 2012
SOURCE: Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
If you are not sure what you are doing, call out an engineer and have the job carried out properly with safety testing at the end of the job!
Posted on Dec 09, 2007
SOURCE: Washing machine will not fill w/ hot or cold water
my washing maschine is only filling with hot water not cold.
It worked fine yesterday!
Posted on Dec 27, 2008
skrbin
  • 121 Answers
SOURCE: indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Posted on Feb 17, 2009
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
  • 154 Answers
SOURCE: My washing machine makes a cluck sound at the end
Not knowing what model machine you have, I would hazard a guess and say it is your break solenoid or break arm or a variation on a break system.
After the spin cycle, the break solenoid or motor engages a break arm to stop and lock your spinning drum. The loud clunk is normal especially in Simpson and Hoover top load machines.
You can check this by putting the machine on a spin cycle. Once the machine gets up to speed, open the door. You will hear the clunck and then the drum stops abrublty.
If that is the case, it is normal and no need to worry about it. However, it you did not have the noise before, then best to get it checked out by a repairer.
Regards
Ash
Posted on Nov 08, 2009
Testimonial: "Hi Ash, You are correct. It is a Simpson model top loader. (esprite model). will try what you suggest. Many thanks Cheers Carol"
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
heatman101
ghgf
Sep 03, 2010 | Splendide 2100 Vented Washer-Dryer
I have a 2 story house and at one end my outlets stopped working,nore does any of the bathroom out lets.the other side of upstairs work plus the downstairs work what the heck happened?????anyone please...
have you checked you breakers? If the breakers are working and all connected, you have a problem only a licensed electrician should deal with.
Jun 03, 2010 | Washing Machines
My shower drain gurgles when the washing machine drains
The drain from your washer is tied to your shower drain and it is receiving air from your shower drain. Maybe your washer drain is not vented. This should not be a major concern if you can live with the noise.
Jan 03, 2010 | Dryers
My Bathroom Extractor Fan does not work properly and for some reason the bathroom smells of cigarette smoke when the upstairs neighbours are at home!! Our landlord say's this is not possible!!!
Yes, very possible!. The bathroom fan is connected together, and the upstairs one is down-drafting to you. Have the exhaust checked for blockage, or buy a fan that has a built-in damper that closes the exit when not in use.
Oct 21, 2009 | HP Extractor Fan Kit 110V Rack Mount Fan
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
