Question about JVC Audio Players & Recorders
Can I hook up wireless speakers to the JVC R-X44 Receiver?
If so, how? Is there some sort of adapter between the speaker wire coonection and the wifi connector?
    Master:
  • 444 Answers
You need the transmitter that hooks up to the speaker terminals of your reciever,
Posted on Nov 03, 2012
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
  • 105 Answers
SOURCE: I am trying to connect
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Posted on Apr 03, 2008
  • 151 Answers
SOURCE: Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Posted on Aug 05, 2008
SOURCE: Sony DB930 - Rear right speaker (terminal connector?) not working
These receivers have a common fault with the relay on the amplifier board. If you open the lid, the rear amplifier PCB is on-top in the centre. The relay is in the middle of the board. It should be easy enough if you have a multimeter to check the contacts are closing correctly, if not then replace it, the specs are printed on the side. If you are not confident then don't try it, these are powerful amplifiers with +/-60v DC rails. 120v DC can do you some damage if you get it wrong!!
Posted on Feb 11, 2009
smarthome2
  • 1114 Answers
SOURCE: Outdoor speaker hook-up
Go into the manual setup on the GUI then go to the zone 2 and zone 3 setup. If you are using only the power from the receiver to power the speakers, make sure the setting is for Zone 3 amp "INT" if you still have no volume, on the front of the receiver look at the display, make sure "zone 3" is lit up then use the small remote and turn up the vol. if it's on you will see "zone 3 vol" and the bar going up it should be ok. if it says "fixed" it thinks you have an external volume control, if you do, make sure it's "on" at about 12 o'clock and test. If not, you need to switch it in the on screen "menu" or "GUI" button, follow to zone 2 & 3 vol control and make sure it is set to variable. If you still have no vol post a comment and we can dig further. Hope this helps
Posted on Jun 06, 2009
FIND THE CODE TO GET RID OF THE WORD PROTECT ON MY JVC RECEIVER
Protect is displayed because there's a problem with your speaker wiring or there's a speaker shorted out. It's not there to tick you off for some reason.
So, you don't need a code. What you need to do is go sort out your wiring because somewhere there's two cables touching and the amp is trying to save itself from blowing up because you wired something wrong.
Sep 09, 2014 | JVC Audio Players & Recorders
I have a JVC Receiver that I'm trying to hook a
"[A] set of Sony Speakers" is meaningless. What model(s)? If they're part of an all-in-one system they may not be suitable for the JVC.
Manuals exist for everything. Read them.
http://www.retrevo.com/support/JVC-RX-5052S-Receivers-manual/id/315ci175/t/2/
This receiver is designed for standard commonly available 8-ohm (nominal) speakers that connect with common stripped end lamp cord or speaker wire.
Sep 03, 2011 | JVC Audio/video Receiver Rx-5052s -...
Where do i connect wireless speakers to stereo?
This would depend on several things. Most receivers have place on the back where bare wire is plugged in by pushing some sort of tab. But, also some receivers will require an adaptor of some sort. First check to see where the speaker outs are on the receiver. Next figure out what kind of an adapter you need to bridge to that connection. Get you user manual out.
Feb 14, 2011 | Audio Players & Recorders
Trying to hook up sony s-master with componet cables an the s-master displays on the display ''PROTECT UNPLUG'' however with nothing plugged in the s-master, works fine
Check speaker wires, any wire seems shorted and causing Protect Unplug error message in receiver.
Good way to sort out bad wire is plug one speaker at a time, turn On receiver check, turn Off, then plug next speaker wire until you find out what speaker wire activates protection circuit of receiver.
Thanks.
Jan 01, 2011 | Audio Players & Recorders
JVC HX-C6
Hello, Yes you can, if they are the regular speaker wire (2 wires--black+red or something similar)
Nov 22, 2009 | JVC HX-C6 Shelf System
Wireless speakers will not work.
Post the Model #'s of the products involved and I can be a little more specific. Using generic troubleshooting, First: make sure you have the wires for the receiving unit of the wireless speakers hooked up to either "A" Front or "B" Front. thenmake sure your receiver speaker switch for the corresponding location is on. It will light up on the front of the receiver either A, B, or both. Now, turn on the AV receiver and Tune it to a strong radio signal in your area, turn up the volume 1/4 to 1/2 way. Power the wireless units on. Both the speakers and their receiver should have a power button or at least a light to let you know they are getting signal. keep the speakers close and fine tune the wireless receiver with them until the led light on the front of the speakers is solid. You should have good audio at this point.
The other way the wireless receiver is hooked up is with RCA cables to the AV receiver. Without knowing what AV receiver you have, plug the RCA's into an "Output" like "Front Main Pre Out" or "VCR/Tape2 mon" or just plain "Monitor out" Depending on which Output you use will determine the setting on the receiver. If you need further clarification, post your equipment model numbers and I can tell you exactly what to do. Hope this helps
Jun 24, 2009 | Electronics - Others
Hook up wireless speakers
I'm assuming the wireless speakers you have utilize an RCA jack to connect to the receiver.
Solution:
The good news is yes, you can use them on your receiver. The bad news is that the only output on your receiver is "VIDEO OUT" so whatever you want to watch or hear on the wireless speakers must be connected to the "VIDEO INPUT".
If the wireless speaker module uses speaker wire to connect to a receiver you will simply tap into the surround thumb clip speaker jacks.
I will add that wireless speakers tend to be disappointing when used in home theater.
Mar 24, 2009 | Sony STR-DE475 Receiver
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
Overload
No, one of your speakers is damaged (could be an amp channel went bad, but speaker is more likely). Unplug all spkrs, then plug one in and see if it acts normal when turned up. Repeat this until all speakers are hooked up or the culprit spkr is found.
Sep 25, 2007 | JVC RX-6018V Receiver
122 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
